SFSA016GM1AA2TO-I-DB-516-STD 数据手册
Product Fact Sheet
Industrial
M.2 SATA SSD
X-600m2 2280 Series
SATA Gen3 – 6.0 Gbit/s, SLC
Commercial and Industrial
Temperature Grade
Date :
Re vi si o n:
Au gu s t 30 , 2 0 1 9
1 .0 9
Product Fact Sheet
X-600m2 2280 Series
Product Summary
Capacities: 16 GBytes, 32 GBytes, 64 GBytes, 128 GBytes
Form Factor: PCI ExpressTM M.2 (2280) (80 mm x 22 mm x 3.58 mm)
Compliance: SATA Gen3 - 6 Gbit/s (Gen2 - 3 Gbit/s and Gen1 - 1.5 Gbit/s backward compatible)
Command Sets: Supports ATA/ATAPI-8 and ACS-2
Performance:
o Read Performance: Sequential Read up to 520 MBytes/s, Random Read 4K up to 76,000 IOPS
o Write Performance: Sequential Write up to 405 MBytes/s, Random Write 4K up to 73,000 IOPS
Operating Temperature Range*:
o Commercial: 0 °C to 70 °C
o Industrial: -40 °C to 85 °C
Storage Temperature Range: -40 °C to 85 °C
Operating Voltage: 3.3 V ± 5%
Power (Max Capacity): Read (Active): 1.7 W; Write (Active): 2.5 W; Idle: 380 mW; Slumber: 115 mW
Data Retention: 10 Years @ Life Begin; 1 Year @ Life End
Endurance in TeraBytes Written (TBW) Max Capacity†: Client ≥ 7,715; Embedded ≥ 2,500; Enterprise ≥ 1,120
Shock/Vibration: 1,500 g / 50 g
Hardware BCH Code ECC: up to 66 bit correction per 1 KByte page
Mean Time Between Failure: > 2,000,000 hours
Data Reliability: < 1 non-recoverable error per 1016 bits read
Product Features
Dynamic and Static Wear Leveling
Data Care Management
o Active: Adaptive Read Refresh
o Passive: Background Media Scan
Lifetime Enhancements
o Dynamic Bad Block Remapping
o Write Amplification Reduction
On-Board Power Fail Protection
AHCI, TRIM, and NCQ Support
ATA Security Feature Set Support
DEVSLP Compatible
In-Field Firmware Update
Enterprise-Grade Self-Monitoring, Analysis, and Reporting Technology (S.M.A.R.T.)
30 μinch Gold-Plated Connector (IPC-6012B Class 2 Compliant)
AES256 Encryption (on request)
Swissbit Life Time Monitoring (SBLTM) Tool and SDK for SBLTM (on request)
Why Swissbit?
Swissbit is focused on the design, development, manufacture, and support of leading edge memory and
storage solutions for the worldwide OEM/ODM marketplace. As a global supplier, Swissbit recognizes and
addressees the higher level of application requirements of today’s industrial, Netcom, and automotive
customers by providing best-in-class products and services, with uncompromised attention to driving overall
value and quality.
Adequate airflow is required to ensure the temperature, as reported in the S.M.A.R.T. data, does not exceed 115°C (industrial
temperature drive) and 100°C (commercial temperature drive) respectively.
According to JEDEC (JESD47I), the time to write the full TBW is a minimum of 18 months. Higher average daily data volume reduces the
specified TBW. The values listed are estimates and are subject to change without notice.
Swissbit AG
Industriestrasse 4
CH-9552 Bronschhofen
Switzerland
www.swissbit.com
industrial@swissbit.com
Revision: 1.09
Doc-2791
File: X-600m2_2280_fact_sheet_Rev109
Page 2 of 2
SFSA016GM1AA2TO-I-DB-516-STD 价格&库存
很抱歉,暂时无法提供与“SFSA016GM1AA2TO-I-DB-516-STD”相匹配的价格&库存,您可以联系我们找货
