APHA016GR13CG-2T
APHA016GR13CG-2T
    APACERMEMORYAMERICA(宇瞻科技)
    USB FLASH DRIVE 16GB SLC USB 2.0
APHA016GR13CG-2T 数据手册
RoHS Compliant USB Flash Drive AH321 Specifications November 26, 2015 Version 1.9 Apacer Technology Inc. 1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C Tel: +886-2-2267-8000 www.apacer.com http://www.apacer.com http://www.apacer.com Fax: +886-2-2267-2261 USB Handy Flash Drive AP-HAxxxXX13XG-XX FEATURES:    USB2.0 High-Speed and USB1.1 FullSpeed compatible interface Capacity For SLC: 128, 256, 512 MB 1, 2, 4, 8, 16, 32 GB – For MLC: 4, 8, 16, 32, 64 GB –  – –  Temperature Ranges Operating: Standard: 0°C to 70°C Extended: -40°C to 85°C – Storage: -40°C to 85°C –  – – – Performance* Sustained read: up to 34 MB/s Sustained write: up to 22 MB/s Flash Management – Implements advanced wear-leveling algorithms to substantially increase longevity of flash media – ECC Power Consumption (typical) Active mode: 185 mA Idle mode: 65 mA Operating voltage: 5V  RoHS Compliant  Dimensions: 53.30 x 18.80 x 8.00, unit: ㎜  EMC: FCC, CE * The results for performance and power consumption addressed here may vary in real world platforms. 1 © 2015 Apacer Technology, Inc. Rev. 1.9 USB Handy Flash Drive AP-HAxxxXX13XG-XX Table of Contents 1. General Description .............................................................................. 3 1.1 Performance-optimized USB Controller .............................................................................................. 3 1.1.1 Error Correction Code (ECC) ........................................................................................................ 3 1.1.2 Wear-Leveling ............................................................................................................................... 3 2. General Specifications.......................................................................... 4 2.1 Performance Specifications – SLC ...................................................................................................... 4 2.2 Performance Specifications – MLC ..................................................................................................... 4 3. Electrical Specifications ...................................................................... 5 4. Physical Dimensions ............................................................................. 6 5. Product Ordering Information ............................................................... 7 5.1 Product Code Designations ................................................................................................................. 7 5.2 Valid Combinations .............................................................................................................................. 8 5.2.1 AH322 (SLC)................................................................................................................................. 8 5.2.2 AH322 (MLC) ................................................................................................................................ 8 2 © 2015 Apacer Technology, Inc. Rev. 1.9 USB Handy Flash Drive AP-HAxxxXX13XG-XX 1. General Description Apacer’s USB FLASH Drive (UFD) is a high performance flash disk drive designed offering portable storage solutions. UFDs can be plugged into a standard USB 2.0 connector commonly found in desktops, portable computers and even enterprise PC systems. Apacer’s UFDs have an efficient built-in microcontroller and file management firmware that ensures ideal performance, functionality and reliability. This product is well suited for portable flash storage applications while operating at minimal power consumption. 1.1 Performance-optimized USB Controller The heart of an UDM is the USB controller, which translates standard USB signals to the flash media and controls the data in/out between the controller itself and the flash media. This proprietary USB controller is specifically designed to attain high data throughput from host to flash. 1.1.1 Error Correction Code (ECC) The UDM uses BCH Error Detection Code (EDC) and Error Correction Code (ECC) algorithms which correct up to 24 random single-bit errors for each 1024-byte block of data. 1.1.2 Wear-Leveling Flash memory can be erased a limited number of times. In a typical application, and especially if a file system is used, specific pages are constantly updated (e.g., the page that contains the FAT, registry, etc.). Without any special handling, these pages would wear out more rapidly than other pages, reducing the lifetime of the entire flash. To overcome this inherent deficiency, Apacer’s USB-Disk Module (UDM) uses wear-leveling algorithm. This wear-leveling algorithm ensures that consecutive writes of a specific sector are not written physically to the same page in the flash. This distributes flash media usage evenly across all pages, thereby maximizing flash lifetime. The wear-leveling mechanism provides write/erase cycles for reliable data storage over an extended period. 