APHA008GAG0CG-1TM
APHA008GAG0CG-1TM
    APACERMEMORYAMERICA(宇瞻科技)
    USB FLASH DRV 8GB SLC USB2.0/3.0
APHA008GAG0CG-1TM 数据手册
RoHS Compliant USB Flash Drive EH353 Product Specifications February 16, 2015 Version 1.0 Apacer Technology Inc. 1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C Tel: +886-2-2267-8000 www.apacer.com Fax: +886-2-2267-2261 USB Disk Module APHAxxxXAG0XG-1TX FEATURES:   USB3.0 Super Speed compatible, and backward compatible with USB2.0 & interface – USB3.0 max. transfer rate: 5.0 Gbps – Backward compatible with 480Mbps & 12 Mbps  Capacity – SLC: 256, 512 MB 1, 2, 4, 8, 16, 32 GB – MLC: 8, 16, 32, 64 GB  Performance* – Sustained read: up to 205 MB/s – Sustained write: up to 85 MB/s  – – Temperature ranges Operating: Standard: 0°C to 70°C Extended: -40°C to +85°C C – Storage: -40°C to +85°C –  – – – Intelligent USB Module Built-in hardware ECC Power saving implemented Power consumption (typical)* Active mode: 225 mA Idle mode: 65 mA Operating voltage: 5V  RoHS Compliant  USB bus-powered capability  NAND Flash Type: SLC/MLC  Dimension: 59.0 x 18.4 x 9.1, unit: ㎜ *Performance and power consumption addressed here vary from configurations and platforms. 1 © 2015 Apacer Technology, Inc. Rev. 1.0 USB Disk Module APHAxxxXAG0XG-1TX Table of Contents 1. General Description............................................................. 3 1.1 Performance-optimized USB Controller .............................................................................................. 3 1.1.1 Power Saving Implemented .......................................................................................................... 3 1.1.2 Program RAM Architect ................................................................................................................ 3 1.1.3 Error Correction Code (ECC) ........................................................................................................ 3 2. General Specifications ........................................................ 4 2.1 SLC ...................................................................................................................................................... 4 2.2 MLC ..................................................................................................................................................... 4 3. Absolute Maximum Rating .................................................. 5 4. Physical Dimensions ........................................................... 6 5. Product Ordering Information ............................................. 7 5.1 Product Code Designations ................................................................................................................. 7 5.2 Valid Combinations .............................................................................................................................. 8 5.2.1 EH353 (SLC)................................................................................................................................. 8 5.2.2 EH353 (MLC) ................................................................................................................................ 8 2 © 2015 Apacer Technology, Inc. Rev. 1.0 USB Disk Module APHAxxxXAG0XG-1TX 1. General Description Apacer USB3.0 Handy FLASH Drive EH353 is ultra high-performance flash disk drive designed offering portable storage solutions or external memory expansion. This new generation USB flash drive is compatible with the latest USB specification – USB3.0 Super Speed, with a maximum transfer rate of 5.0 Gbps. The connector is backward employable with USB2.0 and USB1.1 interfaces as well. With compliance with USB3.0 specification, this USB drive can deliver up to 205 MB/s outstanding performance. Reliability wise, the USB comes with built-in hardware ECC to ensure data integrity. This product is well suited for portable flash storage applications while operating at minimal power consumption. 1.1 Performance-optimized USB Controller 1.1.1 Power Saving Implemented The internal controller of the USB model is designed with power saving implementations, allowing the device to operate at low power consumption. 