1750J
1750J
    HAMMONDMANUFACTURING
    螺栓安装
    1750J
1750J 数据手册
Hammond Mfg. Co. Ltd., Electronics Division www.hammondmfg.com 1750J PRIMARY BRN TUBE GUITAR AMPLIFIER - OUTPUT TRANSFORMER • • • • • • Designed for drop in replacement of original units. Constructed to look similar to original factory units (where possible). Material used & design specifications were kept as close as possible to the original part to preserve the stock "tone". Open style with minimum 9" long primary and secondary leads Frequency response 70Hz - 15KHz (0/-1.5dB reference @ 1KHz) Distortion is less than 3% @ 70Hz SECONDARY BLK COM 4000 CT Ohms RED BLU 40 WATTS 70Hz - 15kHz GRN 4 Ohms BLK DA ELECTRICAL SPECIFICATIONS Characteristics Input Impedance Output Impedance Output Power Typical 4000 Ohms 4 Ohms 40W DCR Primary Brown-Blue Secondary Black-Green 185.0 Ohms 0.400 Ohm Inductance Impedance Primary Blue-Brown @ 1.0 kHz, 1.0 V OC 19.8H 120K Ohm Leakage Inductance Primary Blue-Brown @ 1.0 kHz, 1.0 V SC 227.3mH Dielectric Strength Temperature Range 1500VRMS -40 to 105 degC TEST CONDITIONS Measurement instruments: D scope series iii audio analyzer Wayne Kerr 3255B with a 3265B Keithley 2010 DVM Hp4192a impedance analyzer TE C 17 GRN BR 40 W N BL - R ATT K ED S M A - G R - BL 70 DE N: U: Hz I N 4  40 - 1 5 00 CA  C kH z NA T DA 50 J B BLU RED A D G BRN NOTE: ALL LEADS 9" LONG MIN. Dimensions A 4.000” ±0.063 B 2.800” REF C 2.63" MAX D G 3.560” ±0.063 0.187” ±0.015 TYPICAL TEST CIRCUIT PRIMARY R S/ SECONDARY 2 RL * All graphs input level 27dBu @1.0KHz reference. **The results are typical and are subject to normal manufacturing and electrical tolerances. R S/ OUT 2 www.hammondmfg.com This drawing and the information in it is the property of Hammond Manufacturing. It may not be reproduced, transmitted or used in any manner whatsoever without the written permission of Hammond Manufacturing. Data subject to change without notice. www.hammondmfg.com
