APM2T80P201016GAN-GTM1W 数据手册
ġ
RoHS Recast Compliant
M.2 2280 Flash Drive
P201-M Product Specifications (Toshiba 15nm)
October 21, 2015
Version 1.0
Apacer Technology Inc.
1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C
Tel: +886-2-2267-8000
www.apacer.com
Fax: +886-2-2267-2261
APM2T80P201xxxGAN-XTM1X
Features:
z
Standard SATA Interface Compliance
– Serial ATA Revision 3.2 compliance
– SATA 6.0 Gbps interface
– ATA-8 command set
z
Capacities
– 16, 32, 64, 128, 256 GB
z
z
Performance*
– Burst read/write: 600 MB/sec
– Sustained read: up to 430 MB/sec
– Sustained write: up to 160 MB/sec
Flash Management
– Built-in hardware ECC
– Static/dynamic wear-leveling
– Flash bad-block management
– S.M.A.R.T.
– Power Failure Management
– ATA Secure Erase
– TRIM
z
NAND Flash Type: MLC
z
Endurance
– 16GB: 14 TBW
– 32GB: 28 TBW
– 64GB: 57 TBW
– 128GB: 114 TBW
– 256GB: 228 TBW
z
Temperature ranges
– Operating:
Standard :0°C to 70°C
Extended: -40°C to 85°C
– Storage: -40°C to 85°C
z
Supply voltage
– 3.3 V Ʋ 5%
z
Power consumption (typical)*
– Active mode: 450 mA
– Idle mode: 95 mA
z
Connector type
– 75-pin SATA-based M.2 module pinout
z
Form factor
– M.2 2280 form factor
– Dimensions: 80.00x22.00x3.80, unit: ϩ
z
Shock & Vibration***
– Shock:1,500 G
– Vibration: 15 G
z
MTBF: >2,000,000 hours
z
SATA Power Management
z
RoHS Recast compliant (complies with
2011/65/EU standard)
z
Device Sleep mode (optional)
*Varies from capacities. The values for performances and power consumptions presented are typical and may vary depending on flash configurations
or platform settings. The term idle refers to the standby state of the device.
**Non-operating
1
© 2015 Apacer Technology Inc.
Rev. 1.0
Table of Contents
1. General Description .............................................................................. 3
2. Pin Assignments .................................................................................... 3
3. Product Specifications.......................................................................... 6
3.1 Capacity ............................................................................................................................................... 6
3.2 Performance ........................................................................................................................................ 6
3.3 Environmental Specifications .............................................................................................................. 7
3.4 Mean Time Between Failures (MTBF) ................................................................................................ 7
3.5 Certification and Compliance .............................................................................................................. 7
4. Flash Management ................................................................................ 8
4.1 Error Correction/Detection ................................................................................................................... 8
4.2 Bad Block Management ...................................................................................................................... 8
4.3 Wear Leveling ...................................................................................................................................... 8
4.4 Power Failure Management ................................................................................................................ 8
4.5 ATA Secure Erase ............................................................................................................................... 8
4.6 TRIM .................................................................................................................................................... 9
4.7 SATA Power Management .................................................................................................................. 9
4.8 Endurance ......................................................................................................................................... 10
5. Software Interface .............................................................................. 11
5.1 Command Set .................................................................................................................................... 11
5.2 S.M.A.R.T. ......................................................................................................................................... 12
6. Electrical Specification ...................................................................... 13
7. Physical Characteristics ..................................................................... 14
8. Product Ordering Information ............................................................. 16
2
Rev. 1.0
Apacer’s P201-M is the next generation modularized Solid State Drive (SSD) with the shape of all new
M.2 form factor, aimed to be the more suitable for mobile and compact computers with standard width at
only 22.00 mm. P201-M appears in M.2 2280 mechanical dimensions and is believed to be the leading
add-in storage solution for future host computing systems.
The M.2 SSD is designed with SATA-based connector pinouts, providing full compliance with the latest
SATA Revision 3.2 interface specifications. Aside from SATA compliance, P201-M delivers exceptional
performance and power efficiency. On the other hand, the extreme thin and light form factor makes P201M the ideal choice for mobile computing systems, which appears to be the trend in near future.
