Hammond Mfg. Co. Ltd., Electronics Division
www.hammondmfg.com
125DSE
UNIVERSAL SINGLE ENDED TUBE OUTPUT TRANSFORMER
Designed for general purpose or replacement use (not Hi-Fi), in single ended, tube output circuits.
Frequency response: 100 Hz. - 15 Khz at full rated power (see graphs for detailed response).
For full frequency response (20 Hz. to 20 Khz.) - see our 1627-1642 Series.
For push-pull output use, see our 125 Series.
Open style with minimum 12" long primary & secondary leads.
All sizes use butt stacked cores (using 29M6 steel) with an air gap, to reduce D.C. core saturation.
Primary impedance range from 2,500 to 10,000 Ohms.
Secondary impedance range from 4 to 32 Ohms.
WHT
YEL
GRN
BLU
ORG
BLK
BRN
ELECTRICAL SPECIFICATIONS**
Characteristic
Input Impedance
Output Impedance
Output Power
Max. DC Bias
Primary - DCR
Blue – Brown
Secondary DCR
Black – Orange
Black – Green
Black – Yellow
Black – White
Inductance
Primary – Blue – Brown
Sec – Black – Orange
Sec – Black – Green
Sec – Black – Yellow
Sec – Black – White
Impedance
Sec – Black – Green
Sec – Black – White
Frequency Response
Dielectric Strength
Temperature Range
Typical
2500 - 10000
4/8/16/32
10 Watts
70 mA
www.hammondmfg.com
Schematic and Hook Up Data
PRIMARY
WHT 32 @ 10,000 PRI
16 @ 5,000 PRI
8 @ 2,500 PRI
BRN
126.5
238 m
315 m
438 m
600 m
@ 1.0 kHz, 1.0 V OC
4.48 Hy
3.48 mH
6.65 mH
14.0 mH
27.4 mH
@ 1.0 kHz, 1.0 V OC
28.3 K
21.8
44.3
92.0
180.0
See graphs for specific
response, Typ. 1.0db from
100Hz to 15KHz
1500Vrms
-40 To 105C
SECONDARY
10,000
YEL 16 @ 10,000 PRI
8 @ 5,000 PRI
4 @ 2,500 PRI
OR
5,000
GRN 8 @ 10,000 PRI
4 @ 5,000 PRI
OR
2,500
ORG 4 @ 10,000 PRI
BLU
BLK
125DSE
SINGLE ENDED AUDIO 10W 70mA DC
PRI: 10,000; 5,000; 2,500 OHM
SEC: 4, 8, 16, 32 OHM
DATE CODE
MADE IN CANADA
www.hammondmfg.com
www.hammondmfg.com
www.hammondmfg.com
PRIMARY
TYPICAL TEST CIRCUIT
R S/
SECONDARY
2
RL
R S/
OUT
2
Measurement instruments
Hp4192a impedance analyzer
Hp3456a DVM
Keithley 2002 DVM
D scope series iii audio analyzer
Wayne Kerr 3255B with a 3265B
* All graphs input level 20dbu.
** The results are typical and are subject to normal manufacturing and electrical tolerances.
This drawing and the information in it is the property of Hammond Manufacturing. It may not be reproduced, transmitted or used in any manner whatsoever without the written permission of
Hammond Manufacturing. Data subject to change without notice.
很抱歉,暂时无法提供与“125DSE”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+629.002751+75.16184
- 10+568.6304810+67.94774
- 25+552.5361325+66.02456
- 50+542.5237550+64.82815
- 100+534.06420100+63.81729