1.1.2 Program RAM Architect The internal Program RAM implementation allows the host to upgrade firmware codes anytime when needed. 1.1.3 Error Correction Code (ECC) The UFD utilizes 1-bit Error Detection Code (EDC) and Error Correction Code (ECC) 3 © 2015 Apacer Technology, Inc. Rev. 1.0 USB Disk Module APHAxxxXAG0XG-1TX 2. General Specifications 2.1 SLC Interface Performance* (MB/s) Temperature Power consumption* MTBF Super-speed USB3.0 compliant; backward compatible with USB 2.0 and USB 1.1 256MB Read (MB/s) Write (MB/s) 0 to 70°C ; Active: 225 mA Idle: 65 mA 1,000,000 hours 512MB 1GB 2GB 4GB 8GB 16GB 32GB 60 21 65 40 65 40 65 50 80 65 80 70 80 70 60 10 *Results may vary from flash configurations or host system settings. 2.2 MLC Interface Performance* Temperature Power consumption* MTBF Super-speed USB3.0 compliant; backward compatible with USB 2.0 and USB 1.1 8GB 16GB 32GB 64GB Read (MB/s) 205 200 205 200 Write (MB/s) 20 45 85 80 0 to 70°C Active: 265 mA Idle: 70 mA 1,000,000 hours *Results may vary from flash configurations or host system settings. 4 © 2015 Apacer Technology, Inc. Rev. 1.0 USB Disk Module APHAxxxXAG0XG-1TX 3. Absolute Maximum Rating Caution: Absolute Maximum Stress Ratings – Applied conditions greater than those listed under “Absolute Maximum Stress Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these conditions or conditions greater than those defined in the operational sections of this data sheet is not implied. Exposure to absolute maximum stress rating conditions may affect device reliability. Table: Absolute Stress Rating Parameters Conditions Required power supply Operating temperature 4.5-5.5V 0℃ to 70℃; -40°C to +85°C(extended) Storage temperature -40℃ to +85℃ 5 © 2015 Apacer Technology, Inc. Rev. 1.0 USB Disk Module APHAxxxXAG0XG-1TX 4. Physical Dimensions Unit: mm 6 © 2015 Apacer Technology, Inc. Rev. 1.0 USB Disk Module APHAxxxXAG0XG-1TX 5. Product Ordering Information 5.1 Product Code Designations AP HA xxxX A G 0 X – G X XX Flash Type: T: Toshiba SLC TM: Toshiba MLC Version Control G: RoHS Compliant Temperature: C: Standard Temperature E: Extended Temperature PCB version Model Name G= EH353 Solution version Capacities: 256M = 512M = 001G = 002G = 004G = 008G = 016G = 032G = 064G = 256MB 512MB 1GB 2GB 4GB 8GB 16GB 32GB 64GB Handy Apacer Product Code 7 © 2015 Apacer Technology, Inc. Rev. 1.0 USB Disk Module APHAxxxXAG0XG-1TX 5.2 Valid Combinations 5.2.1 EH353 (SLC) Capacity Standard Extended 256 MB APHA256MAG0CG-1T APHA256MAG0EG-1T 512 MB APHA512MAG0CG-1T APHA512MAG0EG-1T 1 GB APHA001GAG0CG-1T APHA001GAG0EG-1T 2 GB APHA002GAG0CG-1T APHA002GAG0EG-1T 4 GB APHA004GAG0CG-1T APHA004GAG0EG-1T 8 GB APHA008GAG0CG-1T APHA008GAG0EG-1T 16 GB APHA016GAG0CG-1T APHA016GAG0EG-1T 32 GB APHA032GAG0CG-1T APHA032GAG0EG-1T 5.2.2 EH353 (MLC) Capacity Standard Extended 8GB APHA008GAG0CG-1TM APHA008GAG0EG-1TM 16GB APHA016GAG0CG-1TM APHA016GAG0EG-1TM 32GB APHA032GAG0CG-1TM APHA032GAG0EG-1TM 64GB APHA064GAG0CG-1TM APHA064GAG0EG-1TM 8 © 2015 Apacer Technology, Inc. Rev. 1.0 USB Disk Module APHAxxxXAG0XG-1TX Revision History Revision 1.0 Description Date Official Release 2/16/2015 9 © 2015 Apacer Technology, Inc. Rev. 1.0 USB Disk Module APHAxxxXAG0XG-1TX Global Presence Taiwan (Headquarters) Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: 886-2-2267-8000 Fax: 886-2-2267-2261 amtsales@apacer.com U.S.A. Apacer Memory America, Inc. 386 Fairview Way, Suite102, Milpitas, CA 95035 Tel: 1-408-586-1291 Fax: 1-408-935-9611 sa@apacerus.com Japan Apacer Technology Corp. 5F, Matsura Bldg., Shiba, Minato-Ku Tokyo, 105-0014, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Europe Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-267-0000#6199 sales@apacer.nl China Apacer Electronic (Shanghai) Co., Ltd 1301, No.251,Xiaomuqiao Road, Shanghai, 200032, China Tel: 86-21-5529-0222 Fax: 86-21-5206-6939 sales@apacer.com.cn India Apacer Technologies Pvt. Ltd. #143, 1st Floor, Raheja Arcade, 5th Block Kormangala Industrial Layout, Bangalore - 560095, India Tel: 91-80-4152-9061 sales_india@apacer.com 10 © 2015 Apacer Technology, Inc. Rev. 1.0
APHA008GAG0CG-1TM 价格&库存
很抱歉,暂时无法提供与“APHA008GAG0CG-1TM”相匹配的价格&库存,您可以联系我们找货