Regarding reliability, P201-M is built with a powerful SATA controller that supports on-the-module ECC as
well as efficient wear leveling scheme. In terms of power efficiency, P201-M is compliant with SATA 6.0
Gbps interface standard so that it can operate on SATA power management modes, which greatly save
on power consumption.
2. Pin Assignments
This connector does not support hot plug capability. There are a total of 75 pins. 12 pin locations are used
for mechanical key locations; this allows such a module to plug into both Key B and Key M connectors.
Notch M
Notch B
Pin1
Pin
Type
Description
1
CONFIG_3
Ground (according to M.2 configurations for SSD-SATA definition)
2
3.3V
Supply Pin, 3.3V
3
GND
Ground
4
3.3V
Supply pin, 3.3V
5
No connect
No connect
6
Not available
No connect (used for other purposes)
7
Not available
8
Not available
9
No connect
No connect
10
DAS/DSS
Device Activity Signal/Disable Staggered Spin-up
11
No connect
12
(removed for key)
Mechanical notch B
3
Rev. 1.0
13
(removed for key)
Mechanical notch B
14
(removed for key)
Mechanical notch B
15
(removed for key)
Mechanical notch B
16
(removed for key)
Mechanical notch B
17
(removed for key)
Mechanical notch B
18
(removed for key)
Mechanical notch B
19
(removed for key)
Mechanical notch B
Not available
21
CONFIG_0
22
Not available
23
Not available
24
Not available
25
Not available
26
Not available
27
GND
Ground
28
Not available
29
PERn1
Not used
30
Not available
31
PERp1
Not used
32
Not available
33
GND
Ground
34
Not available
35
PETn1
Not used
36
Not available
37
PETp1
Not used
38
DEVSLP
Device Sleep, input. If driven high the host is informing the SSD to
enter a low power state (optional)
39
GND
Ground
40
Not available
41
SATA-Rx+
Host receiver differential signal pair
42
Not available
43
SATA-Rx-
44
Not available
45
GND
Ground
46
Not available
47
SATA-Tx-
Host transmitter differential pair
48
Not available
4
Rev. 1.0
49
SATA-Tx+
50
PERST#
Not used
51
GND
Ground
52
CLKREQ#
Not used
53
REFCLKN
Not used
54
PEWAKE#
Not used
55
REFCLKP
Not used
56
MFG1
Manufacturing pin. Use determined by vendor (no connect on a host)
57
GND
Ground
58
MFG2
59
(removed for key)
Mechanical notch M
60
(removed for key)
Mechanical notch M
61
(removed for key)
Mechanical notch M
62
(removed for key)
Mechanical notch M
63
(removed for key)
Mechanical notch M
64
(removed for key)
Mechanical notch M
65
(removed for key)
Mechanical notch M
66
(removed for key)
Mechanical notch M
67
Not available
68
SUSCLK
Not used
69
CONFIG_1
Ground
70
3.3V
Supply pin, 3.3V
71
GND
Ground
72
3.3V
Supply pin, 3.3V
73
GND
Ground
74
3.3V
Supply pin, 3.3V
75
CONFIG_2
Ground
5
Rev. 1.0
3.1 Capacity
Capacity specification of P201-M is available as shown in Table 3-1. It lists the specific capacity and the
default numbers of heads, sectors and cylinders for each product line.
Table 3-1: Capacity specifications
Capacity
Total bytes*
Cylinders
Heads
Sectors
Max LBA
16 GB
16,013,942,784
16,383
16
63
31,277,232
32 GB
32,017,047,552
16,383
16
63
62,533,296
64 GB
64,023,257,088
16,383
16
63
125,045,424
128 GB
128,035,676,160
16,383
16
63
250,069,680
256 GB
256,060,514,304
16,383
16
63
500,118,192
*Display of total bytes varies from file systems, which means not all of the bytes can be used for storage.
**Notes: 1 GB = 1,000,000,000 bytes; 1 sector = 512 bytes.
LBA count addressed in the table above indicates total user storage capacity and will remain the same throughout the lifespan of the
device. However, the total usable capacity of the SSD is most likely to be less than the total physical capacity because a small portion
of the capacity is reserved for device maintenance usages.
