126B
126B
    HAMMONDMANUFACTURING
    螺栓安装
    126B
126B 数据手册
10/3/22, 1:31 AM Tube Driver - Interstage (126 Series) - Hammond Mfg. Quality Products. Service Excellence. Tube Driver - Interstage 126 Series Features Designed for driver use ONLY in single ended tube output amplifiers. These units replace coupling capacitor circuits for improved sound. Closed style with minimum 8" long leads. All models use bifilar wound windings for exceptional coupling and bandwidth. Minimum frequency response 20 Hz. - 20 Khz (+/- 1db max. ref. 1 Khz.). The core is gapped to support the specified D.C. bias current. Maximum working voltage - 400 VDC Units are Hi-Pot tested at 1,000 VDC Core uses Hi grade silicon laminations (29M6). Units weight - 3 lbs. 2 oz.   Primary Secondary D.C. Part No. D.C. Audio Impedance Resistance Impedance Resistance Watts (Ohms) (Ohms) (Ohms) (Ohms) https://www.hammfg.com/electronics/transformers/audio/126 Dimensions Rated D.C. Inductance Bias Current G A B C D E Mtg Slot 1/2 10/3/22, 1:31 AM Tube Driver - Interstage (126 Series) - Hammond Mfg. Primary Secondary D.C. D.C. Audio Impedance Resistance Impedance Resistance Part No. Watts (Ohms) (Ohms) (Ohms) (Ohms) 126A 4 5K 178 5K 126B 4 5K 178 5K 126C 4 10K 375 10K Dimensions Rated D.C. G Inductance Bias Current A B C D E Mtg Slot 178 59 Henrys 15 ma. 2.50 3.12 3.12 2.00 2.25 0.20 0.38 178 44 Henries 30 ma. 2.50 3.12 3.12 2.00 2.25 0.20 0.38 375 106 Henrys 15 ma. 2.50 3.12 3.12 2.00 2.25 0.20 0.38 Data subject to change without notice © 2022. Hammond Manufacturing Ltd. All rights reserved. https://www.hammfg.com/electronics/transformers/audio/126 2/2
很抱歉,暂时无法提供与“126B”相匹配的价格&库存,您可以联系我们找货
126B
  • 1+1198.718821+155.14110
