APM2T80P201064GAN-8TM
    APACERMEMORYAMERICA(宇瞻科技)
    Solid State Drive (SSD) 64GB SATA III FLASH - NAND (MLC) M.2 Module 3.3V
APM2T80P201064GAN-8TM 数据手册
RoHS Recast Compliant M.2 2280 Flash Drive P201-M Product Specifications December 23, 2014 Version 1.1 Apacer Technology Inc. 1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C Tel: +886-2-2267-8000 www.apacer.com Fax: +886-2-2267-2261 M.2 2280 Flash Drive APM2T80P201xxxxAN-xTM Features: Standard SATA Interface Compliance Serial ATA Revision 3.2 compliance SATA 6.0 Gbps interface ATA-8 command set Temperature ranges Operating: 0°C to 70°C Storage: -40°C to 85°C Supply voltage 3.3 V 5% Capacities 16, 32, 64, 128, 256 GB Power consumption (typical)* Active mode: 600 mA Idle mode: 90 mA Performance* Burst read/write: 600 MB/sec Sustained read: up to 515 MB/sec Sustained write: up to 180 MB/sec Connector type 75-pin SATA-based M.2 module pinout Form factor M.2 2280 form factor Dimensions: 80.00x22.00x3.80, unit: Flash Management Built-in hardware ECC, enabling up to 72 bit correction per 1K bytes Static/dynamic wear-leveling Flash bad-block management S.M.A.R.T. Power Failure Management ATA Secure Erase TRIM Shock & Vibration*** Shock:1500 G Vibration: 15 G MTBF: >2,000,000 hours SATA Power Management NAND Flash Type: MLC RoHS Recast compliant (complies with 2011/65/EU standard) Device Sleep mode (optional) *Varies from capacities. The values for performances and power consumptions presented are typical and may vary depending on flash configurations or platform settings. The term idle refers to the standby state of the device. **Non-operating 1 © 2014 Apacer Technology Inc. Rev. 1.1 M.2 2280 Flash Drive APM2T80P201xxxxAN-xTM Table of Contents 1. General Description .............................................................................. 3 2. Pin Assignments .................................................................................... 3 3. Product Specifications.......................................................................... 6 3.1 Capacity ............................................................................................................................................... 6 3.2 Performance ........................................................................................................................................ 6 3.3 Environmental Specifications .............................................................................................................. 7 3.4 Mean Time Between Failures (MTBF) ................................................................................................ 7 3.5 Certification and Compliance .............................................................................................................. 7 4. Flash Management ................................................................................ 8 4.1 Error Correction/Detection ................................................................................................................... 8 4.2 Bad Block Management ...................................................................................................................... 8 4.3 Wear Leveling ...................................................................................................................................... 8 4.4 Power Failure Management ................................................................................................................ 8 4.5 ATA Secure Erase ............................................................................................................................... 8 4.6 TRIM .................................................................................................................................................... 9 4.7 SATA Power Management .................................................................................................................. 9 5. Software Interface .............................................................................. 10 5.1 Command Set .................................................................................................................................... 10 5.2 S.M.A.R.T. ......................................................................................................................................... 11 6. Electrical Specification ...................................................................... 12 7. Physical Characteristics ..................................................................... 