3.2 Performance
Performances of P201-M are listed below in table 3-2.
Table 3-2: Performance
Capacity
16 GB
32 GB
64 GB
128 GB
256 GB
Sustained read (MB/s)
215
230
415
410
430
Sustained write (MB/s)
150
130
155
160
160
Performance
Note: Results were measured by CrystalDiskMark and may differ from various flash configurations or host system setting
6
Rev. 1.0
Environmental specification of P201-M series follows MIL-STD-810 standards as shown in Table 3-3.
Table 3-3 P201-M environmental specifications
Item
Specification
Operating temperature
0°C ~70°C (standard) ; -40°C to 85°C(extended)
Non-operating temperature
-40°C ~85°C
Operating humidity
40°C90%RH
Non-operating humidity
40°C93%RH
Frequency/Displacement: 20Hz~80Hz/1.52mm
Frequency/Acceleration: 80Hz~2000Hz/20G
X, Y, Z axis/60mins
1500G, 0.5ms
Vibration (Non-operating)
shock (Non-operating)
Drop (Non-operating)
Bending (non-operating)
80cm free fall, 6 face of each unit
ʁ20N, hold 1min/5times
Torque (non-operating)
0.5N-m or Ʋ2.5 deg, hold 1min/5times
ESD (Electrostatic)
Passed (at relative temp/humidity: 24°C, 49%RH)
Mean Time Between Failures (MTBF) is predicted based on reliability data for the individual components
in P201-M. The prediction result for P201-M is more than 2,000,000 hours.
Notes about the MTBF:
The MTBF is predicated and calculated based on “Telcordia Technologies Special Report, SR-332, Issue
2” method.
P201-M complies with the following standards:
z
z
z
z
CE: EN55022
FCC :CISPR22
BSMI 13438
RoHS Recast
7
Rev. 1.0
4. Flash Management
P201-M implements a hardware ECC scheme, based on the BCH algorithm. It can detect and correct up
to 72 bits error in 1K bytes.
Current production technology is unable to guarantee total reliability of NAND flash memory array. When
a flash memory device leaves factory, it comes with a minimal number of initial bad blocks during
production or out-of-factory as there is no currently known technology that produce flash chips free of bad
blocks. In addition, bad blocks may develop during program/erase cycles. When host performs
program/erase command on a block, bad block may appear in Status Register. Since bad blocks are
inevitable, the solution is to keep them in control. Apacer flash devices are programmed with ECC, block
mapping technique and S.M.A.R.T to reduce invalidity or error. Once bad blocks are detected, data in
those blocks will be transferred to free blocks and error will be corrected by designated algorithms.
4.3 Wear Leveling
Flash memory devices differ from Hard Disk Drives (HDDs) in terms of how blocks are utilized. For HDDs,
when a change is made to stored data, like erase or update, the controller mechanism on HDDs will
perform overwrites on blocks. Unlike HDDs, flash blocks cannot be overwritten and each P/E cycle wears
down the lifespan of blocks gradually. Repeatedly program/erase cycles performed on the same memory
cells will eventually cause some blocks to age faster than others. This would bring flash storages to their
end of service term sooner. Wear leveling is an important mechanism that level out the wearing of blocks
so that the wearing-down of blocks can be almost evenly distributed. This will increase the lifespan of
SSDs. Commonly used wear leveling types are Static and Dynamic.
Power Failure Management plays a crucial role when experiencing unstable power supply. Power
disruption may occur when users are storing data into the SSD. In this urgent situation, the controller
would run multiple write-to-flash cycles to store the metadata for later block rebuilding. This urgent
operation requires about several milliseconds to get it done. At the next power up, the firmware will
perform a status tracking to retrieve the mapping table and resume previously programmed NAND blocks
to check if there is any incompleteness of transmission.
Note: The controller unit of this product model is designed with a DRAM as a write cache for improved performance and data
efficiency. Though unlikely to happen in most cases, the data cached in the volatile DRAM might be potentially affected if a sudden
power loss takes place before the cached data is flushed into non-volatile NAND flash memory.
