APSDM016GH2AN-ATMG
APSDM016GH2AN-ATMG
    APACERMEMORYAMERICA(宇瞻科技)
    SSD 16GB MLC SATA III 5V
APSDM016GH2AN-ATMG 数据手册
RoHS Recast Compliant SATA-Disk Module 5A SDM5A-M 7P/90D Low Profile 2 Product Specifications February 6, 2015 Version 1.0 Apacer Technology Inc. 1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C Tel: +886-2-2267-8000 www.apacer.com Fax: +886-2-2267-2261 SATA-Disk Module 5A APSDM0xxGH2XN-ATMG Features:  Standard Serial ATA 3.1 Revision – SATA 6.0 Gbps interface – ATA-8 command set – Backward compatible with SATA 1.5/3.0 Gbps  Temperature ranges – Operating: 0°C to 70°C – Storage: -40°C to 100°C  Supply voltage – 5.0 V ± 5%  Capacities – 16, 32, 64 GB   Performance* – Burst read/write: 600 MB/sec – Sustained read: up to 445 MB/sec – Sustained write: up to 135 MB/sec Power consumption (typical)* – Active mode: 280 mA – Idle mode: 55 mA  Connector type – 7-pin SATA signal connector – Power segment options: 2 metal pins on each side of SATA connector or power cable connector  Form factor – SATA Disk Module: 7-pin/180 degree   Flash Management – Built-in hardware ECC, enabling up to 40-bit correction per 1K bytes – Static/dynamic wear-leveling – Flash bad-block management – S.M.A.R.T. – Power Failure Management – ATA Secure Erase – TRIM NAND Flash Type: MLC – Dimensions: 33.00 ㎜ x 29.30 ㎜ x 1.00 ㎜**  Shock & Vibration*** – Shock:1500 G – Vibration: 15 G  MTBF: >1,000,000 hours  RoHS Recast compliant – Complies with 2011/65/EU standard *Varies from capacities. The values for performances and power consumptions presented are typical and may vary depending on flash configurations or platform settings. The term idle refers to the standby state of the device. **1.00mm indicates the thickness of the module only. ***Non-operating 1 © 2015 Apacer Technology Inc. Rev. 1.0 SATA-Disk Module 5A APSDM0xxGH2XN-ATMG Table of Contents 1. General Descriptions ............................................................................ 3 2. Pin Assignments .................................................................................... 3 3. Product Specifications.......................................................................... 4 3.1 Capacity ............................................................................................................................................... 4 3.2 Performance ........................................................................................................................................ 4 3.3 Environmental Specifications .............................................................................................................. 4 3.4 Mean Time Between Failures (MTBF) ................................................................................................ 5 3.5 Certification and Compliance .............................................................................................................. 5 4. Flash Management ................................................................................ 6 4.1 Error Correction/Detection ................................................................................................................... 6 4.2 Bad Block Management ...................................................................................................................... 6 4.3 Wear Leveling ...................................................................................................................................... 6 4.4 Power Failure Management ................................................................................................................ 6 4.5 ATA Secure Erase ............................................................................................................................... 6 4.6 TRIM .................................................................................................................................................... 7 4.7 SATA Power Management .................................................................................................................. 7 5. Software Interface ................................................................................ 