APSDM064GM9CN-3BTW
APSDM064GM9CN-3BTW
    APACERMEMORYAMERICA(宇瞻科技)
    SSD 64GB MSATA SLC SATA III 3.3V
APSDM064GM9CN-3BTW 数据手册
RoHS Compliant Serial ATA Flash Drive mSATA A1 Product Specifications October 7th, 2014 Version 1.6 Apacer Technology Inc. 1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C Tel: +886-2-2267-8000 www.apacer.com Fax: +886-2-2267-2261 Serial ATA Flash Drive APSDMxxxxMXXN-XTX Features:  Compliance with SATA Revision 3.1 Serial ATA Revision 3.1 specifications SATA 6.0 Gbps interface Backward compatible with SATA 1.5 and 3.0 Gbps interfaces – ATA-8 command set Temperature ranges Operating: Standard: 0°C to 70°C Extended: -40°C to 85°C – Storage: -40°C to 100°C  – – –  Capacities – 4, 8, 16, 32, 64, 128 GB  Performance* – Interface burst read/write: 600 MB/sec Standard type: – Sustained read: up to 160 MB/sec – Sustained write: up to 155 MB/sec High-speed type: – Sustained read: up to 530 MB/sec – Sustained write: up to 450 MB/sec – Random read 4K: up to 82,000 IOPS – Random write 4K: up to 77,000 IOPS  Flash Management Built-in hardware ECC, enabling up to 40 bit correction per 1K bytes – Static/dynamic wear leveling – Flash bad-block management – S.M.A.R.T. – Power Failure Management – ATA Secure Erase – TRIM – Supply voltage 3.3 V 5%  – ± Power consumption (typical)* Standard type: – Active mode: 410 mA – Idle mode: 195 mA High-speed – Active mode: 890 mA – Idle mode: 160 mA  Form factor JEDEC MO-300  – Shock & Vibration** Shock: 1500 G Vibration: 15 G  – – –  SATA power management modes  Device Sleep mode (optional)  Write Protect switch (optional)  RoHS compliant  NAND Flash Type: SLC *Varies from capacities. The values addressed here are typical and may vary depending on settings and platforms. **Non-operating 1 ©2014 Apacer Technology Inc. Rev. 1.6 Serial ATA Flash Drive APSDMxxxxMXXN-XTX Table of Contents 1. Product Description ............................................................................................... 3 1.1 Introduction .................................................................................................................................................3 1.2 Capacity Specification.................................................................................................................................3 1.3 Performance.................................................................................................................................................3 1.4 Pin Assignments ..........................................................................................................................................4 2. Software Interface................................................................................................... 6 2.1 Command Set ..............................................................................................................................................6 2.2 S.M.A.R.T....................................................................................................................................................6 3. Flash Management ................................................................................................. 8 3.1 Error Correction/Detection ........................................................................................................................8 3.2 Bad Block Management .............................................................................................................................8 3.3 Wear Leveling .............................................................................................................................................8 3.4 Power Failure Management .......................................................................................................................8 3.5 ATA Secure Erase .......................................................................................................................................8 3.6 TRIM ...........................................................................................................................................................9 3.7 SATA Power Management ........................................................................................................................9 4. Reliability Specifications ..................................................................................... 