SFSA030GM1AA1TO-I-LB-516-STD 数据手册
Product Fact Sheet
durabit™
“the better MLC”
Industrial
M.2 SATA SSD
X-60m2 2280 Series
SATA Gen3 - 6.0 Gbit/s, MLC
Commercial and Industrial
Temperature Grade
Date :
Re vi si o n:
Au gu s t 0 2, 20 1 9
1 .1 1
Product Fact Sheet
X-60m2 2280 Series
Product Summary
Capacities: 30 GBytes, 60 GBytes, 120 GBytes, 240 GBytes, 480 GBytes, 960 GBytes
Form Factor: PCI ExpressTM M.2 (2280) (80 mm x 22 mm x 3.58 mm)
Compliance: SATA Gen3 - 6 Gbit/s (Gen2 - 3 Gbit/s and Gen1 - 1.5 Gbit/s backward compatible)
Command Sets: Supports ATA/ATAPI-8 and ACS-2
Performance:
o Read Performance: Sequential Read up to 520 MBytes/s, Random Read IOPS up to 75,000
o Write Performance: Sequential Write up to 460 MBytes/s, Random Write IOPS up to 78,000
Operating Temperature Range*:
o Commercial: 0 °C to 70 °C
o Industrial: -40 °C to 85 °C
Storage Temperature Range: -40 °C to 85 °C
Operating Voltage: 3.3 V ± 5%
Power (Max): Read (Active): 1.5 W; Write (Active): 3.4 W; Idle: 410 mW; Slumber: 115 mW
Data Retention: 10 Years @ Life Begin; 1 Year @ Life End
Endurance in TeraBytes Written (TBW) Max Capacity†: Client > 2165; Embedded > 595; Enterprise > 555
Shock/Vibration: 1,500 g / 50 g
Hardware BCH Code ECC: up to 66 bit correction per 1 KByte page
NAND Flash Technology: Multi-Level Cell (MLC)
Mean Time Between Failure: > 2,000,000 hours
Data Reliability: < 1 non-recoverable error per 1016 bits read
Product Features
Best-in-Class Performance and Endurance with durabit™ Technology
Dynamic and Static Wear Leveling
Subpage Mode Flash Translation Layer (FTL)
Active and Passive Data Care Management
Lifetime Enhancements
o Dynamic Bad Block Remapping
o Write Amplification Reduction
On-Board Power Fail Protection
AHCI, TRIM, and NCQ Support
ATA Security Feature Set Support
DEVSLP Compatible
In-Field Firmware Update
Enterprise-Grade Self-Monitoring, Analysis, and Reporting Technology (S.M.A.R.T.)
30 μinch Gold-Plated Connector (IPC-6012B Class 2 Compliant)
AES256 Encryption (on request)
Swissbit Life Time Monitoring (SBLTM) Tool and SDK for SBLTM (on request)
Why Swissbit?
Swissbit is focused on the design, development, manufacture, and support of leading edge memory and
storage solutions for the worldwide OEM/ODM marketplace. As a global supplier, Swissbit recognizes and
addressees the higher level of application requirements of today’s industrial, Netcom, and automotive
customers by providing best-in-class products and services, with uncompromised attention to driving overall
value and quality.
Adequate airflow is required to ensure the temperature, as reported in the S.M.A.R.T. data, does not exceed 115°C (industrial temperature
drive) and 100°C (commercial temperature drive) respectively.
According to JEDEC (JESD47I), the time to write the full TBW is a minimum of 18 months. Higher average daily data volume reduces the
specified TBW. The values listed are estimates and are subject to change without notice.
Swissbit AG
Industriestrasse 4
CH-9552 Bronschhofen
Switzerland
www.swissbit.com
industrial@swissbit.com
Revision: 1.11
Doc-2719
File: X-60m2_2280_fact_sheet_Rev111
Page 2 of 2
SFSA030GM1AA1TO-I-LB-516-STD 价格&库存
很抱歉,暂时无法提供与“SFSA030GM1AA1TO-I-LB-516-STD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+651.996781+84.35319