8 5.1 Command Set ...................................................................................................................................... 8 5.2 S.M.A.R.T. ........................................................................................................................................... 8 6. Electrical Specification ...................................................................... 10 7. Physical Characteristics ..................................................................... 11 7.1 Dimensions ........................................................................................................................................ 11 7.2 Write Protect Switch .......................................................................................................................... 11 8. Product Ordering Information ............................................................. 12 8.1 Product Code Designations ............................................................................................................... 12 8.2 Valid Combinations ............................................................................................................................ 13 8.2.1 7P/90D LP2................................................................................................................................. 13 8.2.2 7P/90D LP2 with write protect .................................................................................................... 13 2 © 2015 Apacer Technology Inc. Rev. 1.0 SATA-Disk Module 5A APSDM0xxGH2XN-ATMG 1. General Descriptions Apacer’s SDM5A-M (SATA Disk Module 5A - M) is our next generation disk-on-module (DOM) series that offers elevated speed boost and higher error correction capabilities. Built with SATA 6 Gb/s interface, SDM5A-M delivers exceptional performance in data transfer. With its SATA interface compliance and compact size, this high-speed disk module defines an ideal balance of performance, capacities, reliability and cost. SDM5A-M comes in moderate capacities that are suitable to boot industrial applications and light operating systems for specific operations, while with some extra memory space for data storage. The architectural nature of SATA disk module provides higher resistance to external environmental influences and better flexibility for motherboard space. Regarding data reliability, SDM5A-M is built in with powerful ECC engine that can correct up to 40-bit per 1KB data. In addition, the controller unit of this DOM device supports wear-leveling, SMART and power failure management for data integrity. Wit its trustable reliability, performance and cost effectiveness, Apacer’s SDM5A-M is definitely the ideal storage or cache solution for embedded and industrial computers, servers and thin clients. 2. Pin Assignments Table 2-1 Signal segment Power cable connector Pin Type S1 S2 S3 S4 S5 S6 S7 GND RxP RxN GND TxN TxP GND Description + Differential Receive Signal - Differential Receive Signal - Differential Transmit Signal + Differential Transmit Signal Signal Pin 1 Table 2-2 Power segment Pin Signal/Description P1 P2 VCC (5V) GND 3 © 2015 Apacer Technology Inc. Rev. 1.0 SATA-Disk Module 5A APSDM0xxGH2XN-ATMG 3. Product Specifications 3.1 Capacity Capacity specification of SDM5A-M is available as shown in table 3-1. It lists the specific capacity and the default numbers of heads, sectors and cylinders for each product line. Table 3-1 Capacity specifications Capacity Total bytes* Cylinders Heads Sectors Max LBA 16 GB 16,013,942,784 16,383 16 63 31,277,232 32 GB 32,017,047,552 16,383 16 63 62,533,296 64 GB 64,023,257,088 16,383 16 63 125,045,424 *Display of total bytes varies from file systems, which means not all of the bytes can be used for storage. **Notes: 1 GB = 1,000,000,000 bytes; 1 sector = 512 bytes. LBA count addressed in the table above indicates total user storage capacity and will remain the same throughout the lifespan of the device. However, the total usable capacity of the SSD is most likely to be less than the total physical capacity because a small portion of the capacity is reserved for device maintenance usages. 