Hammond Mfg. Co. Ltd., Electronics Division
www.hammondmfg.com
1750P
TUBE GUITAR AMPLIFIER - OUTPUT TRANSFORMER
Designed for drop in replacement of original
units such as Marshall1 JMP, JCM 800 (P-TM0100)
Constructed to look similar to original factory
units (where possible).
Material used & design specifications were kept
as close as possible to the original part to
preserve the stock "tone".
Frequency response 50Hz - 12KHz
(0/-1dB reference @ 1KHz)
Distortion is less than 1% @ 70Hz
ELECTRICAL SPECIFICATIONS
Characteristics
Input Impedance
Output Impedance
Output Power
Typical
3400 Ohms
4, 8 & 16 Ohms
50 W
DCR
PIN#4-7
PIN#4-2
PIN#2-7
PIN#23-21
PIN#23-16
PIN#23-14
82.25Ohms
40.70Ohms
41.47Ohms
0.351Ohm
0.506Ohm
0.725Ohm
Inductance Impedance
PIN#4-7
B
C
D
@ 60Hz, 10 V OC
22.65H
8.62K Ohm
Leakage Inductance
Primary Blue-Red
@ 60Hz, 10 V SC
10.30 mH
Dielectric Strength
Temperature Range
2250VRMS
-40 to 105 degC
E
A
Dimensions
A 3.760” ±0.063
B 3.090” ±0.125
C
D
TEST CONDITIONS
Measurement instruments:
D scope series iii audio analyzer
Wayne Kerr 3255B with a 3265B
3.130” ±0.063
2.500” ±0.063
3.128” ±0.063
TYPICAL TEST CIRCUIT
PRIMARY
Keithley 2010 DVM
Hp4192a impedance analyzer
E
R S/
SECONDARY
2
RL
* All graphs input level 27dBu @1.0KHz reference.
**The results are typical and are subject to normal manufacturing and
electrical tolerances.
1
R S/
OUT
2
DISCLAIMER: Hammond Mfg. is not affiliated with Fender Musical Instruments Corp., Marshall Amplification, Yorkville/Traynor, AMPEG or VOX Amplification companies.
Amplifier model names are trademarks of the amplifier companies and are just listed here for reference purpose only.
www.hammondmfg.com
This
www.hammondmfg.com
很抱歉,暂时无法提供与“1750P”相匹配的价格&库存,您可以联系我们找货
