IDC Breakout Helper - 2x3 (6 pin)
PRODUCT ID: 2105
DESCRIPTION
This little 2x3 (6 pin - 0.1 spaced) IDC Breadboard Helper is great in conjunction
with our 6-pin IDC cable. It comes in two parts, a 'pin-through' socket and a male
header. The socket straddles the center of a breadboard or Perma-Proto and then
header plugs into the top of the socket. Since IDC cables are so standard, but a
royal pain to use with breadboards, this is a good and cheap hack for prototyping.
Works best when soldered in place. We have used these to prototype on a
solderless breadboard but some customers report their breadboards don't play nice
with the shorter pins so your mileage may vary
Each order comes with one socket and one header. Breadboard, Perma Proto and
IDC cable not included!
We also have helpers for:
2x20 Pins
2x16 Pins
2x13 Pins
2x8 Pins
2x5 Pins
http://www.adafruit.com/products/2105
11/27/2015
Technical Details
Dimensions (assembled): 8mm x 8mm x 17mm / 0.3" x 0.3" x 0.7"
Dimensions (header): 7mm x 4.5mm x 12mm / 0.3" x 0.2" x 0.5"
Dimensions (socket): 8mm x 8mm x 8mm / 0.3" x 0.3" x 0.3"
Weight (assembled): 0.7g
很抱歉,暂时无法提供与“2105”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+8.371441+1.08307