13 8. Product Ordering Information ............................................................. 14 8.1 Product Code Designations ............................................................................................................... 15 8.2 Valid Combinations ............................................................................................................................ 16 2 © 2014 Apacer Technology Inc. Rev. 1.1 M.2 2280 Flash Drive APM2T80P201xxxxAN-xTM 1. General Description P201-M is the next generation modularized Solid State Drive (SSD) with the shape of all new M.2 form factor, aimed to be the more suitable for mobile and compact computers with standard width at only 22.00 mm. P201-M appears in M.2 2280 mechanical dimensions and is believed to be the leading add-in storage solution for future host computing systems. The M.2 SSD is designed with SATA-based connector pinouts, providing full compliance with the latest SATA Revision 3.2 interface specifications. Aside from SATA compliance, P201-M delivers exceptional performance and power efficiency. On the other hand, the extreme thin and light form factor makes P201M the ideal choice for mobile computing systems, which appears to be the trend in near future. Regarding reliability, P201-M is built with a powerful SATA controller that supports on-the-module ECC as well as efficient wear leveling scheme. In terms of power efficiency, P201-M is compliant with SATA 6.0 Gbps interface standard so that it can operate on SATA power management modes, which greatly save on power consumption. 2. Pin Assignments This connector does not support hot plug capability. There are a total of 75 pins. 12 pin locations are used for mechanical key locations; this allows such a module to plug into both Key B and Key M connectors. Notch M Notch B Pin1 Pin Type Description 1 CONFIG_3 Ground (according to M.2 configurations for SSD-SATA definition) 2 3.3V Supply Pin, 3.3V 3 GND Ground 4 3.3V Supply pin, 3.3V 5 No connect No connect 6 Not available No connect (used for other purposes) 7 Not available No connect (used for other purposes) 8 Not available No connect (used for other purposes) 9 No connect No connect 10 DAS/DSS Device Activity Signal/Disable Staggered Spin-up 11 No connect No connect (used for other purposes) 12 (removed for key) Mechanical notch B 3 © 2014 Apacer Technology Inc. Rev. 1.1 M.2 2280 Flash Drive APM2T80P201xxxxAN-xTM 13 (removed for key) Mechanical notch B 14 (removed for key) Mechanical notch B 15 (removed for key) Mechanical notch B 16 (removed for key) Mechanical notch B 17 (removed for key) Mechanical notch B 18 (removed for key) Mechanical notch B 19 (removed for key) Mechanical notch B 20 Not available No connect (used for other purposes) 21 CONFIG_0 Ground (according to M.2 configurations for SSD-SATA definition) 22 Not available No connect (used for other purposes) 23 Not available No connect (used for other purposes) 24 Not available No connect (used for other purposes) 25 Not available No connect (used for other purposes) 26 Not available No connect (used for other purposes) 27 GND Ground 28 Not available No connect (used for other purposes) 29 PERn1 Not used 30 Not available No connect (used for other purposes) 31 PERp1 Not used 32 Not available No connect (used for other purposes) 33 GND Ground 34 Not available No connect (used for other purposes) 35 PETn1 Not used 36 Not available No connect (used for other purposes) 37 PETp1 Not used 38 DEVSLP Device Sleep, input. If driven high the host is informing the SSD to enter a low power state (optional) 39 GND Ground 40 Not available No connect (used for other purposes) 41 SATA-Rx+ Host receiver differential signal pair 42 Not available No connect (used for other purposes) 43 SATA-Rx- Host receiver differential signal pair 44 Not available No connect (used for other purposes) 45 GND Ground 46 Not available No connect (used for other purposes) 47 SATA-Tx- Host transmitter differential pair 48 Not available No connect (used for other purposes) 4 © 2014 Apacer Technology Inc. Rev. 1.1 M.2 2280 Flash Drive APM2T80P201xxxxAN-xTM 49 SATA-Tx+ Host transmitter differential pair 50 PERST# Not used 51 GND Ground 52 CLKREQ# Not used 53 REFCLKN Not used 54 PEWAKE# Not used 55 REFCLKP Not used 56 MFG1 Manufacturing pin. Use determined by vendor (no connect on a host) 57 GND Ground 58 MFG2 Manufacturing pin. Use determined by vendor (no connect on a host) 59 (removed for key) Mechanical notch B 60 (removed for key) Mechanical notch B 61 (removed for key) Mechanical notch B 62 (removed for key) Mechanical notch B 63 (removed for