TPI-5010
TPI-5010
    TPI(TPI 公司)
    KIT ADAPTER CABL 7PC W/WALL RACK
TPI-5010 数据手册
Item # TPI-5010 UNIVERSAL ADAPTER CABLE KIT (RG 58) For use with TPI-3000A and TPI-5000A adapter kits • Provides the functionality of an entire set of cables • Creates the cable of your choice using the universal cable and any combination of connectors from the kits noted above • No soldering, no crimping - cable may be used over and over in different combinations • Soft insulation makes cable flexible and easy to handle • Kit includes 6ea. 48” universal cables and wall rack Material: Inner Conductor: Dielectric Core: Specifications: 20AWG (19/0.18mm)Tinned Stranded Copper Wires 0.90mm Nominal O.D. Foamed Polyethylene 2.85 +/- 0.10mm O.D. Shield: Adhesive AL-Mylar Outer Conductor: Single Braid, 37AWG Tinned Copper Wire 3.40mm Nominal O.D. Carriers------------16 Ends ----------------7 Picks / 25.4mm ---8 +/- 10% Coverage -----------90% Jacket: Type II A, Non-Contaminating PVC Impedance: 50W + /- 2.0W Capacitance: 94.8 pF/m Nominal Velocity of Propagation: 70% Nominal Attenuation: See Chart Below db/100ft 0.43 1.4 3.0 4.3 6.1 8.7 11.6 13.2 13.9 MHz 1 10 50 100 200 400 700 900 1000 db/100m 1.4 4.4 9.9 14.0 20.0 28.4 37.9 43.2 45.6 MHz 1 10 50 100 200 400 700 900 1000 Copyright © 2008 Test Products International, Inc.
TPI-5010 价格&库存
很抱歉,暂时无法提供与“TPI-5010”相匹配的价格&库存,您可以联系我们找货
