Hammond Mfg. Co. Ltd., Electronics Division
www.hammondmfg.com
PRIMARY
WHT
1750Y
SECONDARY
GRN 8 Ohm
TUBE GUITAR AMPLIFIER - OUTPUT TRANSFORMER
Designed for drop in replacement of original
units such as VOX1 AC15 Vintage (P-TVO15)
Constructed to look similar to original factory
units (where possible).
Material used & design specifications were kept
as close as possible to the original part to
preserve the stock "tone".
Open style with minimum 18" long primary and
secondary leads
Frequency response 70Hz - 15KHz
(0/-1dB reference @ 1KHz)
Distortion is less than 1% @ 70Hz
BRN
6200
Ohm
CT
BLK
RED
70Hz - 15kHz
15W
Y
BLK
ELECTRICAL SPECIFICATIONS
Characteristics
Input Impedance
Output Impedance
Output Power
Typical
6200 Ohms
8 Ohms
15 W
DCR
Primary White-Red
Secondary Black-Green
289.0 Ohms
0.480 Ohm
COM
A
GRN
R
MEz
OR15kH CT
F
S z 00
B
1
A N 70H : 62 8 A
TR TS RED M D
IO WATBRN - N: CO C AN A
D
U 15 GR
DA
TE
IN
T
WH BLK
DE
MA
C
W HT
E
Inductance Impedance
Primary White-Red
@ 1.0 kHz, 1.0 V OC
14.6H
92K Ohm
31.04mH
231.20 Ohm
D
G
A
BRN
Leakage Inductance
Primary White-Red
@ 1.0 kHz, 1.0 V SC
14.04 mH
Dielectric Strength
Temperature Range
2000VRMS
-40 to 105 degC
TEST CONDITIONS
Measurement instruments:
D scope series iii audio analyzer
Wayne Kerr 3255B with a 3265B
RED
NOTE: ALL LEADS 18.0" OUT MIN., STRIPPED .5"
Dimensions
A
2.500” ±0.063 C
3.060” ±0.063 E
2.376” ±0.063
B
3.328” ±0.125 D
1.875” ±0.063 G
0.185” X 0.370” ±0.015
TYPICAL TEST CIRCUIT
PRIMARY
Keithley 2010 DVM
Hp4192a impedance analyzer
R S/
SECONDARY
2
RL
* All graphs input level 27dBu @1.0KHz reference.
**The results are typical and are subject to normal manufacturing and
electrical tolerances.
1
R S/
OUT
2
DISCLAIMER: Hammond Mfg. is not affiliated with Fender Musical Instruments Corp., Marshall Amplification, Yorkville/Traynor, AMPEG or VOX Amplification companies.
Amplifier model names are trademarks of the amplifier companies and are just listed here for reference purpose only.
www.hammondmfg.com
This drawing and the information in it is the property of Hammond Manufacturing. It may not be reproduced, transmitted or used in any manner whatsoever without the written
permission of Hammond Manufacturing. Data subject to change without notice.
www.hammondmfg.com
很抱歉,暂时无法提供与“1750Y”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1697.01480
- 200+677.11680
- 500+654.49080
- 1000+643.31280