3 © 2015 Apacer Technology, Inc. Rev. 1.9 USB Handy Flash Drive AP-HAxxxXX13XG-XX 2. General Specifications Interface Performance* High-speed USB2.0 compliant; backward compatible with USB 1.1 SLC: up to 34 MB/s (read); 22 MB/s (write) MLC: up to 33 MB/s (read); 16 MB/s (write) 0 to 70°C Half sine wave 40 G, 11ms / Square wave 100 G, 6ms FCC, CE 2,000,000 hours (SLC) / 1,000,000 (MLC) Temperature Shock EMC MTBF *Results may vary from flash configurations or host system settings. 2.1 Performance Specifications – SLC Capacity Performance Sustained read (MB/s) Sustained write (MB/s) 256 MB 512 MB 1 GB 2 GB 4 GB 8 GB 16 GB 32 GB 31 10 31 15 32 19 34 19 28 21 32 15 34 22 31 21 Note: results may vary depending on flash configurations or host system settings 2.2 Performance Specifications – MLC Capacity Performance Sustained read (MB/s) Sustained write (MB/s) 4 GB 8 GB 16 GB 32 GB 64 GB 32 10 32 10 33 14 33 16 29 10 Note: results may vary depending on flash configurations or host system settings 4 © 2015 Apacer Technology, Inc. Rev. 1.9 USB Handy Flash Drive AP-HAxxxXX13XG-XX 3. Electrical Specifications Caution: Absolute Maximum Stress Ratings – Applied conditions greater than those listed under “Absolute Maximum Stress Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these conditions or conditions greater than those defined in the operational sections of this data sheet is not implied. Exposure to absolute maximum stress rating conditions may affect device reliability. Table: Absolute Stress Rating Parameters Ambient temperature Storage temperature Required power supply Input power (VDD ) Voltage on any pin except VDD with respect to GND Conditions 0 to 70°C -40 to 85°C 4.5-5.5V -0.3V (min.) to 5.5V (max.) -0.3V (min.) to VDD + 0.3V (max.) 5 © 2015 Apacer Technology, Inc. Rev. 1.9 USB Handy Flash Drive AP-HAxxxXX13XG-XX 4. Physical Dimensions 6 © 2015 Apacer Technology, Inc. Rev. 1.9 USB Handy Flash Drive AP-HAxxxXX13XG-XX 5. Product Ordering Information 5.1 Product Code Designations AP HA xxxx X X 3 X G – XX Flash Type S: Samsung SLC T: Toshiba SLC C: Micron SLC CM: Micron MLC G: RoHS Compliant Temperature C: Commercial Temperature E: Extended Temperature PCB version Model Name 1 = AH321 2 = AH322 Solution version Capacities 128M = 128MB 256M = 256MB 512M = 512MB 001G = 1GB 002G = 2GB 004G = 4GB 008G = 8GB 016G = 16GB 032G = 32GB 064G = 64GB Handy Apacer Product Code 7 © 2015 Apacer Technology, Inc. Rev. 1.9 USB Handy Flash Drive AP-HAxxxXX13XG-XX 5.2 Valid Combinations 5.2.1 AH322 (SLC) Capacity 128 MB 256 MB 512 MB 1 GB 2 GB 4 GB 8 GB 16 GB 32 GB 5.2.2 AH322 (MLC) Capacity 4 GB 8 GB 16 GB 32 GB 64 GB Standard APHA128MR13CG-2T APHA256MR13CG-2T APHA512MR13CG-2T APHA001GR13CG-2T APHA002GR13CG-2T APHA004GR13CG-2T APHA008GR13CG-2T APHA016GR13CG-2T APHA032GR13CG-2T Standard APHA004GR13CG-CM APHA008GR13CG-CM APHA016GR13CG-CM APHA032GR13CG-CM APHA064GR13CG-CM Extended APHA128MT13EG-2T APHA256MT13EG-2T APHA512MT13EG-2T APHA001GT13EG-2T APHA002GT13EG-2T APHA004GT13EG-2T APHA008GT13EG-2T APHA016GT13EG-2T APHA032GT13EG-2T Extended APHA004GT13EG-CM APHA008GT13EG-CM APHA016GT13EG-CM APHA032GT13EG-CM APHA064GT13EG-CM 8 © 2015 Apacer Technology, Inc. Rev. 1.9 USB Handy Flash Drive AP-HAxxxXX13XG-XX Revision History Revision Description Date 1.0 Official Release August 11 , 2011 1.1 Updated Product Ordering Information June 20 , 2012 1.2 1.3 th Updated Product Ordering Information - contents relating to extended temperature are removed Updated read/write performance due to change in NAND flash use Updated addresses of Taiwan headquarter and the office in India th nd July 2 , 2012 th July 30 , 2013 th 1.4 Added performance tables June 4 , 2014 1.5 Added SLC extended temperature models October 17 , 2014 1.6 Updated Product Ordering Information November 17 , 2014 1.7 Updated Product Ordering Information February 17 , 2015 1.8 Added storage temperature November 11 , 2015 1.9 Added 64GB support November 26 , 2015 th th th th th 9 © 2015 Apacer Technology, Inc. Rev. 1.9 USB Handy Flash Drive AP-HAxxxXX13XG-XX Global Presence Taiwan (Headquarters) Apacer Technology Inc. Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: 886-2-2267-8000 Fax: 886-2-2267-2261 amtsales@apacer.com U.S.A. Apacer Memory America, Inc. 46732 Lakeview Blvd., Fremont, CA 94538 Tel: 1-408-518-8699 Fax: 1-510-249-9568 sa@apacerus.com Japan Apacer Technology Corp. 5F, Matsura Bldg., Shiba, Minato-Ku Tokyo, 105-0014, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Europe Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-267-0000#6199 sales@apacer.nl China Apacer Electronic (Shanghai) Co., Ltd Room D, 22/FL, No.2, Lane 600, JieyunPlaza, Tianshan RD, Shanghai, 200051, China Tel: 86-21-6228-9939 Fax: 86-21-6228-9936 sales@apacer.com.cn India Apacer Technologies Pvt Ltd, th Unit No.201, “Brigade Corner”, 7 Block Jayanagar, Yediyur Circle, Bangalore – 560082, India Tel: 91-80-4152-9061 Fax: 91-80-4170-0215 sales_india@apacer.com 10 © 2015 Apacer Technology, Inc. Rev. 1.9
APHA016GR13CG-2T 价格&库存
很抱歉,暂时无法提供与“APHA016GR13CG-2T”相匹配的价格&库存,您可以联系我们找货
