2270
2270
    ADAFRUIT
    IDC BREAKOUT HELPER
2270 数据手册
IDC Breakout Helper - 2x20 (40 pin) PRODUCT ID: 2270 DESCRIPTION - The "poor woman's" Raspberry Pi A+ / B+ / Pi 2 cobbler! This combo of 2x20 pin (0.1 spaced) header and socket is for our popular GPIO Ribbon Cable for Raspberry Pi Model A+/B+/Pi 2 (40 pins).  It comes in two parts, a 'pin-through' socket and a male header. The socket straddles the center of a breadboard or Perma-Proto and then header plugs into the top of the socket. Since IDC cables are so standard, but a royal pain to use with breadboards, this is a good and cheap hack for prototyping Works best when soldered in place. We have used these to prototype on a solderless breadboard but some customers report their breadboards don't play nice with the shorter pins so your mileage may vary. Each order comes with one socket and one header. Breadboard, Perma Proto and IDC cable not included! We also have helpers for: • • • • • 2x16 Pins 2x13 Pins 2x8 Pins 2x5 Pins 2x3 Pins http://www.adafruit.com/products/2270 11/27/2015 Technical Details Dimensions (assembled): 51mm x 8mm x 17mm / 2" x 0.3" x 0.7" Dimensions (header): 51mm x 5mm x 12mm / 2" x 0.2" x 0.5" Dimensions (socket): 51mm x 8mm x 8mm / 2" x 0.3" x 0.3" Weight (assembled): 4.5g
很抱歉,暂时无法提供与“2270”相匹配的价格&库存,您可以联系我们找货
    • 1+18.32760
    • 200+7.32240
    • 500+7.07400
    • 1000+6.95520
