SFSA128GU1AA4TO-I-NC-216-STD
    SWISSBIT
    Solid State Drive (SSD) 128GB SATA III FLASH - NAND (SLC) mSATA 3.3V
SFSA128GU1AA4TO-I-NC-216-STD 数据手册
Product Fact Sheet Industrial mSATA SSD (MO-300 Full size) X-600m Series SATA Gen3 – 6.0 Gbits/s, SLC Commercial and Industrial Temperature Grade Date : Re vi si o n: N ove m be r 0 9 , 2 0 2 1 1 .0 9 Product Fact Sheet X-600m Series Product Summary         Capacities: 4 GBytes, 8 GBytes, 16 GBytes, 32 GBytes, 64 GBytes, 128GBytes Form Factor: JEDEC MO-300 Full Size mSATA SSD (50.8 mm x 29.85 mm x 3.5 mm) Compliance1: SATA Gen3 - 6 Gbit/s (Gen2 - 3 Gbit/s and Gen1 - 1.5 Gbit/s backward compatible) Command Sets: Supports ATA/ATAPI-8 and ACS-2 (2011/06/22) Performance: o Read Performance: Sequential Read up to 520 MBytes/s, Random Read 4K up to 76,000 IOPS o Write Performance: Sequential Write up to 405 MBytes/s, Random Write 4K up to 73,000 IOPS Operating Temperature Range2: o Commercial: 0 °C to 70 °C o Industrial: -40 °C to 85 °C Storage Temperature Range: -40 °C to 85 °C Operating Voltage: 3.3 V ± 5% Power (Max Capacity): Read (Active): 1.7 W; Write (Active): 2.5 W; Idle: 380 mW; Slumber: 115 mW  Data Retention: 10 Years @ Life Begin; 1 Year @ Life End  Endurance in TeraBytes Written (TBW) Max Capacity3: Client ≥ 7,715; Embedded ≥ 2,500; Enterprise > 1,115  Shock/Vibration: 1,500 g / 50 g  Hardware BCH Code ECC: up to 66 bit correction per 1 KByte page  Mean Time Between Failure (MTBF): > 2,000,000 hours  Data Reliability: < 1 non-recoverable error per 1016 bits read  Product Features  Dynamic and Static Wear Leveling  Subpage Mode Flash Translation Layer (FTL)  Active and Passive Data Care Management   Lifetime Enhancements o Dynamic Bad Block Remapping o Write Amplification Reduction On-Board Power Fail Protection  AHCI, TRIM, and NCQ Support  ATA Security Feature Set Support  DEVSLP Compatible  In-Field Firmware Update4  Enterprise-Grade Self-Monitoring, Analysis, and Reporting Technology (S.M.A.R.T.)  30 µinch Gold-Plated Connector (IPC-6012B Class 2 Compliant)  AES256 Encryption (on request)  Swissbit Life Time Monitoring (SBLTM) Tool and SDK for SBLTM (on request) Why Swissbit? Swissbit is focused on the design, development, manufacture, and support of leading edge memory and storage solutions for the worldwide OEM/ODM marketplace. As a global supplier, Swissbit recognizes and addressees the higher level of application requirements of today’s industrial, Netcom, and automotive customers by providing best-in-class products and services, with uncompromised attention to driving overall value and quality. 1 The verification of host system and storage device compatibility is in customer’s responsibility. Swissbit can provide guidance and support on request. 2 Adequate airflow is required to ensure the temperature, as reported in the S.M.A.R.T. data, does not exceed 115°C (industrial temperature drive) and 100°C (commercial temperature drive) respectively. 3 According to JEDEC (JESD47I), the time to write the full TBW is a minimum of 18 months. Higher average daily data volume reduces the specified TBW. The values listed are estimates and are subject to change without notice. 4 The support of In-Field FW update capabilities on host systems is recommended. Swissbit AG Revision: 1.09 Industriestrasse 4 TLP: Swissbit public Template: Doc-4991 CH-9552 Bronschhofen File: X-600m_fact_sheet_Rev109 Switzerland www.swissbit.com/contact Page 2 of 2
物料型号:swissbit X-600m系列
器件简介:该系列SSD是工业级存储解决方案,支持SATA Gen3 - 6 Gbit/s,兼容Gen2和Gen1。提供多种容量选择,从4GB到128GB。
引脚分配:遵循JEDEC MO-300全尺寸mSATA SSD标准,尺寸为50.8 mm x 29.85 mm x 3.5 mm。
参数特性: - 顺序读取速度高达520MB/s,随机4K读取IOPS高达76,000。 - 顺序写入速度高达405MB/s,随机4K写入IOPS高达73,000。 - 工作温度范围:商业级0°C至70°C,工业级-40°C至85°C。 - 存储温度范围:-40°C至85°C。 - 工作电压:3.3V ± 5%。 - 最大功耗:读取/写入时分别为1.7W/2.5W,空闲时380mW,休眠时115mW。 - 数据保持:从开始使用10年,寿命末期1年。 - 耐久性:根据容量不同,TBW(写入的TeraBytes)不同,客户端级≥7,715,嵌入式≥2,500,企业级>1,115。
功能详解: - 动态和静态磨损平衡。 - 子页模式闪存转换层(FTL)。 - 主动和被动数据护理管理。 - 寿命增强技术,包括动态坏块重映射和写入放大减少。 - 板载电源故障保护。 - 支持AHCI、TRIM和NCQ。 - 支持ATA安全特性集。 - DEVSLP兼容。 - 支持现场固件更新。 - 企业级自我监控、分析和报告技术(S.M.A.R.T.)。 - 30微英寸镀金连接器,符合IPC-6012B Class 2标准。 - 可选AES256加密。 - 可选Swissbit生命周期监控(SBLTM)工具和SDK。
应用信息:Swissbit专注于为全球OEM/ODM市场设计、开发、制造和支持领先的内存和存储解决方案。Swissbit提供一流的产品和服务,以满足工业、网络通信和汽车客户的高级别应用需求。
封装信息:30微英寸镀金连接器,符合IPC-6012B Class 2标准。
SFSA128GU1AA4TO-I-NC-216-STD 价格&库存
很抱歉,暂时无法提供与“SFSA128GU1AA4TO-I-NC-216-STD”相匹配的价格&库存,您可以联系我们找货
