SFSA120GQ1AA4TO-I-LB-216-STD 数据手册
Product Fact Sheet
durabit™
“the better MLC”
Industrial
2.5” SATA SSD
X-60 Series
SATA Gen3 - 6.0 Gbit/s, MLC
Commercial and Industrial
Temperature Grade
Date :
Re vi si o n:
N ove m be r 05 , 2 0 2 1
1 .0 3
Product Fact Sheet
X-60 Series
Product Summary
Capacities: 30 GBytes, 60 GBytes, 120 GBytes, 240 GBytes, 480 GBytes, 960 GBytes
Form Factor: 2.5" SATA Solid State Drive (70 mm x 100 mm x 7 mm)
Compliance: SATA Gen3 - 6 Gbit/s (Gen2 - 3 Gbit/s and Gen1 - 1.5 Gbit/s backward compatible)
Command Sets: Supports ATA/ATAPI-8 and ACS-2
Performance:
o Read Performance: Sequential Read up to 525 MBytes/s, Random Read 4K up to 74,300 IOPS
o Write Performance: Sequential Write up to 460 MBytes/s, Random Write 4K up to 77,900 IOPS
Operating Temperature Range1:
o Commercial: 0 °C to 70 °C
o Industrial: -40 °C to 85 °C
Storage Temperature Range: -40 °C to 85 °C
Operating Voltage: 5 V ± 10% (3.3 V available upon request)
Power (Max): Read (Active): 2.1 W; Write (Active): 4.0 W; Idle: 525 mW; Slumber: 125 mW
Data Retention: 10 Years @ Life Begin / 1 Year @ Life End
Endurance in TeraBytes Written (TBW) @ Max Capacity2: Client ≥ 2,380; Embedded ≥ 660; Enterprise ≥ 610
Shock/Vibration: 1,500 g / 50 g
High-Performance 32-Bit Processor with Integrated, Parallel Flash Interface Engines:
o Multi-Level Cell (MLC) NAND Flash
o Hardware BCH Code ECC (up to 66 bit correction per 1 KByte page)
Mean Time Between Failure (MTBF): > 2,000,000 hours
Data Reliability: < 1 non-recoverable error per 1016 bits read
Product Features
Best-in-Class Performance and Endurance with durabit™ Technology
Dynamic and Static Wear Leveling
Active and Passive Data Care Management
Lifetime Enhancements
o Dynamic Bad Block Remapping
o Write Amplification Reduction
On-Board Power Fail Protection
AHCI, TRIM, and NCQ Support
ATA Security Feature Set Support
DEVSLP Compatible
In-Field Firmware Update
Enterprise-Grade Self-Monitoring, Analysis, and Reporting Technology (S.M.A.R.T.)
30 µinch Gold-Plated Connector (IPC-6012B Class 2 Compliant)
AES256 Encryption (on request)
Swissbit Life Time Monitoring (SBLTM) Tool and SDK for SBLTM (on request)
Why Swissbit?
Swissbit is focused on the design, development, manufacture, and support of leading edge memory and
storage solutions for the worldwide OEM/ODM marketplace. As a global supplier, Swissbit recognizes and
addresses the higher level of application requirements of today’s industrial, Netcom, and automotive
customers by providing best-in-class products and services, with uncompromised attention to driving overall
value and quality.
1
2
Adequate airflow is required to ensure the temperature, as reported in the S.M.A.R.T. data, does not exceed 115°C (industrial
temperature drive) and 100°C (commercial temperature drive) respectively.
According to JEDEC (JESD47I), the time to write the full TBW is a minimum of 18 months. Higher average daily data volume reduces the
specified TBW. The values listed are estimates and are subject to change without notice.
Swissbit AG
Industriestrasse 4
CH-9552 Bronschhofen
Switzerland
TLP: Swissbit public
www.swissbit.com/contact
Revision: 1.03
Template: Doc-4991
File: X-60_fact_sheet_Rev103
Page 2 of 2
SFSA120GQ1AA4TO-I-LB-216-STD 价格&库存
很抱歉,暂时无法提供与“SFSA120GQ1AA4TO-I-LB-216-STD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1645.431931+213.82808
