1750R
1750R
    HAMMONDMANUFACTURING
    螺栓安装
    1750R
1750R 数据手册
Hammond Mfg. Co. Ltd., Electronics Division www.hammondmfg.com 1750R PRIMARY TUBE GUITAR AMPLIFIER - OUTPUT TRANSFORMER • • • • • • SECONDARY ORG COM BRN Designed for drop in replacement of original 2000 Ohm units such as Yorkville/Traynor 1 98694 (A1301) Constructed to look similar to original factory units (where possible). Material used & design specifications were kept as close as possible to the original part to preserve the stock "tone". Open style with minimum 9" long primary and secondary leads Frequency response 50Hz - 12KHz (0/-1dB reference @ 1KHz) Distortion is less than 1% @ 50Hz CT YEL 4 Ohm RED GRN 8 Ohm BLU BLK 16 Ohm 50Hz-12kHz 100 W B R 50 2kHz C T 17 50H z - 21000  ELECTRICAL SPECIFICATIONS Characteristics Input Impedance Output Impedance Output Power Typical 2000 Ohms 4, 8 & 16 Ohms 100 W Y EL DA TE GRN C DCR Primary Blue-Brown Secondary Black-Orange 25.72 Ohms 0.222 Ohm Inductance Impedance Primary Blue-Brown Secondary Black-Green Secondary Black-Yellow Secondary Black-Orange @ 1.0 kHz, 1.0 V OC 4.84H 31.2K Ohm 16.20mH 117.05 Ohm 31.28mH 219.30 Ohm 58.48mH 400.60 Ohm Leakage Inductance Primary Blue-Brown @ 1.0 kHz, 1.0 V SC 11.37 mH Dielectric Strength Temperature Range 2250VRMS -40 to 105 degC TEST CONDITIONS Measurement instruments: D scope series iii audio analyzer Wayne Kerr 3255B with a 3265B  : TS - BR NN: 4 6  AT R :1 A 0W ED , G 1 0 - R O M , O RG NA D U C A B L LK : : 8  I N C B EL DE Y MA ORG BLK BLU E D Dimensions A 3.750” ±0.063 B 3.936” ±0.125 C D 4.560" MAX 3.000” ±0.063 E G 1 BRN 2.813” ±0.063 0.203 X 0.375 ” ±0.015 TYPICAL TEST CIRCUIT R S/ SECONDARY 2 RL * All graphs input level 27dBu @1.0KHz reference. **The results are typical and are subject to normal manufacturing and electrical tolerances. RED G NOTE: ALL LEADS 9" OUT MIN., STRIPPED .5" PRIMARY Keithley 2010 DVM Hp4192a impedance analyzer A R S/ OUT 2 DISCLAIMER: Hammond Mfg. is not affiliated with Fender Musical Instruments Corp., Marshall Amplification, Yorkville/Traynor, AMPEG or VOX Amplification companies. Amplifier model names are trademarks of the amplifier companies and are just listed here for reference purpose only. www.hammondmfg.com This drawing and the information in it is the property of Hammond Manufacturing. It may not be reproduced, transmitted or used in any manner whatsoever without the written permission of Hammond Manufacturing. Data subject to change without notice. www.hammondmfg.com
1750R 价格&库存
很抱歉,暂时无法提供与“1750R”相匹配的价格&库存,您可以联系我们找货
1750R
    • 1+3327.85800
    • 200+1327.83840
    • 500+1283.47200
    • 1000+1261.54800
