Hammond Mfg. Co. Ltd., Electronics Division
www.hammondmfg.com
140MEX
CHASSIS MOUNT – SHIELDED
IMPEDANCE MATCHING TRANSFORMER
This transformer operates in the 20 Hz to 20 KHz range.
The metal can provides excellent shielding from a broad
range of external sources. The nickel core provides high
permeability combined with low losses.
Typical applications Input/output Isolation, Line Matching,
Driver, Hybrid applications.
ELECTRICAL SPECIFICATIONS
Characteristic
Input Impedance
Output Impedance
Output Power
DCR
Primary
Secondary
Inductance
Primary
Secondary
Impedance
Primary
Secondary
Typical
100,000 Ω
1500 Ω
10.0 dbm
5430 Ω
159 Ω
@ 1.0 kHz, 1.0 V OC
2100 H
34 H
@ 1.0 kHz, 1.0 V OC
13.7 kΩ
810 kΩ
Frequency Response
Turns ratio
±1db from 20 Hz to 20KHz
8.13:1
Insertion Loss
Return Loss
Longitudinal balance
很抱歉,暂时无法提供与“140MEX”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+681.703441+88.58910
- 10+654.1141410+85.00380
- 25+627.8914925+81.59610
- 50+621.1436450+80.71920
- 100+610.72292100+79.36500