key) Mechanical notch B 64 (removed for key) Mechanical notch B 65 (removed for key) Mechanical notch B 66 (removed for key) Mechanical notch B 67 Not available No connect (used for other purposes) 68 SUSCLK Not used 69 CONFIG_1 Ground 70 3.3V Supply pin, 3.3V 71 GND Ground 72 3.3V Supply pin, 3.3V 73 GND Ground 74 3.3V Supply pin, 3.3V 75 CONFIG_2 Ground 5 © 2014 Apacer Technology Inc. Rev. 1.1 M.2 2280 Flash Drive APM2T80P201xxxxAN-xTM 3. Product Specifications 3.1 Capacity Capacity specification of P201-M is available as shown in Table 3-1. It lists the specific capacity and the default numbers of heads, sectors and cylinders for each product line. Table 3-1: Capacity specifications Capacity Total bytes* Cylinders Heads Sectors Max LBA 16 GB 16,013,942,784 16,383 16 63 31,277,232 32 GB 32,017,047,552 16,383 16 63 62,533,296 64 GB 64,023,257,088 16,383 16 63 125,045,424 128 GB 128,035,676,160 16,383 16 63 250,069,680 256 GB 256,060,514,304 16,383 16 63 500,118,192 *Display of total bytes varies from file systems, which means not all of the bytes can be used for storage. **Notes: 1 GB = 1,000,000,000 bytes; 1 sector = 512 bytes. LBA count addressed in the table above indicates total user storage capacity and will remain the same throughout the lifespan of the device. However, the total usable capacity of the SSD is most likely to be less than the total physical capacity because a small portion of the capacity is reserved for device maintenance usages. 3.2 Performance Performances of P201-M are listed below in table 3-2. Table 3-2: Performance Capacity 16 GB 32 GB 64 GB 128 GB 256 GB Sustained read (MB/s) 300 510 515 515 515 Sustained write (MB/s) 170 180 180 180 180 Performance Note: Results were measured by CrystalDiskMark and may differ from various flash configurations or host system setting 6 © 2014 Apacer Technology Inc. Rev. 1.1 M.2 2280 Flash Drive APM2T80P201xxxxAN-xTM 3.3 Environmental Specifications Environmental specification of P201-M series follows MIL-STD-810 standards as shown in Table 3-3. Table 3-3 P201-M environmental specifications Item Specification Operating temperature 0~70 Non-operating temperature -40~85 Operating humidity 40 Non-operating humidity 40 , 93%RH Frequency/Displacement: 20Hz~80Hz/1.52mm Frequency/Acceleration: 80Hz~2000Hz/20G X, Y, Z axis/60mins 1500G, 0.5ms Vibration (Non-operating) shock (Non-operating) Drop (Non-operating) , 90%RH Bending (non-operating) 80cm free fall, 6 face of each unit 20N, hold 1min/5times Torque (non-operating) 0.5N-m or 2.5 deg, hold 1min/5times ESD (Electrostatic) Passed (at relative temp/humidity: 24 , 49%RH) 3.4 Mean Time Between Failures (MTBF) Mean Time Between Failures (MTBF) is predicted based on reliability data for the individual components in P201-M. The prediction result for P201-M is more than 2,000,000 hours. Notes about the MTBF: The MTBF is predicated and calculated based on Telcordia Technologies Special Report, SR-332, Issue 2 method. 3.5 Certification and Compliance P201-M complies with the following standards: CE: EN55022 FCC :CISPR22 BSMI 13438 RoHS Recast 7 © 2014 Apacer Technology Inc. Rev. 1.1 M.2 2280 Flash Drive APM2T80P201xxxxAN-xTM 4. Flash Management 4.1 Error Correction/Detection P201-M implements a hardware ECC scheme, based on the BCH algorithm. It can detect and correct up to 72 bits error in 1K bytes. 4.2 Bad Block Management Current production technology is unable to guarantee total reliability of NAND flash memory array. When a flash memory device leaves factory, it comes with a minimal number of initial bad blocks during production or out-of-factory as there is no currently known technology that produce flash chips free of bad blocks. In addition, bad blocks may develop during program/erase cycles. When host performs program/erase command on a block, bad block may appear in Status Register. Since bad blocks are inevitable, the solution is to keep them in control. Apacer flash devices are programmed with ECC, block mapping technique and S.M.A.R.T to reduce invalidity or error. Once bad blocks are detected, data in those blocks will be transferred to free blocks and error will be corrected by designated algorithms. 4.3 Wear Leveling Flash memory devices differ from Hard Disk Drives (HDDs) in terms of how blocks are utilized. For HDDs, when a change is made to stored data, like erase or update, the controller mechanism on HDDs will perform overwrites on blocks. Unlike HDDs, flash blocks cannot be overwritten and each P/E cycle wears down the lifespan of blocks gradually. Repeatedly program/erase cycles performed on the same memory cells will eventually cause some blocks to age faster than others. This would bring flash storages to their end of service term sooner. Wear leveling is an important mechanism that level out the wearing of blocks so that the wearing-down of blocks can be almost evenly distributed. This will increase the lifespan of SSDs. Commonly used wear leveling types are Static and Dynamic. 