APHA016G2BACG-BTM-DK
    APACERMEMORYAMERICA(宇瞻科技)
    USB FLASH DRIVE 16GB SLC USB 2.0
APHA016G2BACG-BTM-DK 数据手册
RoHS Compliant Commercial USB Flash Drive AH162-A Product Specification February 11, 2015 Version 1.2 Apacer Technology Inc. 1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C Tel: +886-2-2267-8000 www.apacer.com Fax: +886-2-2267-2261 USB Flash Drive APHAxxxx2BACG-XXX Table of Contents 1. 2. 3. 4. 5. 6. 7. General Descriptions ............................................................... 2 Features ................................................................................... 2 Performance............................................................................. 3 Power consumption ................................................................. 3 Operating Range ...................................................................... 4 Dimensions............................................................................... 4 Product Ordering Information ................................................. 5 7.1 Product Code Designations.......................................................................................... 5 7.2 Valid Combinations ...................................................................................................... 6 7.2.1 AH162-A (SLC) .................................................................................................. 6 7.2.2 AH162-A (MLC) .................................................................................................. 6 © 2015 Apacer Technology, Inc. Rev. 1.2 1 USB Flash Drive APHAxxxx2BACG-XXX 1. General Descriptions Apacer AH162-A is a removable flash disk drive with USB interface and capabilities of supporting various storage capacities. Compatible with both USB 1.1 and 2.0 specifications with its plug-and-play nature, AH162-A is can be easily adopted in any computing system with an available USB port. The device can be automatically detected by the host computer so that users can access data to read, write, copy, or move data between host system drive and AH162-A. No battery, cable, or software driver is required, AH162-A is widely compatible with mainstream computer platforms, no matter desktop or laptops, as long as there is an available USB port. AH162-A makes data transfer easy, fast and handy. 2. Features  Compatible with USB 1.1 and 2.0 specifications  Capacity: SLC – 2, 4 GB MLC – 4, 8, 16 GB  Operating system support:  Windows: 2000 SP4, XP, Vista, and 7. (note: no device driver is necessary for Windows starting from XP).  Mac OS 8.1 or later (for USB 1.1 interface speed)  Mac OS X 10.2.8 or later (for USB 2.0 interface speed)  Linux Kernel: version 2.4.0 or above (for USB 1.1 interface speed)  Linux Kernel: version 2.4.10 or above (for USB 2.0 interface speed)  Plug & Play  Data retention up to 10 years  Operating voltage: DC 4.5 ~ 5.5V from USB port (no external power is required)  Interface transfer rate:  High speed: up to 480Mbits/sec for USB 2.0  Full speed: up to 12Mbits/sec for USB 1.1  Low power consumption  Altitude: 80,000 feet (relative to sea level)  Acoustic noise: 0 dB (at one meter)  Vibration: 15G peak to peak (max)  Operating temperature: 0-70℃  Humidity: 20% to 90% © 2015 Apacer Technology, Inc. Rev. 1.2 2 USB Flash Drive APHAxxxx2BACG-XXX 3. Performance Table 3-1 Performance (SLC) Capacity 2 GB 4 GB Sustained read (MB/s) 22 24 Sustained write (MB/s) 19 21 Performance Table 3-2 Performance (MLC) Capacity 4 GB 8 GB 16 GB Sustained read (MB/s) 26 26 26 Sustained write (MB/s) 10 10 10 Performance Note: Results may differ from various flash configurations or host system setting 4. Power consumption Table 4-1: Typical power consumption (SLC) Capacity 2 GB 4 GB Active (mA) 75 70 Idle (mA) 40 40 Modes Table4-2: Typical power consumption (MLC) Capacity 4 GB 8 GB 16 GB Active (mA) 70 70 80 Idle (mA) 40 40 40 Modes Note: Results may differ from various flash configurations or host system setting © 2015 Apacer Technology, Inc. Rev. 1.2 3 USB Flash Drive APHAxxxx2BACG-XXX 5. Operating Range Items Range Supply Voltage 5.0V±10% (4.5-5.5V) Operating temperature 0°C to +70°C Storage temperature -25°C to +85°C 6. Dimensions Unit: ㎜ Tolerance: ± 0.2 © 2015 Apacer Technology, Inc. Rev. 1.2 4 USB Flash Drive APHAxxxx2BACG-XXX 7. Product Ordering Information 7.1 Product Code Designations AP HA xxxx 2 B A C G – X XX Flash Type: TM: Toshiba MLC T: Toshiba SLC Version Control G: RoHS Compliant Temperature: C: Commercial Temperature PCB version Model Name B = AH162-A Solution version Capacities: 002G = 2GB 004G = 4GB 008G = 8GB 016G = 16GB Handy Apacer Product Code © 2015 Apacer Technology, Inc. Rev. 1.2 5 USB Flash Drive APHAxxxx2BACG-XXX 7.2 Valid Combinations 7.2.1 AH162-A (SLC) Capacity Standard 2 GB APHA002G2BACG-CT 4 GB APHA004G2BACG-CT 7.2.2 AH162-A (MLC) Capacity Standard 4 GB APHA004G2BACG-BTM 8 GB APHA008G2BACG-BTM 16 GB APHA016G2BACG-BTM © 2015 Apacer Technology, Inc. Rev. 1.2 6 USB Flash Drive APHAxxxx2BACG-XXX Revision History Revision Date Description Remark 1.0 11/04/2014 Official release 1.1 11/06/2014 Revised the label photo of cover page 1.2 02/11/2015 Added 4 GB SLG information © 2015 Apacer Technology, Inc. Rev. 1.2 7 USB Flash Drive APHAxxxx2BACG-XXX Global Presence Taiwan (Headquarters) Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: 886-2-2267-8000 Fax: 886-2-2267-2261 amtsales@apacer.com U.S.A. Apacer Memory America, Inc. 386 Fairview Way, Suite102, Milpitas, CA 95035 Tel: 1-408-518-8699 Fax: 1-408-935-9611 sa@apacerus.com Japan Apacer Technology Corp. 5F, Matsura Bldg., Shiba, Minato-Ku Tokyo, 105-0014, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Europe Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-267-0000#6199 sales@apacer.nl China Apacer Electronic (Shanghai) Co., Ltd 1301, No.251,Xiaomuqiao Road, Shanghai, 200032, China Tel: 86-21-5529-0222 Fax: 86-21-5206-6939 sales@apacer.com.cn India Apacer Technologies Pvt Ltd, # 535, 1st Floor, 8th cross, JP Nagar 3rd Phase, Bangalore – 560078, India Tel: 91-80-4152-9061 sales_india@apacer.com © 2015 Apacer Technology, Inc. Rev. 1.2 8
APHA016G2BACG-BTM-DK 价格&库存
很抱歉,暂时无法提供与“APHA016G2BACG-BTM-DK”相匹配的价格&库存,您可以联系我们找货