3.2 Performance Performances of SDM5A-M are listed below in table 3-2. Table 3-2 Performance specifications Capacity 16 GB 32 GB 64 GB Sustained read (MB/s) 360 440 445 Sustained write (MB/s) 40 75 135 Performance Note: Results may differ from various flash configurations or host system setting 3.3 Environmental Specifications Environmental specification of SDM5A-M product follows MIL-STD-810 standards as shown in Table 3-3. Table 3-3 Environmental specifications Item Specification Operating temp. 0~70℃ Non-operating temp. -40~100(℃) Operating vibration 20~2000(Hz), 7.69 (Grms), random wave, X, Y, Z axis Non-operating vibration 10~2000(Hz), 15(G), sine wave, X, Y, Z axis Operating shock 50(G), 11(ms), half-sine wave Non-operating shock 1500(G), 0.5(ms), half-sine wave 4 © 2015 Apacer Technology Inc. Rev. 1.0 SATA-Disk Module 5A APSDM0xxGH2XN-ATMG 3.4 Mean Time Between Failures (MTBF) Mean Time Between Failures (MTBF) is predicted based on reliability data for the individual components in SDM5A-M. The prediction result for SDM5A-M is more than 1,000,000 hours. Notes about the MTBF: The MTBF is predicated and calculated based on “Telcordia Technologies Special Report, SR-332, Issue 2” method. 3.5 Certification and Compliance SDM5A-M complies with the following standards:     CE FCC RoHS Recast MIL-STD-810 5 © 2015 Apacer Technology Inc. Rev. 1.0 SATA-Disk Module 5A APSDM0xxGH2XN-ATMG 4. Flash Management 4.1 Error Correction/Detection SDM5A-M implements a hardware ECC scheme, based on the BCH algorithm. It can detect and correct up to 40-bit error in 1K bytes. 4.2 Bad Block Management Current production technology is unable to guarantee total reliability of NAND flash memory array. When a flash memory device leaves factory, it comes with a minimal number of initial bad blocks during production or out-of-factory as there is no currently known technology that produce flash chips free of bad blocks. In addition, bad blocks may develop during program/erase cycles. When host performs program/erase command on a block, bad block may appear in Status Register. Since bad blocks are inevitable, the solution is to keep them in control. Apacer flash devices are programmed with ECC, block mapping technique and S.M.A.R.T to reduce invalidity or error. Once bad blocks are detected, data in those blocks will be transferred to free blocks and error will be corrected by designated algorithms. 4.3 Wear Leveling Flash memory devices differ from Hard Disk Drives (HDDs) in terms of how blocks are utilized. For HDDs, when a change is made to stored data, like erase or update, the controller mechanism on HDDs will perform overwrites on blocks. Unlike HDDs, flash blocks cannot be overwritten and each P/E cycle wears down the lifespan of blocks gradually. Repeatedly program/erase cycles performed on the same memory cells will eventually cause some blocks to age faster than others. This would bring flash storages to their end of service term sooner. Wear leveling is an important mechanism that level out the wearing of blocks so that the wearing-down of blocks can be almost evenly distributed. This will increase the lifespan of SSDs. Commonly used wear leveling types are Static and Dynamic. 4.4 Power Failure Management Power Failure Management plays a crucial role when experiencing unstable power supply. Power disruption may occur when users are storing data into the SSD. In this urgent situation, the controller would run multiple write-to-flash cycles to store the metadata for later block rebuilding. This urgent operation requires about several milliseconds to get it done. At the next power up, the firmware will perform a status tracking to retrieve the mapping table and resume previously programmed NAND blocks to check if there is any incompleteness of transmission. 4.5 ATA Secure Erase ATA Secure Erase is an ATA disk purging command currently embedded in most of the storage drives. Defined in ATA specifications, (ATA) Secure Erase is part of Security Feature Set that allows storage drives to erase all user data areas. The erase process usually runs on the firmware level as most of the ATA-based storage media currently in the market are built-in with this command. ATA Secure Erase can securely wipe out the user data in the drive and protects it from malicious attack. 