Hammond Mfg. Co. Ltd., Electronics Division
www.hammfg.com
1760L
PRIMARY
TUBE GUITAR AMPLIFIER - OUTPUT TRANSFORMER
Designed for drop in replacement of original
units.
Constructed to look similar to original factory
units (where possible).
Material used & design specifications were kept
as close as possible to the original part to
preserve the stock "tone".
Open style with minimum 9" long primary and
secondary leads
Frequency response 70Hz - 15KHz
(0/-1dB reference @ 1KHz)
Distortion is less than 2% @ 70Hz
SECONDARY
WHT 16 Ohm
BLU
4200 CT RED
Ohm
BRN
YEL
8 Ohm
BLK
4 Ohm
GRN
COM
70Hz - 15kHz
50/60 Watts
ELECTRICAL SPECIFICATIONS
Characteristics
Input Impedance
Output Impedance
Output Power
Typical
4200 Ohms
4, 8 & 16 Ohms
50/60W
-1 5
46.48 Ohm
51.04 Ohm
0.238 Ohm
0.405 Ohm
0.578 Ohm
B
z
6 E
/1 DAT
T N:
OM
W A -B R : C
/ 6 0 E D HT
5 0 LU-R EL/W ADA
B K/Y AN
L
C
IN
N/ B
GR ADE
M
YEL
DCR
Primary Brown-Red
Primary Red-Blue
Secondary Green-Black
Secondary Green-Yellow
Secondary Green-White
kH
L z
60 70H CT /8
17 T S 4200 /4
WHT
C
BLK
G
RIN
D
ON CTU
MM FA
HA ANU
M
BLU
RED
GRN
D
E
A
BRN
F
Inductance Impedance
Primary Brown-Blue
@ 1.0 kHz, 1.0 V OC
5.72 H
36.4 KOhm
9.31 mH
66.26 Ohm
18.15 mH
126.85 Ohm
34.23 mH
233.5 Ohm
Leakage Inductance
Primary Brown-Blue
@ 1.0 kHz, 1.0 V SC
3.506 mH
Dielectric Strength
Temperature Range
2828VDC
-40 to 105 degC
TEST CONDITIONS
Measurement instruments:
D scope series iii audio analyzer
Wayne Kerr 3255B with a 3265B
G
NOTE: ALL LEADS 9.0" OUT MIN.
Dimensions
A 4.063” ±0.063
B 3.150” ±0.125
C 3.500” ±0.063
D 3.500” ±0.063
1.955” ±0.063
2.480” ±0.063
0.180” X 0.300"
±0.015
TYPICAL TEST CIRCUIT
PRIMARY
Keithley 2010 DVM
Hp4192a impedance analyzer
E
F
G
R S/
SECONDARY
2
RL
* All graphs input level 27dBu @1.0KHz reference.
**The results are typical and are subject to normal manufacturing and
electrical tolerances.
R S/
OUT
2
www.hammfg.com
This drawing and the information in it is the property of Hammond Manufacturing. It may not be reproduced, transmitted or used in any manner whatsoever without the written permission of
Hammond Manufacturing. Data subject to change without notice.
www.hammfg.com
Release 2: 01.18.2022
www.hammfg.com
