KIT-RMCF0402FT-05
KIT-RMCF0402FT-05
    SEI
    RES KIT 10K-97.6K 1/16W 2880PCS
KIT-RMCF0402FT-05 数据手册
Engineering Kits Stackpole Electronics, Inc. RMCF – Thick Film Chip Resistors Features: • • • • • • • Resistive Product Solutions 20 pieces of each standard value for sizes 0603 and larger 30 pieces of each standard value for 0201 and 0402 sizes 96 values (1 decade) in each 1% tolerance kit 48 values (2 decades) in each 5% tolerance kit Packaged in cut tape RoHS compliant RMCF data specification link Available Kits Quantity Per Value 30 Total Quantity 2880 KIT-RMCF0201FT-02 1% Number of Values 96 KIT-RMCF0201FT-03 1% 96 30 2880 Each E96 value from 100-976 ohm KIT-RMCF0201FT-04 1% 96 30 2880 Each E96 value from 1K-9.76K ohm Stackpole Part Number Tolerance Description Each E96 value from 10-97.6 ohm KIT-RMCF0201FT-05 1% 96 30 2880 Each E96 value from 10K-97.6K ohm KIT-RMCF0201FT-06 1% 96 30 2880 Each E96 value from 100K-976K ohm KIT-RMCF0402FT-02 1% 96 30 2880 Each E96 value from 10-97.6 ohm KIT-RMCF0402FT-03 1% 96 30 2880 Each E96 value from 100-976 ohm KIT-RMCF0402FT-04 1% 96 30 2880 Each E96 value from 1K-9.76K ohm KIT-RMCF0402FT-05 1% 96 30 2880 Each E96 value from 10K-97.6K ohm KIT-RMCF0402FT-06 1% 96 30 2880 Each E96 value from 100K-976K ohm KIT-RMCF0402JT-12 5% 48 30 1440 Each E24 value from 10-910 ohm KIT-RMCF0402JT-13 5% 48 30 1440 Each E24 value from 1K-91K ohm KIT-RMCF0603FT-02 1% 96 20 1920 Each E96 value from 10-97.6 ohm KIT-RMCF0603FT-03 1% 96 20 1920 Each E96 value from 100-976 ohm KIT-RMCF0603FT-04 1% 96 20 1920 Each E96 value from 1K-9.76K ohm KIT-RMCF0603FT-05 1% 96 20 1920 Each E96 value from 10K-97.6K ohm KIT-RMCF0603FT-06 1% 96 5% 48 1920 960 Each E96 value from 100K-976K ohm KIT-RMCF0603JT-12 20 20 KIT-RMCF0603JT-13 5% 5% 48 20 960 KIT-RMCF0603JT-14 48 20 960 KIT-RMCF0805FT-02 1% 96 20 1920 Each E24 value from 10-910 ohm Each E24 value from 1K-91K ohm Each E24 value from 100K-10M ohm (excluding 9.1M) Each E96 value from 10-97.6 ohm KIT-RMCF0805FT-03 1% 96 KIT-RMCF0805FT-04 1% 96 20 20 1920 1920 KIT-RMCF0805FT-05 1% 96 20 1920 Each E96 value from 1K-9.76K ohm Each E96 value from 10K-97.6K ohm KIT-RMCF0805FT-06 1% 5% 96 20 1920 Each E96 value from 100K-976K ohm KIT-RMCF0805JT-12 20 960 Each E24 value from 10-910 ohm KIT-RMCF0805JT-13 5% 48 48 20 960 Each E24 value from 1K-91K ohm Each E96 value from 100-976 ohm KIT-RMCF0805JT-14 5% 48 20 960 KIT-RMCF1206FT-02 KIT-RMCF1206FT-03 1% 1% 96 96 20 1920 Each E24 value from 100K-10M ohm (excluding 9.1M) Each E96 value from 10-97.6 ohm KIT-RMCF1206FT-04 KIT-RMCF1206FT-05 KIT-RMCF1206FT-06 1% 1% 96 96 20 20 20 1920 1920 Each E96 value from 100-976 ohm Each E96 value from 1K-9.76K ohm 1% 5% 5% 5% 96 48 48 48 20 20 20 20 1920 1920 960 960 960 Each E96 value from 10K-97.6K ohm Each E96 value from 100K-976K ohm Each E24 value from 10-910 ohm Each E24 value from 1K-91K ohm Each E24 value from 100K-10M ohm (excluding 9.1M) KIT-RMCF1206JT-12 KIT-RMCF1206JT-13 KIT-RMCF1206JT-14 Rev Date: 07/20/2016 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 1 www.seielect.com marketing@seielect.com
KIT-RMCF0402FT-05
- 物料型号:文档列出了多种型号的电阻器套件,例如KIT-RMCF0201FT-02至KIT-RMCF1206JT-14,涵盖不同的尺寸和公差。 - 器件简介:文档没有提供详细的器件简介,但提到了这些电阻器是厚膜芯片电阻器。 - 引脚分配:文档没有明确说明引脚分配,因为它们是无源元件。 - 参数特性:提供了不同套件的参数特性,包括公差(1%和5%)、电阻值范围、每个值的数量以及总数量。 - 功能详解:文档没有提供功能详解,但可以推断这些电阻器用于电路设计和测试。 - 应用信息:文档没有提供具体的应用信息,但这些套件适用于工程师在设计和测试电路时使用。 - 封装信息:文档列出了不同尺寸的封装,如0201、0402、0603、0805和1206。
KIT-RMCF0402FT-05 价格&库存
很抱歉,暂时无法提供与“KIT-RMCF0402FT-05”相匹配的价格&库存,您可以联系我们找货
