10/3/22, 1:31 AM
Tube Driver - Interstage (126 Series) - Hammond Mfg.
Quality Products. Service Excellence.
Tube Driver - Interstage 126 Series
Features
Designed for driver use ONLY in single ended tube output amplifiers. These units replace
coupling capacitor circuits for improved sound.
Closed style with minimum 8" long leads.
All models use bifilar wound windings for exceptional coupling and bandwidth.
Minimum frequency response 20 Hz. - 20 Khz (+/- 1db max. ref. 1 Khz.).
The core is gapped to support the specified D.C. bias current.
Maximum working voltage - 400 VDC
Units are Hi-Pot tested at 1,000 VDC
Core uses Hi grade silicon laminations (29M6).
Units weight - 3 lbs. 2 oz.
Primary
Secondary
D.C.
Part No.
D.C.
Audio
Impedance
Resistance
Impedance
Resistance
Watts
(Ohms)
(Ohms)
(Ohms)
(Ohms)
https://www.hammfg.com/electronics/transformers/audio/126
Dimensions
Rated D.C.
Inductance
Bias Current
G
A
B
C
D
E
Mtg Slot
1/2
10/3/22, 1:31 AM
Primary
Secondary
D.C.
D.C.
Audio
Impedance
Resistance
Impedance
Resistance
Part No.
Watts
(Ohms)
(Ohms)
(Ohms)
(Ohms)
126A
4
5K
178
5K
126B
4
5K
178
5K
126C
4
10K
375
10K
Dimensions
Rated D.C.
G
Inductance
Bias Current
A
B
C
D
E
Mtg Slot
178
59 Henrys
15 ma.
2.50
3.12
3.12
2.00
2.25
0.20
0.38
178
44 Henries
30 ma.
2.50
3.12
3.12
2.00
2.25
0.20
0.38
375
106 Henrys
15 ma.
2.50
3.12
3.12
2.00
2.25
0.20
0.38
Data subject to change without notice
© 2022. Hammond Manufacturing Ltd. All rights reserved.
2/2
很抱歉,暂时无法提供与“126A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1706.86440
- 200+681.04800
- 500+658.29240
- 1000+647.04960