10 4.1 Environmental ..........................................................................................................................................10 4.2 Mean Time Between Failures (MTBF)....................................................................................................10 4.3 Certification and Compliance ..................................................................................................................10 5. Electrical Characteristics..................................................................................... 11 5.1 Operating Voltage .....................................................................................................................................11 5.2 Power Consumption .................................................................................................................................11 6. Mechanical Specifications ................................................................................... 12 6.1 6.2 6.3 7. Dimensions (Standard type).....................................................................................................................12 Dimensions (High-speed type) .................................................................................................................13 Write Protect Switch (optional)...............................................................................................................14 Product Ordering Information ............................................................................. 15 7.1 Product Code Designations ......................................................................................................................15 7.2 Valid Combinations ..................................................................................................................................16 2 ©2014 Apacer Technology Inc. Rev. 1.6 Serial ATA Flash Drive APSDMxxxxMXXN-XTX 1. Product Description 1.1 Introduction Apacer’s mSATA A1 is a well-balanced solid-state disk (SSD) drive with compact form factor (JEDEC MO-300) and great performance. Designed in SATA 6.0 Gbps interface, the mSATA SSD is able to deliver exceptional read/write speed, making it the ideal companion for heavy-loading embedded or server operations with space constraints for host computing systems. In regard of reliability, the drive comes with various implementations including powerful hardware ECC engine, power saving modes, wear leveling, flash block management, S.M.A.R.T., TRIM, and power failure management. 1.2 Capacity Specification Table 1-1 Capacity specification Capacity Total Bytes Cylinders Heads Sectors Max LBA 4 GB 4,011,614,208 7,773 16 63 7,835,184 8 GB 8,012,390,400 15,525 16 63 15,649,200 16 GB 16,013,942,784 16,383 16 63 31,277,232 32 GB 32,017,047,552 16,383 16 63 62,533,296 64 GB 64,023,257,088 16,383 16 63 125,045,424 128 GB 128,035,676,160 16,383 16 63 250,069,680 1. Display of total bytes varies from file systems. 2. Cylinders, heads or sectors are not applicable for these capacities. Only LBA addressing applies.3. LBA count addressed in the table above indicates total user storage capacity and will remain the same throughout the lifespan of the device. However, the total usable capacity of the SSD is most likely to be less than the total physical capacity because a small portion of the capacity is reserved for device maintenance usages. 1.3 Performance Table 1-2 Performance (standard) Capacity Performance Sustained Read (MB/s) Sustained Write (MB/s) 4 GB 8 GB 16 GB 32 GB 64 GB 140 150 150 160 160 55 80 80 150 155 Table 1-3 Performance (high-speed) Capacity 32 GB 64 GB 128 GB Sustained Read (MB/s) 530 530 530 Sustained Write (MB/s) 270 440 450 Random Read IOPS (4K) 81,000 82,000 82,000 Random Write IOPS (4K) 62,000 76,000 77,000 Performance Note: Performance varies from flash configurations or host system settings. IOPS: measured on 8GB span (16777216 sectors Disk Size), 32 Outstanding I/Os (QD=32), Full Random Data pattern, 4KB Align I/Os and test durations 15minutes. 