1615A
1615A
    HAMMONDMANUFACTURING
    螺栓安装
    1615A
1615A 数据手册
Hammond Mfg. Co. Ltd., Electronics Division www.hammondmfg.com 1615A HI-FI AUDIO OUTPUT MULTIPLE SECONDARY TRANSFORMER  NEW & improved version of our 1608-1650 Series multiple secondary output transformers (Re-designed secondaries for easy hook-up of secondary loads).  Designed for push-pull tube output circuits.  Units are designed to provide ample "headroom" at bass frequencies (Note the weight of each transformer).  All models have a secondary tapped for 4, 8 or 16 ohm outputs.  Enclosed (shielded), 4 slot, above chassis Type "X" mounting.  Manufactured with plastic coil forms for coil support and insulation.  Frequency response 30Hz. to 30Khz. at full rated power (+/- 1db max. - ref. 1Khz) minimum.  Insulated flexible leads 8" min.  Included 40% screen taps for Ultra-Linear operation (if desired).  Typical applications - Push-Pull: triode, Ultra-Linear pentode, pentode and tetrode connected audio output. WHT YEL GRN BLK BRN BRN/YEL RED BLU/YEL BLU *For Full Dimensional Details see page 4 Hammond Mfg. Co. Ltd., Electronics Division www.hammondmfg.com ELECTRICAL SPECIFICATIONS** Schematic and Hook Up Data Characteristic Input Impedance Output Impedance Output Power Primary - DCR Blue – Brown Secondary DCR Black – Green Black – Yellow Black – White Typical 5000 4/8/16 15Watts PRIMARY 181.8 WHT - 16  193m 307m 379m Inductance Primary – Blue – Brown Black – Green Black – Yellow Black – White @ 1.0kHz, 1.0V OC 7.5Hy 70.2mH 125.9mH 210.4mH Impedance Primary – Blue – Brown Black – Green Black – Yellow Black – White @ 1.0kHz, 1.0V OC 46.6K 186.4 356.3 612.8 Frequency Response Dielectric Strength Temperature Range BLU (PLATE) SCHEMATIC SECONDARY See graphs for specific response, Typ. 1.0db from 30Hz to 30KHz 2000Vrms -40 To 105C BLU/YEL (SCREEN Gr) YEL - 8  RED B+ BRN/YEL (SCREEN Gr) BRN (PLATE) GRN - 4  BLK - COM Hammond Mfg. Co. Ltd., Electronics Division www.hammondmfg.com Hammond Mfg. Co. Ltd., Electronics Division www.hammondmfg.com Dimensional Details: Label: 1615A 15WATTS 30Hz - 30KHz BLK - GRN - YEL - WHT COM - 4OHM - 8OHM - 16OHM BLU - RED - BRN: 5000 OHMS CT BRN/YEL & BLU/YEL SCREEN TAPS 40% OF PRI VOLTS DATE Made In Canada TYPICAL TEST CIRCUIT PRIMARY R S/ 2 Measurement instruments Hp4192a impedance analyzer Hp3456a DVM Keithley 2002 DVM D scope series iii audio analyzer Wayne Kerr 3255B with a 3265B * All graphs input level 20dbu. ** The results are typical and are subject to normal manufacturing and electrical tolerances. SECONDARY RL R S/ OUT 2 This drawing and the information in it is the property of Hammond Manufacturing. It may not be reproduced, transmitted or use d in any manner whatsoever without the written permission of Hammond Manufacturing. Data subject to change without notice.
1615A 价格&库存
很抱歉,暂时无法提供与“1615A”相匹配的价格&库存,您可以联系我们找货
