1650RA
1650RA
    HAMMONDMANUFACTURING
    螺栓安装
    1650RA
1650RA 数据手册
Hammond Mfg. Co. Ltd., Electronics Division www.hammondmfg.com 1650RA HI-FI AUDIO OUTPUT MULTIPLE SECONDARY TRANSFORMER  NEW & improved version of our 1608-1650 Series multiple secondary output transformers (Re-designed secondaries for easy hook-up of secondary loads).  Designed for push-pull tube output circuits.  Units are designed to provide ample "headroom" at bass frequencies (Note the weight of each transformer).  All models have a secondary tapped for 4, 8 or 16 ohm outputs.  Enclosed (shielded), 4 slot, above chassis Type "X" mounting.  Manufactured with plastic coil forms for coil support and insulation.  Frequency response 30Hz. to 30Khz. at full rated power (+/- 1db max. - ref. 1Khz) minimum.  Insulated flexible leads 8" min.  Included 40% screen taps for Ultra-Linear operation (if desired).  Typical applications - Push-Pull: triode, Ultra-Linear pentode, pentode and tetrode connected audio output. BLK GRN YEL WHT BLU BLU/YEL RED BRN/YEL BRN *For Full Dimensional Details see page 4 Hammond Mfg. Co. Ltd., Electronics Division www.hammondmfg.com 1650RA ELECTRICAL SPECIFICATIONS** Schematic and Hook Up Data Characteristic Input Impedance Output Impedance Output Power Primary - DCR Blue – Brown Secondary DCR Black – Green Black – Yellow Black – White Leakage Inductance Primary – Blue – Brown Typical 5000 4/8/16 100Watts PRIMARY 105.6 BLU (PLATE) SCHEMATIC SECONDARY WHT - 16  224m 294m 384m @ 1.0kHz, 1.0V SC 170.4mH BLU/YEL (SCREEN Gr) YEL - 8  RED B+ Inductance Primary – Blue – Brown Black – Green Black – Yellow Black – White @ 1.0kHz, 1.0V OC 14.6Hy 162.2mH 182.4mH 208.6mH Impedance Primary – Blue – Brown Black – Green Black – Yellow Black – White @ 1.0kHz, 1.0V OC 91K 309.9 561.4 897.4 Frequency Response Dielectric Strength Temperature Range See graphs for specific response, Typ. 1.0db from 30Hz to 30KHz 2500Vrms -40 To 105C BRN/YEL (SCREEN Gr) BRN (PLATE) GRN - 4  BLK - COM Hammond Mfg. Co. Ltd., Electronics Division www.hammondmfg.com Hammond Mfg. Co. Ltd., Electronics Division www.hammondmfg.com Dimensional Details: Label: 1650RA 100WATTS 30Hz - 30KHz BLK - GRN - YEL - WHT COM - 4OHM - 8OHM - 16OHM BLU - RED - BRN: 5000 OHMS CT BRN/YEL & BLU/YEL SCREEN TAPS 40% OF PRI VOLTS Made In Canada DATE TYPICAL TEST CIRCUIT PRIMARY R S/ 2 Measurement instruments Hp4192a impedance analyzer Hp3456a DVM Keithley 2002 DVM D scope series iii audio analyzer Wayne Kerr 3255B with a 3265B * All graphs input level 20dbu. ** The results are typical and are subject to normal manufacturing and electrical tolerances. SECONDARY RL R S/ OUT 2 This drawing and the information in it is the property of Hammond Manufacturing. It may not be reproduced, transmitted or use d in any manner whatsoever without the written permission of Hammond Manufacturing. Data subject to change without notice.
1650RA 价格&库存
很抱歉,暂时无法提供与“1650RA”相匹配的价格&库存,您可以联系我们找货
