AF128GSSCJ-OEM
AF128GSSCJ-OEM
    ATPELECTRONICS
    SSD 128GB 2.5" SLC SATA III
AF128GSSCJ-OEM 数据手册
ATP Industrial Grade 2.5” SATA SSDs ATP offers various 2.5" SSDs in SLC, MLC and aMLC types with SATA II & SATA III interfaces. ATP SSDs are designed for different applications, including industrial computers, data center, POS, networking, thin clients and other industrial applications. SATA II SSDs - Velocity SI Lite Key Features • 2.5” SATA II form factor • Enhanced endurance with Advanced Wear Leveling algorithm • Built-in hardware-based data protection technology during power failure - PowerProtector • NSA Compliant SecureErase • Supports S.M.A.R.T. ATA feature set The ATP Velocity SI Lite SSD with SATA II interface is specifically designed and engineered for mission critical industrial applications, where high endurance and reliability are required. Utilizing SLC (Single Level Cell) NAND flash components, the ATP Velocity SI Lite SSD offers sequential read speed of up to 182 MB/s and sequential write of up to 133 MB/s. The Velocity SI Lite SSD is a cost-effective alternative for enterprise and industrial applications with high reliability, durability, performance and data integrity requirements. Specifications Ordering Information Product Name Velocity SI Lite 2.5” SSD SATA-II Density Part Number Flash Type SLC 4GB AF4GSSCD-RABXP Density 4GB to 64GB 8GB AF8GSSCD-RABXP 16GB AF16GSSCD-RABXP 32GB AF32GSSCD-RABXP 64GB AF64GSSCD-RABXP Sequential Read up to 182 MB/s Performance Sequential Write up to 133 MB/s Random Read IOPS up to 2,700 Interface SATA II 3 Gb/s Operating Temperature -40°C to +85°C Advanced Wear Leveling Reliability TBW** (max.) : 768 TB MTBF @ 25°C : >2,000,000 hours Dimensions: LxWxH (mm) 100.0 x 69.9 x 9.2 ** All TBW data listed are under highest random write value in each product line. The TBW data are subject to change by density, configuration and customers’ applications. SATA II SSDs - Velocity XE Key Features • Designed for enterprise applications requiring high endurance on aMLC (Advanced Multi-Level Cell) technology • Enhanced endurance by Advanced Wear Leveling algorithm • Support Static Data Refresh technology • NSA Compliant SecureErase • Supports S.M.A.R.T. ATA feature set The ATP Velocity XE SATA SSD provides outstanding performance and proven reliability for product operation, which is perfect for networking and thin clients, also suit for enterprise storage systems with outstanding sequential read and writes performance to relieve performance bottlenecks associated with traditional rotating media HDD storage. Specifications Ordering Information Product Name Velocity XE 2.5” SSD SATA-II Density Part Number Flash Type aMLC 8GB AF8GSACD-RAAXX Density 8GB to 64GB 16GB AF16GSACD-RAAXX Sequential Read up to 250 MB/s 32GB AF32GSACD-RAAXX Sequential Write up to 180 MB/s 64GB AF64GSACD-RAAXX Performance Random Read IOPS up to 4,000 Interface SATA II 3 Gb/s Operating Temperature 0°C to +70°C Advanced Wear Leveling Reliability TBW** (max.) : 512 TB MTBF @ 25°C : >2,000,000 hours Dimensions: LxWxH (mm) 100.0 x 69.9 x 9.2 ** All TBW data listed are under highest random write value in each product line. The TBW data are subject to change by density, configuration and customers’ applications. SATA III SSDs - Velocity SII Pro Key Features • Ideal for heavy program/erase applications • High Performance with SATAIII interface • Enhanced endurance with Advanced Wear Leveling algorithm • Built-in hardware-based data protection technology during power failure – PowerProtector • NSA Compliant SecureErase • Supports S.M.A.R.T. ATA feature set • MIL-STD-810G compliant • AES encryption (optional) The ATP Velocity SII Pro 2.5” SSD with SATA III interface is a best-in-class widetemp industrial grade SLC SSD solution with enterprise-class features. SII Pro SSD offers outstanding performance and proven reliability, ideal for extreme performance, high data security, and consistent data integrity requirement (ATP PowerProtector technology), suited for POS, industrial computers, data center and industrial applications exposed to mission critical, high shock and vibration environments. Specifications Ordering Information Product Name Velocity SII Pro SSD 2.5” SATA-III Density Part Number Flash Type SLC 32GB AF32GSSCJ-VACXP Density 32GB to 256GB 64GB AF64GSSCJ-VACXP Sequential Read up to 520 MB/s 128GB AF128GSSCJ-VACXP Sequential Write up to 420 MB/s 256GB AF256GSSCJ-VACXP Performance Random Read IOPS up to 9,000 Interface SATA III 6 Gb/s Operating Temperature -40°C to +85°C Advanced Wear Leveling Reliability TBW** (max.) : 5,120 TB MTBF @ 25°C : >2,000,000 hours Dimensions: LxWxH (mm) 100.0 x 69.9 x 9.2 ** All TBW data listed are under highest random write value in each product line. The TBW data are subject to change by density, configuration and customers’ applications. SATA III SSDs - Velocity MV Key Features • Designed for enterprise applications requiring high endurance on MLC technology • High performance with SATA III Interface • Enhanced endurance with Advanced Wear Leveling algorithm • Built-in hardware-based data protection technology during power failure – PowerProtector • NSA Compliant SecureErase • Supports S.M.A.R.T. ATA feature set • MIL-STD-810G compliant • AES encryption (optional) Utilizing MLC (Multi Level Cell) NAND flash components, the ATP Velocity M V Enterprise Grade SSD is a best-in-class MLC SSD solution with enterprise- class features for cost-sensitive client environment. M V SSD offers outstanding performance and proven reliability, ideal for extreme performance, high data security, and consistent data integrity requirement, suited for POS, industrial computers, data center and industrial applications exposed to high shock and vibration environments. Specifications Ordering Information Product Name Velocity M V 2.5” SSD SATA-III Density Part Number Flash Type MLC 64GB AF64GSMCJ-VACXP Density 64GB to 512GB 128GB AF128GSMCJ-VACXP 256GB AF256GSMCJ-VACXP 512GB AF512GSMCJ-VACXP Sequential Read up to 520 MB/s Performance Sequential Write up to 440 MB/s Random Read IOPS up to 7,000 Interface SATA III 6 Gb/s Operating Temperature 0°C to 70°C ** All TBW data listed are under highest random write value in each product line. The TBW data are subject to change by density, configuration and customers’ applications. Advanced Wear Leveling Reliability TBW** (max.) : 307.2 TB MTBF @ 25°C : >2,000,000 hours Dimensions: LxWxH (mm) 100.0 x 69.9 x 9.2 ATP TAIWAN(HQ) ATP USA ATP EUROPE ATP JAPAN ATP CHINA TEL: +886-2-2659-6368 FAX: +886-2-2659-4982 sales-apac@atpinc.com TEL: +1-408-732-5000 FAX: +1-408-732-5055 sales@atpinc.com TEL: +49-89-374-9999-0 FAX: +49-89-374-9999-29 sales-europe@atpinc.com TEL: +81-3-6206-8097 FAX: +81-3-6206-8098 sales-japan@atpinc.com TEL: +86-21-5080-2220 FAX: +86-21-5080-2219 sales@cn.atpinc.com
AF128GSSCJ-OEM 价格&库存
很抱歉,暂时无法提供与“AF128GSSCJ-OEM”相匹配的价格&库存,您可以联系我们找货
