140UEX
140UEX
    HAMMONDMANUFACTURING
    螺栓安装
    140UEX
140UEX 数据手册
Hammond Mfg. Co. Ltd., Electronics Division www.hammondmfg.com 140UEX CHASSIS MOUNT – SHIELDED IMPEDANCE MATCHING TRANSFORMER This transformer operates in the 20 Hz to 20 KHz range. The metal can provides excellent shielding from a broad range of external sources. The nickel core provides high permeability combined with low losses. Typical applications Input/output Isolation, Line Matching, Driver, Hybrid applications. ELECTRICAL SPECIFICATIONS Characteristic Input Impedance Output Impedance Output Power DCR Primary Secondary Inductance Primary Secondary Impedance Primary Secondary Typical 10,000 Ω 10,000 Ω 10.0 dbm 886.0 Ω 903.5 Ω @ 1.0 kHz, 1.0 V OC 36.5H 36.5H @ 1.0 kHz, 1.0 V OC 882kΩ 882kΩ 140UEX 5mW 20Hz - 20kHz RED - YEL: 10000 Ω GRN - BLU: 10000 Ω MADE IN CANADA DATE SCHEMATIC DIAGRAM PRIMARY Frequency Response Turns ratio ±1db from 20 Hz to 20KHz 1:1 Insertion Loss Return Loss Longitudinal balance < 1.0 db 20.0db -50.0db Dielectric Strength 500 Vrms RED 10000 Ω YELLOW SECONDARY GREEN 10000 Ω BLUE TYPICAL TEST CIRCUIT PRIMARY R S/ SECONDARY 2 RL Measurement instruments Hp4192a impedance analyzer Hp3456a DVM Keithley 2002 DVM D scope series iii audio analyzer R S/ OUT 2 This drawing and the information in it is the property of Hammond Manufacturing. It may not be reproduced, transmitted or used in any manner whatsoever without the written permission of Hammond Manufacturing. Data subject to change without notice.
140UEX 价格&库存
很抱歉,暂时无法提供与“140UEX”相匹配的价格&库存,您可以联系我们找货
