Hammond Mfg. Co. Ltd., Electronics Division
www.hammondmfg.com
PRIMARY
1750V
SECONDARY
YEL
BLK
COM
TUBE GUITAR AMPLIFIER - OUTPUT TRANSFORMER
Designed for drop in replacement of original
RED
4000 CT
Ohm
units such as VOX1 AC30 Vintage (P-TVO30V)
Constructed to look similar to original factory
units (where possible).
Material used & design specifications were kept
as close as possible to the original part to
preserve the stock "tone".
Open style with minimum 12" long primary and
secondary leads
Frequency response 70Hz - 15KHz
(0/-1dB reference @ 1KHz)
Distortion is less than 2% @ 70Hz
GRN
WHT
BLU
Typical
4000 Ohms
8 & 16 Ohms
30 W
DCR
Primary Yellow-Red
Primary Red-White
Secondary Black-Blue
70.37 Ohms
70.30 Ohms
0.720 Ohm
ER
RM z
B
V FO 5KH CT 16 Ω
1 0
50
17 ANS0Hz - : 400 -Ω8 Ω
TR S 7 HT OM ADA
O ATT - W : C
N
DI 30 W- RED - BLU N CA
U
I
N
A
E
EL GR
Y K
BL
T
DA
E
D
MA
C
WHT
BLK
E
D
Inductance Impedance
Primary Yellow-White
Secondary Black-Green
16 Ohm
70Hz-15kHz
30 WATT
ELECTRICAL SPECIFICATIONS
Characteristics
Input Impedance
Output Impedance
Output Power
8 Ohm
@ 1.0 kHz, 1.0 V OC
6.30H
40K Ohm
19.66mH
132.95 Ohm
35.32mH
233.50 Ohm
A
G
RED
GRN
YEL
BLU
Leakage Inductance
@ 1.0 kHz, 1.0 V SC
5.14 mH
Dielectric Strength
Temperature Range
2000VRMS
-40 to 105 degC
NOTE: ALL LEADS 12.0" OUT MIN.
Dimensions
TEST CONDITIONS
Measurement instruments:
D scope series iii audio analyzer
Wayne Kerr 3255B with a 3265B
A
3.125” ±0.063 C
3.780” ±0.063 E
2.438” ±0.063
B
3.325” ±0.125 D
2.500” ±0.063 G
0.188” X 0.406” ±0.015
TYPICAL TEST CIRCUIT
Keithley 2010 DVM
Hp4192a impedance analyzer
* All graphs input level 27dBu @1.0KHz reference.
**The results are typical and are subject to normal manufacturing and
electrical tolerances.
1
DISCLAIMER: Hammond Mfg. is not affiliated with Fender Musical Instruments Corp., Marshall Amplification, Yorkville/Traynor, AMPEG or VOX Amplification companies.
Amplifier model names are trademarks of the amplifier companies and are just listed here for reference purpose only.
www.hammondmfg.com
This drawing and the information in it is the property of Hammond Manufacturing. It may not be reproduced, transmitted or used in any manner whatsoever without the written permission
of Hammond Manufacturing. Data subject to change without notice.
www.hammondmfg.com
www.hammondmfg.com
很抱歉,暂时无法提供与“1750V”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2305.65960
- 200+919.97640
- 500+889.22880
- 1000+874.04400
- 国内价格 香港价格
- 1+1566.602861+203.49377
- 10+1395.1902110+181.22813
- 25+1332.3134125+173.06076
- 50+1286.6656650+167.13134