ATA Secure Erase is an ATA disk purging command currently embedded in most of the storage drives.
Defined in ATA specifications, (ATA) Secure Erase is part of Security Feature Set that allows storage
drives to erase all user data areas. The erase process usually runs on the firmware level as most of the
ATA-based storage media currently in the market are built-in with this command. ATA Secure Erase can
securely wipe out the user data in the drive and protects it from malicious attack.
8
Rev. 1.0
4.6 TRIM
TRIM, though in capital letters usually, is a memory computation command rather than an abbreviation. It
is mainly a SATA command that enables the operating system to inform the SSD (Solid State Drive)
which blocks of previously stored data are no longer valid, due to erases by the host or operating system,
such as file deletions or disk formatting. Once notified, SSD will begin the discard of the invalid LBAs and
retain more space for itself, in fact, the discarded is no longer recoverable.
When an LBA is replaced by the operating system, as with overwrite of a file, the SSD is informed that the
originally occupied LBA is determined as no longer in use or invalid. The SSD will not save those blocks
in garbage collected sectors. Noticeably, a file deletion command by host or operating system never
actually erases the actual content, rather, just the file is marked as deleted. This issue is even specifically
noticeable for flash based memory devices, such as SSDs. In fact, an SSD will keep garbage collecting
the invalid, previously occupied LBAs, if it is not informed that these LBAs can be erased. Thus, the SSD
would experience a significant performance downfall.
By complying with SATA 6.0 Gb/s specifications, the SSD supports the following SATA power saving
modes:
y
ACTIVE: PHY ready, full power, Tx & Rx operational
y
PARTIAL: Reduces power, resumes in under 10 μs (microseconds)
y
SLUMBER: Reduces power, resumes in under 10 ms (milliseconds)
y
HIPM: Host-Initiated Power Management
y
DIPM: Device-Initiated Power Management
y
Device Sleep (DevSleep or DEVSLP): PHY powered down; power consumption ʀ 5 mW; host
assertion time ʀ 10 ms; exit timeout from this state ʀ 20 ms (unless specified otherwise in SATA
Identify Device Log).
Note:
1. The behaviors of power management features would depend on host/device settings.
2. Device Sleep mode is optional, depending on product ordering selections.
9
Rev. 1.0
4.8 Endurance
The endurance of a storage device is predicted by TeraBytes Written based on several factors related to
usage, such as the amount of data written into the drive, block management conditions, and daily
workload for the drive. Thus, key factors, such as Write Amplifications and the number of P/E cycles, can
influence the lifespan of the drive.
Capacity
TeraBytes Written
16 GB
14
32 GB
28
64 GB
57
128 GB
114
256 GB
228
Notes:
y
The measurement assumes the data written to the SSD for test is under a typical and constant rate.
y
The measurement follows the standard metric: 1 TB (Terabyte) = 1000 GB.
y
This estimation complies with JEDEC JESD-219, enterprise endurance workload of random data
with payload size distribution.
10
Rev. 1.0
5.1 Command Set
This section defines the software requirements and the format of the commands the host sends to P201M. Commands are issued to P201-M by loading the required registers in the command block with the
supplied parameters, and then writing the command code to the Command register.
