SFSA8192V1BR4TO-I-DT-236-STD
    SWISSBIT
    Solid State Drive (SSD) 8GB SATA II FLASH - NAND (SLC) Slim-SATA 5V
SFSA8192V1BR4TO-I-DT-236-STD 数据手册
Product fact sheet Industrial SLIM SATA SSD MO-297A X-200s Series SATA II - 3.0Gb/s up to UDMA6 / MDMA2 / PIO4 BU: Swissbit Grou p Da t e: 15 Febru a ry 2011 Rev ision : 0.8 0 preli mina ry X- 200s_fa ct _sheet _SA - VxBR_Rev 08 0.doc Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Swissbit reserves the right to change products or specifications without notice. www.swissbit.com info@swissbit.com Revision: 0.80 X-200s_fact_sheet_SA-VxBR_Rev080.doc Page 1 of 4 X-200s Solid State Drive Industrial SLIM SATA SSD (MO-297A) 2GByte up to 32GByte Feature summary Form factor: o Jedec MO-297A sized Solid State Drive (SSD) o 54mm x 39mm x 4mm Interface: o SATA Rev 2.6 - 3Gbit/s (1.5Gbit/s compatible) o 7+15pin (SATA+power) o standard 2.5” SATA-connector Highly-integrated memory controller o max. UDMA6 supported o max. PIO mode 4, MDMA2 supported o SLC Nand Flash o Hardware BCH-code ECC (8 Bit correction per sector for SLC) o fix drive configuration Low-power CMOS technology 5V ± 10% power supply optional 3.3V± 5% power supply Low Power, less than 500mA No mechanical noise Activity LED output (P11) (optional can be NC on the module) Wear Leveling: active wear leveling of static and dynamic data The wear leveling assures that dynamic data as well as static data is balanced evenly across the memory. With that the maximum write endurance of the device is guaranteed. Write endurance: Due to intelligent wear leveling an even use of the entire flash is guaranteed, regardless how much “static” (OS) data is stored. Example: If the average file size is 10MByte and the total capacity is 8GByte, 80Mio write cycles can be performed. Data Retention: 10 years @ 10% life time High reliability o MTBF > 2,500,000 hours o Data reliability: < 1 non-recoverable error per 1014 bits read High performance o Up to 300MB/s burst transfer rate in SATA II - 3.0Gb/sec o Sustained Write performance: up to 90MB/s o Sustained Read Performance: up to 105MB/s Available densities o 4GByte up to 32GByte (SLC NAND Flash) Temperature ranges o Commercial Temperature range 0 … +70°C o Industrial Temperature range -40 … +85°C Controlled BOM RoHS compatible Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Swissbit reserves the right to change products or specifications without notice. www.swissbit.com info@swissbit.com Revision: 0.80 X-200s_fact_sheet_SA-VxBR_Rev080.doc Page 2 of 4 Pinout The SLIM SATA connector is a standard SATA 7+15pin connector. Pin S1 S2 S3 S4 S5 S6 S7 Assignment GND A+ AGND BB+ GND Description Signal ground + SATA differential receive signal - SATA differential receive signal Signal ground - SATA differential transmit signal + SATA differential transmit signal Signal ground P1-P3 P4-P6 P7-P9 P10 P11 P12 P13-P15 +3.3V GND +5V GND DA GND +12V Optional 3.3V power supply *) Power Ground Standard 5V power supply *) Power Ground Device activity / LED (optional) **) Power Ground No Connect *) Standard modules have only 5V power supply optional the modules can be ordered with 3.3V supply **) Device Activity Pin is low in idle mode and high (flickering) during data transfer. It can be optional disconnected on the module on request. Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Swissbit reserves the right to change products or specifications without notice. www.swissbit.com info@swissbit.com Revision: 0.80 X-200s_fact_sheet_SA-VxBR_Rev080.doc Page 3 of 4 Table 1: System Performance System Performance Data transfer Rate (sATA burst) Sustained Read (max. measured) Sustained Write (max. measured) 1. 2. 4GB 3.0 (1.5) 115 45 8…32GB 3.0 (1.5) 110 90 Unit Gbit/s MB/s All values refer to modules with 4x Toshiba Flash in UDMA mode 5, SATA 3.0Gbit/s, write/read data sequential 256 Sectors/Transfer command. Sustained speed depends on flash type and number, file size, and burst speed Table 2: Current consumption(1) at 5V ± 10% Current Consumption Write (UDMA6) Read (UDMA6) Standby 1. typical 350 250 125 max 400 350 140 Unit mA All values are typical at 25° C and nominal supply voltage and refer to 16GByte SSD module. Table 3: Environmental Specifications Environmental Specifications Temperature (commercial) Temperature (industrial) Humidity (non-condensing) Vibration (peak -to-peak) Shock Operating Non Operating 0 to 70°C -40 to 85°C -40 to 85°C -50 to 95°C 85% RH, at 85°C max. 95% RH, at 85°C 20G Peak, 10…2000Hz 1500G, 0.5ms duration, half sine wave Table 4: Physical Dimensions Physical Dimensions Unit Width Height Thickness max. Weight (typ.) 54.0 39.8 (with connector) 4 (connector) 10 mm g Table 5: SSD capacity specification Capacity Default_cylinders Default_heads 4GB 8GB 16GB 32GB 7,814 15,628 16,383*) 16,383*) 16 16 16 16 Default_sectors _track 63 63 63 63 Sectors_drive 7,876,512 15,753,024 31,506,432 62,586,880 Total addressable capacity (Byte) 4,032,774,144 8,065,548,288 16,131,293,184 32,044,482,560 *) The CHS addressing is limited to about 8GB. Larger drives should be used in LBA mode. Table 6: System Reliability and Maintenance MTBF (at 25°C) Data Reliability > 2,500,000 hours 14 < 1 Non-Recoverable Error per 10 bits Read (1) Dependent on final system qualification data. For more information on MO-297A mechanical standard, please visit JEDEC at www.jedec.org. For more information on Serial ATA Revision 2.6, please visit Serial ATA International Organization at www.serialata.org Why Swissbit? Swissbit strives to create innovative technologies for future market opportunities utilizing a highly skilled in-house product research and development team. Swissbit maintains a marketing edge by continuing to manufacture world-class high quality memory products and providing customers with both high value and low cost of ownership achieved through efficient processes and procedures. Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Swissbit reserves the right to change products or specifications without notice. www.swissbit.com info@swissbit.com Revision: 0.80 X-200s_fact_sheet_SA-VxBR_Rev080.doc Page 4 of 4
SFSA8192V1BR4TO-I-DT-236-STD 价格&库存
很抱歉,暂时无法提供与“SFSA8192V1BR4TO-I-DT-236-STD”相匹配的价格&库存,您可以联系我们找货
