Hammond Mfg. Co. Ltd., Electronics Division
www.hammondmfg.com
1750K
PRIMARY
TUBE GUITAR AMPLIFIER - OUTPUT TRANSFORMER
SECONDARY
BLU
Designed for drop in replacement of original
units.
Constructed to look similar to original factory
units (where possible).
Material used & design specifications were kept
as close as possible to the original part to
preserve the stock "tone".
Open style with minimum 9" long primary and
secondary leads
Frequency response 70Hz - 15KHz
(0/-1.0dB reference @ 1KHz)
Distortion is less than 1% @ 70Hz
WHT 2 Ohm
RED
4000
Ohm
CT
BLK
70Hz - 15kHz
50W
ELECTRICAL SPECIFICATIONS
Characteristics
Input Impedance
Output Impedance
Output Power
Typical
4000 Ohms
2 Ohms
50 W
COM
BRN
B
z
CT
0 K 5 kH 0
75 z - 1 4 0 0
1 7 0 H L U: 2
B
W D- HT
5 0 -R E K-WDA
L A
N
B R B AN
BLK
MA
DE
IN
DA
TE
C
C
DCR
Primary Brown-Blue
Secondary Black-White
BRN
89.43 Ohms
0.180 Ohm
WHT
F
Inductance Impedance
Primary Brown-Blue
RED
D
E
BLU
A
@ 1.0 kHz, 1.0 V OC
12.5H
81 KOhm
G
NOTE: ALL LEADS 9.0" OUT MIN.
Leakage Inductance
Brown-Blue
@ 1.0 kHz, 1.0 V SC
3.34mH
Dielectric Strength
Temperature Range
2000VRMS
-40 to 105 degC
Dimensions
A 4.063” ±0.063
B 3.125” ±0.125
C 3.453” ±0.063
D
E
F
Keithley 2010 DVM
Hp4192a impedance analyzer
G
0.177” X 0.300”
±0.015
TYPICAL TEST CIRCUIT
TEST CONDITIONS
Measurement instruments:
D scope series iii audio analyzer
Wayne Kerr 3255B with a 3265B
3.500” ±0.063
2.000” ±0.063
2.560” ±0.063
PRIMARY
R S/
SECONDARY
2
RL
* All graphs input level 27dBu @1.0KHz reference.
**The results are typical and are subject to normal manufacturing and
electrical tolerances.
R S/
OUT
2
www.hammondmfg.com
This drawing and the information in it is the property of Hammond Manufacturing. It may not be reproduced, transmitted or used in any manner whatsoever without the written
permission of Hammond Manufacturing. Data subject to change without notice.
www.hammondmfg.com
很抱歉,暂时无法提供与“1750K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1456.44480
- 200+581.13720
- 500+561.71880
- 1000+552.11760
- 国内价格 香港价格
- 1+1144.570441+148.26191
- 10+1019.3919510+132.04691
- 25+973.4440425+126.09505
- 50+940.0728550+121.77232
- 100+907.85848100+117.59943
