10/6/22, 12:14 PM
Audio Broadcast Quality (850A Series) - Hammond Mfg.
Quality Products. Service Excellence.
Audio Broadcast Quality 850A Series
Sealed
Features
Deep-drawn steel case with tin plated finish, with two convenient 6-32 mounting studs
with mounting hardware.
Sealed case and wax potted core internally for stable characteristics and long life.
Wide frequency response +/- 0.5 db max. from 20 Hz. to 20 Khz. (except units over 5K
ohms impedance, may be down 1 db @ 20 Khz.)
Insertion loss of apx. 1 db.
Maximum power level +15 dbm. with specified characteristics, or higher levels with
reduced low frequency performance.
Distortion is apx. 1.5% @ 20 Hz. under full power.
Electrostatic shield between pri. & sec. connected to the green lead.
Humbucking construction
Balanced split windings on pri. & sec. for circuit versatility. Primary may be used as a
secondary and vice versa for impedance matching.
Includes mounting hardware.
Lead length: Min. 4"
Shipping weight 0.4 lb. (0.18 kg).
https://www.hammfg.com/electronics/transformers/audio/850a
1/2
10/6/22, 12:14 PM
Nominal Impedance
(Ohms)
(Ohms)
Part No.
Application
Primary
Secondary
850CA
850EA
Emitter or MIC to Line
12/48
50/200
850GA
Line Isolation or Hybrid
850HA
850JA
Nominal Resistance
(Ohms) +/+/- 20%
20%
(Ohms)
Overall
Overall Dimensions
Dimensions
B
C
D
Primary
Secondary
A
150/600
6
70
1.20
1.70
1.65
1.32
150/600
27
68
1.20
1.70
1.65
1.32
150/600
150/600
71
71
1.20
1.70
1.65
1.32
150/600
300/1200
70
140
1.20
1.70
1.65
1.32
Output to Line, or Line to Base
150/600
1200/4800
69
570
1.20
1.70
1.65
1.32
850LA
Output to Line, Matching or Bridging
5K/20K
150/600
2240
69
1.20
1.70
1.65
1.32
850NA
Output to Line, Matching or Interstage
150/600
10K/40K
65
4980
1.20
1.70
1.65
1.32
850QA
Interstage or Isolating
10K/40K
10K/40K
4890
4980
1.20
1.70
1.65
1.32
Data subject to change without notice
© 2022. Hammond Manufacturing Ltd. All rights reserved.
2/2
很抱歉,暂时无法提供与“850CA”相匹配的价格&库存,您可以联系我们找货