6 © 2015 Apacer Technology Inc. Rev. 1.0 SATA-Disk Module 5A APSDM0xxGH2XN-ATMG 4.6 TRIM TRIM, though in capital letters usually, is a memory computation command rather than an abbreviation. It is mainly a SATA command that enables the operating system to inform the SSD (Solid State Drive) which blocks of previously stored data are no longer valid, due to erases by the host or operating system, such as file deletions or disk formatting. Once notified, SSD will begin the discard of the invalid LBAs and retain more space for itself, in fact, the discarded is no longer recoverable. When an LBA is replaced by the operating system, as with overwrite of a file, the SSD is informed that the originally occupied LBA is determined as no longer in use or invalid. The SSD will not save those blocks in garbage collected sectors. Noticeably, a file deletion command by host or operating system never actually erases the actual content, but marks the file as deleted. This issue is even specifically noticeable for flash based memory devices, such as SSDs. In fact, an SSD will keep garbage collecting the invalid, previously occupied LBAs, if it is not informed that these LBAs can be erased. Thus, the SSD would experience a significant performance downfall. 4.7 SATA Power Management By complying with SATA 6.0 Gb/s specifications, the SSD supports the following SATA power saving modes:  ACTIVE: PHY ready, full power, Tx & Rx operational  PARTIAL: Reduces power, resumes in under 10 µs (microseconds)  SLUMBER: Reduces power, resumes in under 10 ms (milliseconds)  HIPM: Host-Initiated Power Management  DIPM: Device-Initiated Power Management  AUTO-SLUMBER: Automatic transition from partial to slumber. Note: the behaviors of power management features would depend on host/device settings. 7 © 2015 Apacer Technology Inc. Rev. 1.0 SATA-Disk Module 5A APSDM0xxGH2XN-ATMG 5. Software Interface 5.1 Command Set Table 5-1 Command set Code Command Code Command E5h Check Power Mode F3h Security Erase Prepare 06h Data Set Management F4h Security Erase Unit 90h Execute Device Diagnostic F5h Security Freeze Lock E7h Flush Cache F1h Security Set Password EAh Flush Cache EXT F2h Security Unlock Ech Identify Device 70h Seek E3h Idle Efh Set Features E1h Idle Immediate C6h Set Multiple Mode 91h Initialize Device Parameters E6h Sleep C8h Read DMA B0h SMART 25h Read DMA EXT E2h Standby C4h Read Multiple E0h Standby Immediate 29h Read Multiple EXT Cah Write DMA 20h Read Sector 35h Write DMA EXT 24h Read Sector EXT C5h Write Multiple 40h Read Verify Sectors 39h Write Multiple EXT 42h Read Verify Sectors EXT 30h Write Sector 10h Recalibrate 34h Write Sector EXT F6h Security Disable Password 5.2 S.M.A.R.T. S.M.A.R.T. is an abbreviation for Self-Monitoring, Analysis and Reporting Technology, a self-monitoring system that provides indicators of drive health as well as potential disk problems. It serves as a warning for users from unscheduled downtime by monitoring and displaying critical drive information. Ideally, this should allow taking proactive actions to prevent drive failure and make use of S.M.A.R.T. information for future product development reference. Apacer devices use the standard SMART command B0h to read data out from the drive to activate our S.M.A.R.T. feature that complies with the ATA/ATAPI specifications. S.M.A.R.T. Attribute IDs shall include initial bad block count, total later bad block count, maximum erase count, average erase count, power on hours and power cycle. When the S.M.A.R.T. Utility running on the host, it analyzes and reports the disk status to the host before the device reaches in critical condition. Note: attribute IDs may vary from product models due to various solution design and supporting capabilities. 