56-700-002
56-700-002
    APITECHNOLOGIES
    EMIFILTER
56-700-002 数据手册
D-Subminiature Adapter Test Kit & Hardware Adapter Test Kit Specially designed for EMI evaluation process I I Male/female adapter part Adapter Test Kit Easily plugged into equipment under testing conditions Hardware I Ideal for new products and retrofitting Designed to provide simple and effective mounting I Each adapter test kit includes: Hexagonal Spacer I 20 filtered adapters I Tapped spacer fits between flanges I Four shell sizes 9, 15, 25 and 37 I Provide retrofit of 4-40" threads I Four filter ranges: Series 700 - 310 pF Pi Series 100 - 100 pF - 830 - 470 pF FT I Hexagonal Spacer pF - 1000 pF Pi - 1000 pF - 4000 pF Pi - 5600 pF Filtered Connectors 197 .120 Thru-hole Adapter Ordering Information Description Two spacers per adapter required, packaged in bulk Hexagonal Spacer #4-40 UNC Thru-hole Spectrum Part Number Adapter test kit 56-700-002 Adapter test kit with Jackscrew Includes 40 pcs. 56-201-006 56-700-002-JS Hexagonal Spacer 56-201-001 (1 per) Jackscrew Mounting Hardware For .312" (7.92 mm) length 56-201-004 (1 per) Jackscrew Mounting Hardware For .688" (17.47 mm) length Jackscrew Mounting Hardware I Male/female jackscrews I Standard 4-40 threads for compatibility I Two male thread lengths available 56-201-006 (2 per) I Two screws per adapter required Series 100 adapter test kit 56-100-002 I Lockwasher included, packaged in bulk Tubular Spacer 56-201-003 (1 per) SPECTRUM CONTROL INC. • 8031 Avonia Rd. • Fairview, PA 16415 • Phone: 814-474-2207 • Fax: 814-474-2208 • Web site: www.spectrumcontrol.com SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58
56-700-002
1. 物料型号:文档列出了多种适配器测试套件和硬件的型号,例如: - 适配器测试套件:56-700-002 - 带杰克螺丝的适配器测试套件:56-700-002-JS - 六角垫圈:56-201-001(1个) - 杰克螺丝安装硬件:56-201-004(1个)和56-201-006(2个)
2. 器件简介:适配器测试套件是为电磁干扰(EMI)评估过程特别设计的,包括公/母适配器部件,可在测试条件下轻松插入设备。
3. 引脚分配:文档中没有提供具体的引脚分配信息。
4. 参数特性:适配器测试套件包括四种滤波器范围,分别是: - 系列100:-100pF - -470pF - -1000pF - -5600pF
5. 功能详解:适配器测试套件适用于新产品和改装,硬件设计用于提供简单有效的安装方式。
6. 应用信息:适配器测试套件适用于EMI评估,而硬件部分则提供了4-40"螺纹的改装。
7. 封装信息:文档中没有提供封装信息
56-700-002 价格&库存
很抱歉,暂时无法提供与“56-700-002”相匹配的价格&库存,您可以联系我们找货