3 ©2014 Apacer Technology Inc. Rev. 1.6 Serial ATA Flash Drive APSDMxxxxMXXN-XTX 1.4 Pin Assignments Pin assignment of the mSATA A1 is shown in Figure 1-1 and described in Table 1-4. Pin 1 Pin 51 Figure 1-1 Apacer mSATA A1 pin assignment Table 1-4 Pin Assignment Description Pin 1 2 3 4 Type Reserved +3.3V Reserved GND Description No Connect 3.3V source No Connect Ground Pin 27 28 29 30 Type GND Reserved GND Reserved 5 Reserved No Connect 31 -A 6 Reserved No Connect 32 Reserved 7 Reserved No Connect 33 +A 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 Reserved GND Reserved Reserved Reserved Reserved Reserved GND Reserved Reserved GND Reserved Reserved GND Reserved No Connect Ground No Connect No Connect No Connect No Connect No Connect Ground No Connect No Connect Ground No Connect No Connect Ground No Connect 34 35 36 37 38 39 40 41 42 43 44* 45 46 47 48 GND GND Reserved GND Reserved +3.3V GND +3.3V Reserved Device Type DEVSLP Reserved Reserved Reserved Reserved 23 +B Host Receiver Differential Signal Pair 49 DAS/DSS 24 +3.3V Description Ground No Connect Ground No Connect Host Transmitter Differential Signal Pair No Connect Host Transmitter Differential Signal Pair Ground Ground No Connect Ground No Connect 3.3V source Ground 3.3V source No Connect No Connect Device Sleep No Connect No Connect No Connect No Connect Device Activity Signal/Disable Staggered Spin-up Ground 3.3V Source 50 GND Host Receiver 25 -B 51** Detect 0 ohm Differential Signal Pair 26 GND Ground 52 +3.3V 3.3V source *Pin44 can be configured as Device Sleep enabling pin by option. **Notes about Pin51: It is a presence detection pin that shall be connected to GND by a 0 ohm to 220 ohm Resistor on device. Please see the diagram below. 4 ©2014 Apacer Technology Inc. Rev. 1.6 Serial ATA Flash Drive APSDMxxxxMXXN-XTX 5 ©2014 Apacer Technology Inc. Rev. 1.6 Serial ATA Flash Drive APSDMxxxxMXXN-XTX 2. Software Interface 2.1 Command Set Table 2-1 summarizes the ATA commands supported by mSATA A1. Table 2-1: Code 2.2 Command set Command Code Command E5h Check Power Mode F6h Security Disable Password 90h Execute Diagnostics F3h Security Erase Prepare E7h Flush Cache F4h Security Erase Unit ECh Identify Device F5h Security Freeze Lock E3h Idle F1h Security Set Password E1h Idle Immediate F2h Security Unlock 91h Initialize Device Parameters 7xh Seek C8h Read DMA EFh Set Features 25h Read DMA EXT C6h Set Multiple Mode 60h Read FPDMA Queued E6h Sleep 47h Read Log DMA EXT B0h S.M.A.R.T. 2Fh Read Log EXT E2h Standby C4h Read Multiple E0h Standby Immediate 20 or Read Sector(s) CAh Write DMA 40 or Read Verify Sector(s) 35h Write DMA EXT 10h Recalibrate 61h Write FPDMA Queued 57h Write Log DMA EXT 3Fh Write Log EXT C5h Write Multiple 30h or Write Sector(s) S.M.A.R.T. S.M.A.R.T. is an abbreviation for Self-Monitoring, Analysis and Reporting Technology, a self-monitoring system that provides indicators of drive health as well as potential disk problems. It serves as a warning for users from unscheduled downtime by monitoring and displaying critical drive information. Ideally, this should allow taking proactive actions to prevent drive failure and make use of S.M.A.R.T. information for future product development reference. Apacer devices use the standard SMART command B0h to read data out from the drive to activate our S.M.A.R.T. feature that complies with the ATA/ATAPI specifications. S.M.A.R.T. Attribute IDs shall include initial bad block count, total later bad block count, maximum erase count, average erase count, power on hours and power cycle. When the S.M.A.R.T. Utility running on the host, it analyzes and reports the disk status to the host before the device reaches in critical condition. Note: attribute IDs may vary from product models due to various solution design and supporting capabilities. 