8 © 2015 Apacer Technology Inc. Rev. 1.0 SATA-Disk Module 5A APSDM0xxGH2XN-ATMG Apacer memory products come with S.M.A.R.T. commands and subcommands for users to obtain information of drive status and to predict potential drive failures. Users can take advantage of the following commands/subcommands to monitor the health of the drive. Code D0h D1h D2h D4h D5h D6h D8h D9h DAh Byte 0 1–2 3 4 5*-11 SMART Subcommand READ DATA READ ATTRIBUTE THRESHOLDS Enable/Disable Attribute Autosave Execute Off-line Immediate Read Log (optional) Write Log (optional) Enable Operations Disable operations Return Status General SMART attribute structure Description ID (Hex) Status flag Value Worst Raw Data *Byte 5: LSB ID (Hex) 9 (0x09) 12 (0x0C) 163 (0xA3) 164 (0xA4) 166 (0xA6) 167 (0xA7) 168 (0xA8) 175 (0xAF) 192 (0xC0) 194 (0xC2) 241 (0xF1) SMART attribute ID list Attribute Name Power-on hours Power cycle count Max. erase count Avg. erase count Total later bad block count SSD Protect Mode SATA PHY Error Count Bad Cluster Table Count Unexpected Power Loss Count Temperature Total sectors of write Note General General General General General 0: R/W, 3: Read Only Command Fail Count ECC Fail Count ATA Standby Command PCB Temperature LBA 9 © 2015 Apacer Technology Inc. Rev. 1.0 SATA-Disk Module 5A APSDM0xxGH2XN-ATMG 6. Electrical Specification Caution: Absolute Maximum Stress Ratings – Applied conditions greater than those listed under “Absolute Maximum Stress Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these conditions or conditions greater than those defined in the operational sections of this data sheet is not implied. Exposure to absolute maximum stress rating conditions may affect device reliability. Table 6-1 Operating range Items Range Supply Voltage 5V±5% (4.75-5.25V) Ambient temperature 0°C to +70°C Table 6-2 Power consumption (typical) Capacity 16 GB 32 GB 64 GB Active (mA) 210 235 280 Idle (mA) 55 55 55 Modes Note: Results may differ from various flash configurations or host system setting 10 © 2015 Apacer Technology Inc. Rev. 1.0 SATA-Disk Module 5A APSDM0xxGH2XN-ATMG 7. Physical Characteristics 7.1 Dimensions Unit: ㎜ Tolerance: ± 0.25 7.2 Write Protect Switch Apacer implements the Virtual Write scheme that allows write commands to go through the flash controller and data temporarily stored, but no data has been actually written into the flash. Once the system is reset and rebooted, the temporarily stored data will be lost and nowhere to be found in the system. Since the Virtual Write scheme runs at device level, it requires no software or driver installation and is independent from the host OS. Note: Write Protect is optional. 11 © 2015 Apacer Technology Inc. Rev. 1.0 SATA-Disk Module 5A APSDM0xxGH2XN-ATMG 8. Product Ordering Information 8.1 Product Code Designations A P SDM x x x x X 3 X N – X XXX Flash type FW Version N: Standard A: Standard W: Write protect Solution Version Form Factor H: 7/90 LP2 Capacities: 016G: 032G: 064G: 16GB 32GB 64GB Serial ATA Flash Module Apacer Product Code 12 © 2015 Apacer Technology Inc. Rev. 1.0 SATA-Disk Module 5A APSDM0xxGH2XN-ATMG 8.2 Valid Combinations 8.2.1 7P/90D LP2 Capacity Model Number 16 GB APSDM016GH2AN-ATMG 32 GB APSDM032GH2AN-ATMG 64 GB APSDM064GH2AN-ATMG 8.2.2 7P/90D LP2 with write protect Capacity Model Number 16 GB APSDM016GH2WN-ATMG 32 GB APSDM032GH2WN-ATMG 64 GB APSDM064GH2WN-ATMG Note: Please consult with Apacer sales representatives for availability. 13 © 2015 Apacer Technology Inc. Rev. 1.0 SATA-Disk Module 5A APSDM0xxGH2XN-ATMG Revision History Revision 1.0 Date Description 2/6/2015 Official release Remark 14 © 2015 Apacer Technology Inc. Rev. 1.0 SATA-Disk Module 5A APSDM0xxGH2XN-ATMG Global Presence Taiwan (Headquarters) Apacer Technology Inc. Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: 886-2-2267-8000 Fax: 886-2-2267-2261 amtsales@apacer.com U.S.A. Apacer Memory America, Inc. 386 Fairview Way, Suite102, Milpitas, CA 95035 Tel: 1-408-518-8699 Fax: 1-408-935-9611 sa@apacerus.com Japan Apacer Technology Corp. 5F, Matsura Bldg., Shiba, Minato-Ku Tokyo, 105-0014, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Europe Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-267-0000#6199 sales@apacer.nl China Apacer Electronic (Shanghai) Co., Ltd 1301, No.251,Xiaomuqiao Road, Shanghai, 200032, China Tel: 86-21-5529-0222 Fax: 86-21-5206-6939 sales@apacer.com.cn India Apacer Technologies Pvt Ltd, # 535, 1st Floor, 8th cross, JP Nagar 3rd Phase, Bangalore – 560078, India Tel: 91-80-4152-9061 sales_india@apacer.com 15 © 2015 Apacer Technology Inc. Rev. 1.0
APSDM016GH2AN-ATMG 价格&库存
很抱歉,暂时无法提供与“APSDM016GH2AN-ATMG”相匹配的价格&库存,您可以联系我们找货