Table 6-1: Command set
Command
Code
Command
Code
CHECK POWER MODE
98h
10h-1Fh
SLEEP
99h
Read Sectors
20h
SMART
B0h
Read Sectors without Retry
21h
DEVICE CONFIGURATION
B1h
Read Sectors EXT
24h
Read Multiple
C4h
25h
Write Multiple
C5h
Read Native Max Address EXT
27h
Set Multiple Mode
C6h
Read Multiple EXT
29h
Read DMA
C8h
Read Log EXT
2Fh
Read DMA without Retry
C9h
Write Sectors
30h
Write DMA
CAh
31h
Write DMA without Retry
CBh
Write Sectors EXT
34h
Write Multiple FUA EXT
CEh
Write DMA EXT
35h
Standby Immediate
E0h
Set Native Max Address EXT
37h
Idle Immediate
E1h
38h
Standby
E2h
E3h
Data Set Management
Recalibrate
Read DMA EXT
Write Sectors without Retry
CFA WRITE SECTORS WITHOUT ERASE
Write Multiple EXT
06h
39h
IDLE
Write DMA FUA EXT
3Dh
Read Buffer
E4h
Write Long EXT
3Fh
Check Power Mode
E5h
Read Verify Sectors
40h
Sleep
E6h
41h
Flush Cache
E7h
E8h
Read Verify Sectors without Retry
Read Verify Sectors EXT
42h
Write Buffer
WRITE UNCORRECTABLE EXT
45h
Flush Cache EXT
EAh
Read FPDMA Queued
60h
Identify Device
ECh
Write FPDMA Queued
61h
Set Features
EFh
Security Set Password
F1h
F2h
Seek
70h-71h
Execute Device Diagnostic
90h
Security Unlock
Initialize Device Parameters
91h
Security Erase Prepare
F3h
Download Microcode
92h
Security Erase Unit
F4h
11
Rev. 1.0
DOWNLOAD MICROCODE DMA
93h
Security Freeze Lock
F5h
STANDBY IMMEDIATE
94h
Security Disable Password
F6h
IDLE IMMEDIATE
95h
F8
STANDBY
96h
Set Max Address
F9
IDLE
97h
5.2 S.M.A.R.T.
SMART, an acronym for Self-Monitoring, Analysis and Reporting Technology, is an open standard that
allows a hard disk drive to automatically detect its health and report potential failures. When a failure is
recorded by SMART, users can choose to replace the drive to prevent unexpected outage or data loss.
Moreover, SMART can inform users of impending failures while there is still time to perform proactive
actions, such as copy data to another device
12
Rev. 1.0
Table 6-1: Operating range
Ambient Temperature
0°C to 70°C(standard)
Supply Voltage
3.3VƲ5% (3.135-3.465V)
Table 6-2: Typical power consumption
Capacity
16 GB
32 GB
64 GB
128 GB
256 GB
Active (mA)
300
315
360
440
450
Idle (mA)
85
85
95
95
95
Modes
Note: Results may differ from various flash configurations or host system setting
13
Rev. 1.0
8QLWᓔ
7ROHUDQFHs ᓔ
14
Rev. 1.0
8QLWᓔ
7ROHUDQFHs ᓔ
15
Rev. 1.0
8.1
Product Code Designations
$3073[[[*$1ದ ;70
X
Temperature Range
Blank: Standard
W: Extended Temperature
Flash Type
Version Control
Apacer Brand
Capacities:
016G = 16GB
032G = 32GB
064G = 64GB
128G = 128GB
256G = 256GB
Solution version
Form Factor
M.2
Apacer Product Code
16
Rev. 1.0
8.2
Valid Combinations
8.2.1 Standard Temperature
Capacity
No DEVSLP
DEVSLP
16GB
APM2T80P201016GAN-HTM1
32GB
64GB
APM2T80P201032GAN-GTM1
APM2T80P201064GAN-GTM1
APM2T80P201032GAN-HTM1
APM2T80P201064GAN-HTM1
128GB
256GB
APM2T80P201128GAN-GTM1
APM2T80P201256GAN-GTM1
APM2T80P201128GAN-HTM1
APM2T80P201256GAN-HTM1
8.2.2 Extended Temperature
Capacity
No DEVSLP
DEVSLP
16GB
APM2T80P201016GAN-GTM1W APM2T80P201016GAN-HTM1W
32GB
64GB
APM2T80P201032GAN-GTM1W APM2T80P201032GAN-HTM1W
APM2T80P201064GAN-GTM1W APM2T80P201064GAN-HTM1W
128GB
APM2T80P201128GAN-GTM1W APM2T80P201128GAN-HTM1W
256GB
APM2T80P201256GAN-GTM1W APM2T80P201256GAN-HTM1W
Note: Valid combinations are those products in mass production or will be in mass production. Consult
your Apacer sales representative to confirm availability of valid combinations and to determine availability
of new combinations.
17
Rev. 1.0
Revision History
Revision
1.0
Date
Description
10/21/2015
Official release
Remark
18
Rev. 1.0
