SFSA240GV1AA4TO-I-HC-216-STD
    SWISSBIT
    SSD240GBSLIMMLCSATAIII5V
SFSA240GV1AA4TO-I-HC-216-STD 数据手册
Product Fact Sheet durabit™ Industrial SLIM SATA SSD (MO-297) “the better MLC” X-60s Series SATA III - 6.0 Gbit/s Product Fact Sheet Industrial MO-297 SLIM SATA SSD X-60s Series SATA III - 6.0Gbit/s X-60s Series – Industrial Slim SATA Solid State Drive Product Summary  Capacities: 30 GBytes, 60 GBytes, 120 GBytes, 240 GBytes, 480 GBytes  Form Factor: JEDEC MO-297 Slim SATA (54 mm x 39 mm x 4 mm)  Compliance: SATA Revision 3.1 - 6 Gbit/s (3 Gbit/s and 1.5 Gbit/s backward compatible)  Command Sets: Supports ATA/ATAPI-8 and ACS-2  Performance: o Read Performance: Sequential Read up to 520 MBytes/s, Random Read IOPs up to 75,000 o Write Performance: Sequential Write up to 450 MBytes/s, Random Write IOPs up to 75,000  Operating Temperature Range*: o Commercial: 0 °C to 70 °C o Industrial: -40 °C to 85 °C  Storage Temperature Range: -40 °C to 85 °C  Operating Voltage: 5 V ± 10% and 3.3 V ± 5%  Power (Max Capacity): o 3.3V: Read (Active): 1.5 W; Write (Active): 3.2 W; Idle: 380 mW; Slumber: 115 mW o 5V: Read (Active): 1.7 W (5 V); Write (Active): 3.7 W; Idle: 550 mW; Slumber: 275 mW  Data Retention: 10 Years @ Life Begin; 1 Year @ Life End  Endurance in TeraBytes Written (TBW) Max Capacity†: Client > 975; Embedded > 280; Enterprise > 235  Shock/Vibration: 500 g/20 g (MIL-STD810)  Hardware BCH Code ECC: up to 66 bit correction per 1 KByte page  Mean Time Between Failure: > 2,000,000 hours  Data Reliability: < 1 non-recoverable error per 1016 bits read Product Features  Best-in-Class Performance and Endurance with durabit™ Technology  Dynamic and Static Wear Leveling  Active and Passive Data Care Management  Lifetime Enhancements o Dynamic Bad Block Remapping o Write Amplification Reduction  On-Board Power Fail Protection  AHCI, TRIM, and NCQ Support  ATA Security Feature Set Support  In-Field Firmware Update  Enterprise-Grade Self-Monitoring, Analysis, and Reporting Technology (S.M.A.R.T.)  AES256 Encryption (on request)  Swissbit Life Time Monitoring (SBLTM) Tool and SDK for SBLTM (on request) Why Swissbit? Swissbit is focused on the design, development, manufacture, and support of leading edge memory and storage solutions for the worldwide OEM/ODM marketplace. As a global supplier, Swissbit recognizes and addressees the higher level of application requirements of today’s industrial, Netcom, and automotive customers by providing best-in-class products and services, with uncompromised attention to driving overall value and quality. * † Adequate airflow is required to ensure the drive temperature, as reported in the S.M.A.R.T. data, does not exceed the specified maximum operating temperature. According to JEDEC (JESD47I), the time to write the full TBW is 18 months. Higher average daily data volume reduces the specified TBW. Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Revision: 1.05 www.swissbit.com industrial@swissbit.com X-60s_fact_sheet_Rev105.docx Page 2 of 2
SFSA240GV1AA4TO-I-HC-216-STD 价格&库存
很抱歉,暂时无法提供与“SFSA240GV1AA4TO-I-HC-216-STD”相匹配的价格&库存,您可以联系我们找货