6 ©2014 Apacer Technology Inc. Rev. 1.6 Serial ATA Flash Drive APSDMxxxxMXXN-XTX Apacer memory products come with S.M.A.R.T. commands and subcommands for users to obtain information of drive status and to predict potential drive failures. Users can take advantage of the following commands/subcommands to monitor the health of the drive. Code D0h D1h D2h D4h D5h D6h D8h D9h DAh Byte 0 1–2 3 4 5*-11 SMART Subcommand READ DATA READ ATTRIBUTE THRESHOLDS Enable/Disable Attribute Autosave Execute Off-line Immediate Read Log (optional) Write Log (optional) Enable Operations Disable operations Return Status General SMART attribute structure Description ID (Hex) Status flag Value Worst Raw Data *Byte 5: LSB ID (Hex) 9 (0x09) 12 (0x0C) 163 (0xA3) 164 (0xA4) 166 (0xA6) 167 (0xA7) 168 (0xA8) 175 (0xAF) 192 (0xC0) 194 (0xC2) 241 (0xF1) SMART attribute ID list Attribute Name Power-on hours Power cycle count Max. erase count Avg. erase count Total later bad block count SSD Protect Mode (vendor specific) SATA PHY Error Count Bad Cluster Table Count Unexpected Power Loss Count Temperature Total sectors of write 7 ©2014 Apacer Technology Inc. Rev. 1.6 Serial ATA Flash Drive APSDMxxxxMXXN-XTX 3. Flash Management 3.1 Error Correction/Detection mSATA A1 implements a hardware ECC scheme, based on the BCH algorithm. It can detect and correct up to 40 bits error in 1K bytes. 3.2 Bad Block Management Current production technology is unable to guarantee total reliability of NAND flash memory array. When a flash memory device leaves factory, it comes with a minimal number of initial bad blocks during production or out-of-factory as there is no currently known technology that produce flash chips free of bad blocks. In addition, bad blocks may develop during program/erase cycles. When host performs program/erase command on a block, bad block may appear in Status Register. Since bad blocks are inevitable, the solution is to keep them in control. Apacer flash devices are programmed with ECC, block mapping technique and S.M.A.R.T to reduce invalidity or error. Once bad blocks are detected, data in those blocks will be transferred to free blocks and error will be corrected by designated algorithms. 3.3 Wear Leveling Flash memory devices differ from Hard Disk Drives (HDDs) in terms of how blocks are utilized. For HDDs, when a change is made to stored data, like erase or update, the controller mechanism on HDDs will perform overwrites on blocks. Unlike HDDs, flash blocks cannot be overwritten and each P/E cycle wears down the lifespan of blocks gradually. Repeatedly program/erase cycles performed on the same memory cells will eventually cause some blocks to age faster than others. This would bring flash storages to their end of service term sooner. Wear leveling is an important mechanism that level out the wearing of blocks so that the wearing-down of blocks can be almost evenly distributed. This will increase the lifespan of SSDs. Commonly used wear leveling types are Static and Dynamic. 3.4 Power Failure Management Power Failure Management plays a crucial role when experiencing unstable power supply. Power disruption may occur when users are storing data into the SSD. In this urgent situation, the controller would run multiple write-to-flash cycles to store the metadata for later block rebuilding. This urgent operation requires about several milliseconds to get it done. At the next power up, the firmware will perform a status tracking to retrieve the mapping table and resume previously programmed NAND blocks to check if there is any incompleteness of transmission. Note: The controller unit of this product model is designed with a DRAM as a write cache for improved performance and data efficiency. Though unlikely to happen in most cases, the data cached in the volatile DRAM might be potentially affected if a sudden power loss takes place before the cached data is flushed into non-volatile NAND flash memory. 3.5 ATA Secure Erase ATA Secure Erase is an ATA disk purging command currently embedded in most of the storage drives. Defined in ATA specifications, (ATA) Secure Erase is part of Security Feature Set that allows storage drives to erase all user data areas. The erase process usually runs on the firmware level as most of the ATA-based storage media currently in the market are built-in with this command. ATA Secure Erase can securely wipe out the user data in the drive and protects it from malicious attack. 