4.4 Power Failure Management Power Failure Management plays a crucial role when experiencing unstable power supply. Power disruption may occur when users are storing data into the SSD. In this urgent situation, the controller would run multiple write-to-flash cycles to store the metadata for later block rebuilding. This urgent operation requires about several milliseconds to get it done. At the next power up, the firmware will perform a status tracking to retrieve the mapping table and resume previously programmed NAND blocks to check if there is any incompleteness of transmission. Note: The controller unit of this product model is designed with a DRAM as a write cache for improved performance and data efficiency. Though unlikely to happen in most cases, the data cached in the volatile DRAM might be potentially affected if a sudden power loss takes place before the cached data is flushed into non-volatile NAND flash memory. 4.5 ATA Secure Erase ATA Secure Erase is an ATA disk purging command currently embedded in most of the storage drives. Defined in ATA specifications, (ATA) Secure Erase is part of Security Feature Set that allows storage drives to erase all user data areas. The erase process usually runs on the firmware level as most of the ATA-based storage media currently in the market are built-in with this command. ATA Secure Erase can securely wipe out the user data in the drive and protects it from malicious attack. 8 © 2014 Apacer Technology Inc. Rev. 1.1 M.2 2280 Flash Drive APM2T80P201xxxxAN-xTM 4.6 TRIM TRIM, though in capital letters usually, is a memory computation command rather than an abbreviation. It is mainly a SATA command that enables the operating system to inform the SSD (Solid State Drive) which blocks of previously stored data are no longer valid, due to erases by the host or operating system, such as file deletions or disk formatting. Once notified, SSD will begin the discard of the invalid LBAs and retain more space for itself, in fact, the discarded is no longer recoverable. When an LBA is replaced by the operating system, as with overwrite of a file, the SSD is informed that the originally occupied LBA is determined as no longer in use or invalid. The SSD will not save those blocks in garbage collected sectors. Noticeably, a file deletion command by host or operating system never actually erases the actual content, rather, just the file is marked as deleted. This issue is even specifically noticeable for flash based memory devices, such as SSDs. In fact, an SSD will keep garbage collecting the invalid, previously occupied LBAs, if it is not informed that these LBAs can be erased. Thus, the SSD would experience a significant performance downfall. 4.7 SATA Power Management By complying with SATA 6.0 Gb/s specifications, the SSD supports the following SATA power saving modes: ACTIVE: PHY ready, full power, Tx & Rx operational PARTIAL: Reduces power, resumes in under 10 µs (microseconds) SLUMBER: Reduces power, resumes in under 10 ms (milliseconds) HIPM: Host-Initiated Power Management DIPM: Device-Initiated Power Management Device Sleep (DevSleep or DEVSLP): PHY powered down; power consumption 5 mW; host assertion time 10 ms; exit timeout from this state 20 ms (unless specified otherwise in SATA Identify Device Log). Note: 1. The behaviors of power management features would depend on host/device settings. 2. Device Sleep mode is optional, depending on product ordering selections. 9 © 2014 Apacer Technology Inc. Rev. 1.1 M.2 2280 Flash Drive APM2T80P201xxxxAN-xTM 5. Software Interface 5.1 Command Set This section defines the software requirements and the format of the commands the host sends to P201M. Commands are issued to P201-M by loading the required registers in the command block with the supplied parameters, and then writing the command code to the Command register. Table 6-1: Command set Command Code Command Code CHECK POWER MODE 98h 10h-1Fh SLEEP 99h Read Sectors 20h SMART B0h Read Sectors without Retry 21h DEVICE CONFIGURATION B1h Read Sectors EXT 24h Read Multiple C4h 25h Write Multiple C5h 27h Set Multiple Mode C6h Read Multiple EXT 29h Read DMA C8h Read Log EXT 2Fh Read DMA without