1760J
1760J
    HAMMONDMANUFACTURING
    螺栓安装
    1760J
1760J 数据手册
Hammond Mfg. Co. Ltd., Electronics Division www.hammfg.com 1760J • • • • • • PRIMARY SECONDARY BRN TUBE GUITAR AMPLIFIER - OUTPUT TRANSFORMER BLK COM GRN 4 Ohm YEL 8 Ohm 4000 CT Ohm Designed for drop in replacement of original units. Constructed to look similar to original factory units (where possible). Material used & design specifications were kept as close as possible to the original part to preserve the stock "tone". Open style with minimum 9" long primary and secondary leads Frequency response 70Hz - 15KHz (0/-1.5dB reference @ 1KHz) Distortion is less than 1% @ 70Hz RED WHT 16 Ohm BLU 70Hz - 15kHz 40 WATTS BLK ELECTRICAL SPECIFICATIONS Characteristics Input Impedance Output Impedance Output Power DCR Primary Brown-Blue Secondary Black-Green Secondary Black-Yellow Secondary Black-White Inductance Impedance Primary Brown-Blue Leakage Inductance Brown-Blue Dielectric Strength Temperature Range GRN Typical 4000 Ohms 4, 8 & 16 Ohms 40W 185.0 Ohms 0.356 Ohm 0.502 Ohm 0.910 Ohm @ 1.0 kHz, 1.0 V OC 19.5H 124KOhm @ 1.0 kHz, 1.0 V SC 35.93mH 1500VRMS -40 to 105 degC B DA LK/G B TE R N R N 40 W /YE - R AT L/W ED TS M A H T - BL 70 DE : C U: Hz IN OM 400 - 15 CA /4 0  kH NA z DA /8 /1C T 6 17 C HA MA MM O NU ND FA CT U RIN 60 J YEL WHT B G BLU RED A D G BRN NOTE: ALL LEADS 9" LONG MIN. Dimensions A 4.000” ±0.063 B 2.80" REF C 2.63" MAX D G 3.560” ±0.063 0.187” ±0.015 TYPICAL TEST CIRCUIT TEST CONDITIONS Measurement instruments: D scope series iii audio analyzer Wayne Kerr 3255B with a 3265B Keithley 2010 DVM Hp4192a impedance analyzer * All graphs input level 27dBu @1.0KHz reference. **The results are typical and are subject to normal manufacturing and electrical tolerances. PRIMARY R S/ SECONDARY 2 RL R S/ OUT 2 Release 2: 03.03.2021 www.hammfg.com This drawing and the information in it is the property of Hammond Manufacturing. It may not be reproduced, transmitted or used in any manner whatsoever without the written permission of Hammond Manufacturing. Data subject to change without notice. www.hammfg.com