8 ©2014 Apacer Technology Inc. Rev. 1.6 Serial ATA Flash Drive APSDMxxxxMXXN-XTX 3.6 TRIM TRIM is a SATA command that helps improve the read/write performance and efficiency of solid-state drives (SSD). The command enables the host operating system to inform SSD controller whick blocks contain invalid data, mostly because of the erase commands from host. The invalid will be discarded permanently and the SSD will retain more space for itself. 3.7 SATA Power Management By complying with SATA 6.0 Gb/s specifications, the SSD supports the following SATA power saving modes:  ACTIVE: PHY ready, full power, Tx & Rx operational  PARTIAL: Reduces power, resumes in under 10 µs (microseconds)  SLUMBER: Reduces power, resumes in under 10 ms (milliseconds)  HIPM: Host-Initiated Power Management  DIPM: Device-Initiated Power Management  AUTO-SLUMBER: Automatic transition from partial to slumber.  Device Sleep (DevSleep or DEVSLP): PHY powered down; power consumption 5 mW; host assertion time 10 ms; exit timeout from this state 20 ms (unless specified otherwise in SATA Identify Device Log). ≦ ≦ ≦ Note: 1. The behaviors of power management features would depend on host/device settings. 2. Device Sleep mode is optional, depending on product ordering selections. 9 ©2014 Apacer Technology Inc. Rev. 1.6 Serial ATA Flash Drive APSDMxxxxMXXN-XTX 4. Reliability Specifications 4.1 Environmental mSATA A1 environmental specifications follow MIL-STD-810F, as indicated in the following table. Table 4-1 mSATA A1 environmental specifications Environment Temperature Vibration Shock 4.2 Specification 0°C to 70°C (Operating); -40°C to 85°C (Extended) -40°C to 100°C (Non-operating) Non-operating : Sine wave, 15(G), 10~2000(Hz), Operating : Random, 7.69(Grms), 20~2000(Hz) Non-operating: Acceleration, 1,500 G, 0.5 ms Operating: Peak acceleration, 50 G, 11 ms Mean Time Between Failures (MTBF) Mean Time Between Failures (MTBF) is predicted based on reliability data for the individual components in SATA drive. The prediction result for the mSATA A1 is more than 2,000,000 hours. Notes about the MTBF: the MTBF is predicated and calculated based on “Telcordia Technologies Special Report, SR-332, Issue 2” method. 4.3 Certification and Compliance mSATA A1 complies with the following standards:     CE FCC RoHS MIL-STD-810F 10 ©2014 Apacer Technology Inc. Rev. 1.6 Serial ATA Flash Drive APSDMxxxxMXXN-XTX 5. Electrical Characteristics 5.1 Operating Voltage Table 5-1 lists the supply voltage for mSATA A1. Table 5-1 mSATA A1 operating voltage Parameter Conditions Supply voltage 5.2 3.3V ±5% Power Consumption Table 5-2 Power consumption (standard) Capacity 4 GB 8 GB 16 GB 32 GB 64 GB Active (mA) 290 375 375 375 410 Idle (mA) 195 195 195 195 195 Mode Table 5-3: Typical power consumption (high-speed) Capacity 32 GB 64 GB 128 GB Active (mA) 450 680 890 Idle (mA) 160 160 160 Modes Note: Results were conducted by estimates and may differ from various flash configurations or host system setting 11 ©2014 Apacer Technology Inc. Rev. 1.6 Serial ATA Flash Drive APSDMxxxxMXXN-XTX 6. Mechanical Specifications 6.1 Dimensions (Standard type) ㎜ Unit: Tolerance: ± 0.2 12 ©2014 Apacer Technology Inc. Rev. 1.6 Serial ATA Flash Drive APSDMxxxxMXXN-XTX 6.2 Dimensions (High-speed type) ㎜ Unit: Tolerance: ± 0.2 13 ©2014 Apacer Technology Inc. Rev. 1.6 Serial ATA Flash Drive APSDMxxxxMXXN-XTX 6.3 Write Protect Switch (optional) Disable Enable Description of Apacer Write Protect: Apacer implements the Virtual Write scheme that allows write commands to go through the flash controller and data temporarily stored, but no data has been actually written into the flash. Since the Virtual Write scheme runs at device level, it requires no software or driver installation and is independent from the host OS. 14 ©2014 Apacer Technology Inc. Rev. 1.6 Serial ATA Flash Drive APSDMxxxxMXXN-XTX 7. Product Ordering Information 7.1 Product Code Designations