Hammond Mfg. Co. Ltd., Electronics Division
www.hammondmfg.com
1750JA
PRIMARY
TUBE GUITAR AMPLIFIER - OUTPUT TRANSFORMER
Designed for drop in replacement of original
units.
Constructed to look similar to original factory
units (where possible).
Material used & design specifications were kept
as close as possible to the original part to
preserve the stock "tone".
Open style with minimum 11" long primary and
secondary leads
Frequency response 70Hz - 15KHz
(0/-1dB reference @ 1KHz)
Distortion is less than 1% @ 70Hz
4250 CT
Ohm
RED
BLU
Typical
4250 Ohms
4 & 8 Ohms
40 W
DCR
Primary Brown-Red
Primary Red-Blue
Secondary Black-Grn/Yel
Secondary Black-Green
82.0 Ohms
108.3 Ohms
0.253 Ohm
0.462 Ohm
Inductance
Impedance
Primary Brown-Blue
@ 1.0 kHz, 1.0 V OC
11.40 H
72.0 KOhm
28.86 mH
259.20 Ohm
55.60 mH
457.80 Ohm
Leakage Inductance
Primary Brown-Blue
@ 1.0 kHz, 1.0 V SC
31.39 mH
Dielectric Strength
Temperature Range
2000VRMS
-40 to 105 degC
J A A Hz T
5 0 NAD 15k C
1 7 IN CA Hz - 250
DE
70 U: 4 L: 4
MA S
L E
8
TT - B / Y N:
WA ED RN GR
40 N - R K - GLK L
B
R
B
B
GRN/YEL
4 Ohm
GRN
8 Ohm
B
TE
DA
BLK
F
E
D
GRN/YEL
A
GRN
G
BLU
NOTE: ALL LEADS 11" MIN. OUT.
RED
BRN
Dimensions
A 2.500” ±0.063
B 3.150” ±0.125
C 3.256” ±0.063
D
E
F
2.000” ±0.063
2.150” ±0.063
2.650” ±0.063
G
0.188” X 0.375”
±0.015
TYPICAL TEST CIRCUIT
PRIMARY
Keithley 2010 DVM
Hp4192a impedance analyzer
COM
C
TEST CONDITIONS
Measurement instruments:
D scope series iii audio analyzer
Wayne Kerr 3255B with a 3265B
BLK
70Hz - 15kHz
40W
ELECTRICAL SPECIFICATIONS
Characteristics
Input Impedance
Output Impedance
Output Power
SECONDARY
BRN
R S/
SECONDARY
2
RL
* All graphs input level 27dBu @1.0KHz reference.
**The results are typical and are subject to normal manufacturing and
electrical tolerances.
R S/
OUT
2
www.hammondmfg.com
This drawing and the information in it is the property of Hammond Manufacturing. It may not be reproduced, transmitted or used in any manner whatsoever without the written
permission of Hammond Manufacturing. Data subject to change without notice.
www.hammondmfg.com
很抱歉,暂时无法提供与“1750JA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1194.78240
- 200+476.73360
- 500+460.80360
- 1000+452.93040
- 国内价格 香港价格
- 1+887.125281+114.91375
