Hammond Mfg. Co. Ltd., Electronics Division
www.hammondmfg.com
1750X
TUBE GUITAR AMPLIFIER - OUTPUT TRANSFORMER
Designed for drop in replacement of original
units such as Marshall1 JCM 900 (P-TM9100O)
Constructed to look similar to original factory
units (where possible).
Material used & design specifications were kept
as close as possible to the original part to
preserve the stock "tone".
Frequency response 50Hz - 12KHz
(0/-1dB reference @ 1KHz)
Distortion is less than 1% @ 50Hz
ELECTRICAL SPECIFICATIONS
Characteristics
Input Impedance
Output Impedance
Output Power
Typical
1700 Ohms
4, 8 & 16 Ohms
100 W
DCR
PIN#4-2
PIN#2-6
PIN#4-6
PIN#23-21
PIN#23-16
PIN#23-14
16.58Ohms
16.04Ohms
32.58Ohms
0.130Ohm
0.170Ohm
0.230Ohm
Inductance
Impedance
PIN#4-6
@ 60Hz, 10 V OC
14.54H
5.61K Ohm
Leakage Inductance
Primary Blue-Red
@ 60Hz, 10 V SC
2.66 mH
Dielectric Strength
Temperature Range
2500VRMS
-40 to 105 degC
Dimensions
A 3.750” ±0.063
B 3.125” ±0.063
C 4.010” ±0.125
D
E
F
TEST CONDITIONS
Measurement instruments:
D scope series iii audio analyzer
Wayne Kerr 3255B with a 3265B
3.125” ±0.063
2.500” ±0.063
2.268” ±0.063
0.219” ±0.015
0.394” ±0.031
TYPICAL TEST CIRCUIT
PRIMARY
Keithley 2010 DVM
Hp4192a impedance analyzer
G
H
R S/
SECONDARY
2
RL
* All graphs input level 27dBu @1.0KHz reference.
**The results are typical and are subject to normal manufacturing and
electrical tolerances.
R S/
OUT
2
1
DISCLAIMER: Hammond Mfg. is not affiliated with Fender Musical Instruments Corp., Marshall Amplification, Yorkville/Traynor, AMPEG or VOX Amplification companies.
Amplifier model names are trademarks of the amplifier companies and are just listed here for reference purpose only.
www.hammondmfg.com
This
www.hammondmfg.com
很抱歉,暂时无法提供与“1750X”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1660.646601+215.80527
- 10+1478.8996010+192.18678
- 25+1412.2473025+183.52514
- 50+1363.8676250+177.23808