Retry C9h Write Sectors 30h Write DMA CAh 31h Write DMA without Retry CBh Write Sectors EXT 34h Write Multiple FUA EXT CEh Write DMA EXT 35h Standby Immediate E0h Set Native Max Address EXT 37h Idle Immediate E1h 38h Standby E2h E3h Data Set Management Recalibrate Read DMA EXT Read Native Max Address EXT Write Sectors without Retry CFA WRITE SECTORS WITHOUT ERASE Write Multiple EXT 06h 39h IDLE Write DMA FUA EXT 3Dh Read Buffer E4h Write Long EXT 3Fh Check Power Mode E5h Read Verify Sectors 40h Sleep E6h E7h Read Verify Sectors without Retry 41h Flush Cache Read Verify Sectors EXT 42h Write Buffer E8h WRITE UNCORRECTABLE EXT 45h Flush Cache EXT EAh Read FPDMA Queued 60h Identify Device ECh Write FPDMA Queued 61h Set Features EFh Security Set Password F1h F2h Seek 70h-71h Execute Device Diagnostic 90h Security Unlock Initialize Device Parameters 91h Security Erase Prepare F3h Download Microcode 92h Security Erase Unit F4h 10 © 2014 Apacer Technology Inc. Rev. 1.1 M.2 2280 Flash Drive APM2T80P201xxxxAN-xTM DOWNLOAD MICROCODE DMA 93h Security Freeze Lock F5h STANDBY IMMEDIATE 94h Security Disable Password F6h IDLE IMMEDIATE 95h Read Native Max Address F8 STANDBY 96h Set Max Address F9 IDLE 97h 5.2 S.M.A.R.T. SMART, an acronym for Self-Monitoring, Analysis and Reporting Technology, is an open standard that allows a hard disk drive to automatically detect its health and report potential failures. When a failure is recorded by SMART, users can choose to replace the drive to prevent unexpected outage or data loss. Moreover, SMART can inform users of impending failures while there is still time to perform proactive actions, such as copy data to another device 11 © 2014 Apacer Technology Inc. Rev. 1.1 M.2 2280 Flash Drive APM2T80P201xxxxAN-xTM 6. Electrical Specification Table 6-1: Operating range Ambient Temperature Supply Voltage 0°C to +70°C 3.3V 5% (3.135-3.465V) Table 6-2: Typical power consumption Capacity Modes Active (mA) Idle (mA) 16 GB 32 GB 64 GB 128 GB 256 GB 355 85 470 85 445 90 535 90 600 90 Note: Results may differ from various flash configurations or host system setting 12 © 2014 Apacer Technology Inc. Rev. 1.1 M.2 2280 Flash Drive APM2T80P201xxxxAN-xTM 7. Physical Characteristics Unit: Tolerance: 0.2 13 © 2014 Apacer Technology Inc. Rev. 1.1 M.2 2280 Flash Drive APM2T80P201xxxxAN-xTM Unit: Tolerance: 0.2 14 © 2014 Apacer Technology Inc. Rev. 1.1 M.2 2280 Flash Drive APM2T80P201xxxxAN-xTM 8. Product Ordering Information 8.1 Product Code Designations AP M2 T80 P201 xxxx AN x TM Flash Type Version Control Apacer Brand Capacities: 016G = 032G = 064G = 128G = 256G = 16GB 32GB 64GB 128GB 256GB Solution version Form Factor M.2 Apacer Product Code 15 © 2014 Apacer Technology Inc. Rev. 1.1 M.2 2280 Flash Drive APM2T80P201xxxxAN-xTM 8.2 Valid Combinations Capacity No DEVSLP DEVSLP 16GB 32GB 64GB 128GB 256GB APM2T80P201016GAN-1TM APM2T80P201032GAN-1TM APM2T80P201064GAN-1TM APM2T80P201128GAN-1TM APM2T80P201256GAN-1TM APM2T80P201016GAN-2TM APM2T80P201032GAN-2TM APM2T80P201064GAN-2TM APM2T80P201128GAN-2TM APM2T80P201256GAN-2TM Note: Valid combinations are those products in mass production or will be in mass production. Consult your Apacer sales representative to confirm availability of valid combinations and to determine availability of new combinations. 16 © 2014 Apacer Technology Inc. Rev. 1.1 M.2 2280 Flash Drive APM2T80P201xxxxAN-xTM Revision History Revision Date Description Remark 1.0 10/28/2014 Official release 1.1 12/23/2014 Updated power consumption specification 17 © 2014 Apacer Technology Inc. Rev. 1.1 M.2 2280 Flash Drive APM2T80P201xxxxAN-xTM Global Presence Taiwan (Headquarters) Apacer Technology Inc. Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: 886-2-2267-8000 Fax: 886-2-2267-2261 amtsales@apacer.com U.S.A. Apacer Memory America, Inc. 386 Fairview Way, Suite102, Milpitas, CA 95035 Tel: 1-408-518-8699 Fax: 1-408-935-9611 sa@apacerus.com Japan Apacer Technology Corp. 5F, Matsura Bldg., Shiba, Minato-Ku Tokyo, 105-0014, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Europe Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-267-0000#6199 sales@apacer.nl China Apacer Electronic (Shanghai) Co., Ltd 1301, No.251,Xiaomuqiao Road, Shanghai, 200032, China Tel: 86-21-5529-0222 Fax: 86-21-5206-6939 sales@apacer.com.cn India Apacer Technologies Pvt Ltd, # 535, 1st Floor, 8th cross, JP Nagar 3rd Phase, Bangalore 560078, India Tel: 91-80-4152-9061 sales_india@apacer.com 18 © 2014 Apacer Technology Inc. Rev. 1.1
APM2T80P201064GAN-8TM 价格&库存
很抱歉,暂时无法提供与“APM2T80P201064GAN-8TM”相匹配的价格&库存,您可以联系我们找货
