1650F
1650F
    HAMMONDMANUFACTURING
    螺栓安装
    1650F
1650F 数据手册
Hammond Mfg. Co. Ltd., Electronics Division www.hammondmfg.com 1650F "CLASSIC" PUSH-PULL TUBE TYPE ULTRA-LINEAR OUTPUT TRANSFORMERS         Designed for push-pull tube output circuits. Enclosed (shielded), 4 slot, above chassis Type "X" mounting. Frequency response 30 Hz. to 30 Khz. at full rated power (+/- 1 db max. - ref. 1 Khz) minimum. Insulated flexible leads 8" min. Manufactured with plastic coil forms for coil support and insulation. Typical applications - Push-Pull: triode, Ultra-Linear pentode, pentode and tetrode connected audio output. Due to the unique interleaving of the windings BOTH secondary windings must be engaged to meet specifications (see hook-up diagrams below). Suggested tube types: 6L6GC, 6V6, 807, 5881, EL34 ELECTRICAL SPECIFICATIONS Characteristic Input Impedance Output Impedance Output Power Typical 7600 Ohms 4, 8 & 16 Ohms 25 Watts DCR Primary Brown-Blue Secondary Black-Green Secondary Black/Yel-Yel 210.0 Ohms 0.220 Ohm 0.270 Ohm Inductance | Impedance Primary Brown-Red @ 60Hz, 10.0V OC 285H 124KOhm Leakage Inductance Primary Brown-Red @ 60Hz, 10.0V SC 10.40mH Dielectric Strength Temperature Range 2000Vrms -40 To 105C LABEL: 1650F M a d e In C a n a d a DATE Note: The above examples of possible combinations are to help you narrow down the choices of transformers for your favorite tube types. How you operate the tubes (push-pull, push-pull parallel, ultra-linear, class, B+, bias, operating points, etc.) will change optimum plate to plate load impedance. Only a few of the most popular tubes are shown. As more tubes become available we will add them to the list. A tube manual or tube manufacturer's technical data sheets should be consulted first, before making a decision on a proper output transformer. Hammond Mfg. Co. Ltd., Electronics Division www.hammondmfg.com DIMENSIONAL DETAILS: YEL GRN/YEL BLK/YEL GRN BLK BRN BLU BRN/YEL RED BLU/YEL 2.000in ±0.063 Ø0.203 x 0.375 2.500in ±0.063 3.060in ±0.063 TEST CONDITIONS Measurement Instruments: dScope Series III Audio Analyzer Wayne Kerr 3255B with a 3265B Inductance Analyzer HP 4192a LF Impedance Analyzer Keithley 2010 DVM * All graphs input level 27dBu @1.0KHz reference. **The results are typical and are subject to normal manufacturing and electrical tolerances. 2.488in 3.500in ±0.063 ±0.125 TYPICAL TEST CIRCUIT PRIMARY R S/ SECONDARY 2 RL R S/ OUT 2 This drawing and the information in it is the property of Hammond Manufacturing. It may not be reproduced, transmitted or use d in any manner whatsoever without the written permission of Hammond Manufacturing. Data subject to change without notice. Hammond Mfg. Co. Ltd., Electronics Division www.hammondmfg.com