A P SDM x x x x M X XN – X T X Operating Temperature Range ℃ ℃ ℃ ℃ Blank: 0 ~ 70 W: -40 ~ 85 Flash Type Version Control Add on value AN = Standard WN= No DEVSLP + Write Protect CN= DEVSLP + Write Protect Solution Version Form Factor: M= MO-300 Capacities: 004G = 4GB 008G = 8GB 016G = 16GB 032G = 32GB 064G = 64GB 128G = 128GB SATA Disk Module Apacer Product Code 15 ©2014 Apacer Technology Inc. Rev. 1.6 Serial ATA Flash Drive APSDMxxxxMXXN-XTX 7.2 Valid Combinations A. No Write Protect 7.2.1.1 Standard Speed / Operating Temperature (0℃ Capacity 4GB 8GB 16GB 32GB 64GB ℃) ~ 70 NO DEVSLP APSDM004GMBAN-AT APSDM008GMBAN-AT APSDM016GMBAN-AT APSDM032GMBAN-AT APSDM064GMBAN-AT DEVSLP APSDM004GMBAN-BT APSDM008GMBAN-BT APSDM016GMBAN-BT APSDM032GMBAN-BT APSDM064GMBAN-BT 7.2.1.2 Standard Speed / Operating Temperature (-40℃ Capacity 4GB 8GB 16GB 32GB 64GB NO DEVSLP APSDM004GMBAN-ATW APSDM008GMBAN-ATW APSDM016GMBAN-ATW APSDM032GMBAN-ATW APSDM064GMBAN-ATW 7.2.1.3 High Speed / Operating Temperature (0℃ Capacity 32GB 64GB 128GB DEVSLP APSDM004GMBAN-BTW APSDM008GMBAN-BTW APSDM016GMBAN-BTW APSDM032GMBAN-BTW APSDM064GMBAN-BTW ℃) ~ 70 NO DEVSLP DEVSLP APSDM032GM9AN-3BT APSDM064GM9AN-3BT APSDM128GM9AN-3BT APSDM032GM9AN-3AT APSDM064GM9AN-3AT APSDM128GM9AN-3AT 7.2.1.4 High Speed / Operating Temperature (-40℃ Capacity 32GB 64GB 128GB NO DEVSLP APSDM032GM9AN-3ATW APSDM064GM9AN-3ATW APSDM128GM9AN-3ATW ℃) ~ 85 ℃) ~ 85 DEVSLP APSDM032GM9AN-3BTW APSDM064GM9AN-3BTW APSDM128GM9AN-3BTW 16 ©2014 Apacer Technology Inc. Rev. 1.6 Serial ATA Flash Drive APSDMxxxxMXXN-XTX B. Write Protect 7.2.2.1 Standard Speed / Operating Temperature (0℃ Capacity 4GB 8GB 16GB 32GB 64GB ℃) ~ 70 NO DEVSLP APSDM004GMBWN-AT APSDM008GMBWN-AT APSDM016GMBWN-AT APSDM032GMBWN-AT APSDM064GMBWN-AT DEVSLP APSDM004GMBCN-BT APSDM008GMBCN-BT APSDM016GMBCN-BT APSDM032GMBCN-BT APSDM064GMBCN-BT 7.2.2.2 Standard Speed / Operating Temperature (-40℃ Capacity 4GB 8GB 16GB 32GB 64GB NO DEVSLP APSDM004GMBWN-ATW APSDM008GMBWN-ATW APSDM016GMBWN-ATW APSDM032GMBWN-ATW APSDM064GMBWN-ATW 7.2.2.3 High Speed / Operating Temperature (0℃ Capacity 32GB 64GB 128GB DEVSLP APSDM004GMBCN-BTW APSDM008GMBCN-BTW APSDM016GMBCN-BTW APSDM032GMBCN-BTW APSDM064GMBCN-BTW ℃) ~ 70 NO DEVSLP DEVSLP APSDM032GM9CN-3BT APSDM064GM9CN-3BT APSDM128GM9CN-3BT APSDM032GM9WN-3AT APSDM064GM9WN-3AT APSDM128GM9WN-3AT 7.2.2.4 High Speed / Operating Temperature (-40℃ Capacity 32GB 64GB 128GB NO DEVSLP APSDM032GM9WN-3ATW APSDM064GM9WN-3ATW APSDM128GM9WN-3ATW ℃) ~ 85 ℃) ~ 85 DEVSLP APSDM032GM9CN-3BTW APSDM064GM9CN-3BTW APSDM128GM9CN-3BTW Note: please contact Apacer sales representatives for availabilities. 17 ©2014 Apacer Technology Inc. Rev. 1.6 Serial ATA Flash Drive APSDMxxxxMXXN-XTX Revision History Revision Description Date 0.1 Preliminary 02/07/2014 1.0 Official release 02/25/2014 1.1 Removed “DSS” from pin 49 03/14/2014 1.2 Updated mechanical drawing 05/15/2014 1.3 Added high-speed models 07/10/2014 1.4 Revised Product Ordering Information 08/15/2014 1.5 Revised pin assignments 09/15/2014 1.6 Revised part numbers for 32GB in high speed models 10/07/2014 18 ©2014 Apacer Technology Inc. Rev. 1.6 Serial ATA Flash Drive APSDMxxxxMXXN-XTX Global Presence Taiwan (Headquarters) Apacer Technology Inc. Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: 886-2-2267-8000 Fax: 886-2-2267-2261 amtsales@apacer.com U.S.A. Apacer Memory America, Inc. 386 Fairview Way, Suite102, Milpitas, CA 95035 Tel: 1-408-518-8699 Fax: 1-408-935-9611 sa@apacerus.com Japan Apacer Technology Corp. 5F, Matsura Bldg., Shiba, Minato-Ku Tokyo, 105-0014, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Europe Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-267-0000#6199 sales@apacer.nl China Apacer Electronic (Shanghai) Co., Ltd 1301, No.251,Xiaomuqiao Road, Shanghai, 200032, China Tel: 86-21-5529-0222 Fax: 86-21-5206-6939 sales@apacer.com.cn India Apacer Technologies Pvt Ltd, # 535, 1st Floor, 8th cross, JP Nagar 3rd Phase, Bangalore – 560078, India Tel: 91-80-4152-9061 sales_india@apacer.com 19 ©2014 Apacer Technology Inc. Rev. 1.6
APSDM064GM9CN-3BTW 价格&库存
很抱歉,暂时无法提供与“APSDM064GM9CN-3BTW”相匹配的价格&库存,您可以联系我们找货
