Hammond Mfg. Co. Ltd., Electronics Division
www.hammondmfg.com
1627SEA
SINGLE ENDED “CLASSIC” TUBE OUTPUT TRANSFORMER – ULTRA-LINEAR
Over designed" for high fidelity, single ended, Class-A, tube output circuits (triode, tetrode or pentode tubes).
Enclosed (shielded), four slot, chassis Type "X" mounting.
Frequency response at least 20 Hz. to 20 Khz. at full rated power (+/- 1 db max., ref. 1 Khz.)
Insulated flexible leads 8" min.
For maximum versatility, all units (except the 1642SE & 1638SEA) include a 40% screen tap for Ultra-Linear,
tetrode/pentode operation (if desired). The 1642SE & 1638SEA do NOT include this screen tap as they were
designed principally for high impedance triode tubes.
High quality laminations, (M6) grain oriented silicon steel.
Core is gapped to reduce core saturation in Class-A tube amplifier circuits.
For general purpose or replacement use in single ended tube output circuits see our 125SE Series.
BLK
GRN
RED
YEL
WHT
NOTE: ALL LEADS 8" OUT
BLU
BLU/YEL
1627SEA
30 WATTS 20Hz - 20kHz
SECONDARY: 4/8/16 Ohm
Primary: 2500 Ohms
SCREEN TAP 40% of PRI VOLTS
DATE CODE
*For Full Dimensional Details see page 4
MADE IN CANADA
www.hammondmfg.com
Characteristic
Input Impedance
Output Impedance
Output Power
ELECTRICAL SPECIFICATIONS**
Schematic and Hook Up Data
Typical
2500
4/8/16
30 Watts
Primary - DCR
Blue – Brown
Secondary DCR
Black – Green
Black – Yellow
Black – White
413 m
517 m
724 m
Inductance
Primary – Blue – Brown
Black – Green
Black – Yellow
Black – White
@ 1.0 kHz, 1.0 V OC
7.94 Hy
23.5 mH
41.2 mH
87.9 mH
Impedance
Black – Green
Black – Yellow
Black – White
@ 1.0 kHz, 1.0 V OC
49.5 K
140
275
520
Frequency Response
Dielectric Strength
Temperature Range
See graphs for specific
response, Typ. 1.0db from
20Hz to 20KHz
2000Vrms
-40 To 105C
77.5
PRIMARY
RED
(B+)
SCHEMATIC
SECONDARY
WHT - 16
YEL - 8
2500
BLU/YEL
(40% SCREEN TAP)
BLU
(PLATE)
GRN - 4
BLK - COM
www.hammondmfg.com
www.hammondmfg.com
TYPICAL TEST CIRCUIT
PRIMARY
R S/
SECONDARY
2
RL
R S/
OUT
2
Measurement instruments
Hp4192a impedance analyzer
Hp3456a DVM
Keithley 2002 DVM
D scope series iii audio analyzer
Wayne Kerr 3255B with a 3265B
* All graphs input level 20dbu.
** The results are typical and are subject to normal manufacturing and electrical tolerances.
This drawing and the information in it is the property of Hammond Manufacturing. It may not be reproduced, transmitted or use d in any manner whatsoever without the written permission of
Hammond Manufacturing. Data subject to change without notice.
很抱歉,暂时无法提供与“1627SEA”相匹配的价格&库存,您可以联系我们找货
