APM2T42P100008GAN-7T 数据手册
RoHS Recast Compliant
M.2 2242 Flash Drive
P100 Product Specifications
June 30, 2015
Version 1.2
Apacer Technology Inc.
1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C
Tel: +886-2-2267-8000
www.apacer.com
Fax: +886-2-2267-2261
APM2T42P100xxxxAN-XTX
Features:
Compliance with SATA Interface
– Serial ATA Revision 3.1
– SATA 6.0 Gbps
– ATA-8 command set
– Backward compatible with SATA 1.5/3.0
Gbps
Capacities
– 4, 8, 16, 32, 64 GB
Performance*
– Interface burst read/write: 600 MB/sec
– Sustained read: up to 500 MB/sec
– Sustained write: up to 150 MB/sec
Flash Management
– Built-in hardware ECC
– Static/dynamic wear-leveling
– Flash bad-block management
– S.M.A.R.T.
– Power Failure Management
– ATA Secure Erase
– TRIM
NAND Flash Type: SLC
Endurance
– 4 GB: 4 TBW
– 8 GB: 7 TBW
– 16 GB:14 TBW
– 32GB: 28 TBW
– 64GB: 56 TBW
Temperature ranges
– Operating:
Standard: 0°C to 70°C
Extended: -40°C to +85°C
– Storage: -40°C to 100°C
Supply voltage
– 3.3 V ± 5%
Power consumption (typical)*
– Active mode: 440 mA
– Idle mode: 105 mA
Connector type
– 75-pin SATA-based M.2 module pinout
Form factor
– M.2 2242 form factor
– Dimensions: 42.00x22.00x3.65, unit: mm
Shock & Vibration**
– Shock:1500 G
– Vibration: 15 G
MTBF: >2,000,000 hours
SATA Power Management
Device Sleep mode (optional)
RoHS Recast compliant (complies with
2011/65/EU standard)
*Varies from capacities. The values for performances and power consumptions presented are typical and may vary depending on flash configurations
or platform settings. The term idle refers to the standby state of the device.
**Non-operating
1
© 2015 Apacer Technology Inc.
Rev. 1.2
Table of Contents
1. GENERAL DESCRIPTION .................................................................................................... 3
2. PIN ASSIGNMENTS ............................................................................................................... 3
3. PRODUCT SPECIFICATIONS .............................................................................................. 6
3.1 CAPACITY ............................................................................................................................................................. 6
3.2 PERFORMANCE .....................................................................................................................................................6
3.3 ENVIRONMENTAL SPECIFICATIONS .......................................................................................................................7
3.4 MEAN TIME BETWEEN FAILURES (MTBF) ...........................................................................................................7
3.5 CERTIFICATION AND COMPLIANCE .......................................................................................................................7
4. FLASH MANAGEMENT ....................................................................................................... 8
4.1 ERROR CORRECTION/DETECTION .........................................................................................................................8
4.2 BAD BLOCK MANAGEMENT .................................................................................................................................8
4.3 WEAR LEVELING ..................................................................................................................................................8
4.4 POWER FAILURE MANAGEMENT........................................................................................................................... 8
4.5 ATA SECURE ERASE ............................................................................................................................................8
4.6 TRIM ...................................................................................................................................................................8
4.7 SATA POWER MANAGEMENT .............................................................................................................................. 9
4.8 ENDURANCE .........................................................................................................................................................9
5. SOFTWARE INTERFACE .................................................................................................. 10
5.1 COMMAND SET ................................................................................................................................................... 10
5.2 S.M.A.R.T.......................................................................................................................................................... 11
6. ELECTRICAL SPECIFICATION ...................................................................................... 12
7. MECHANICAL SPECIFICATIONS .................................................................................. 13
7.1 DIMENSIONS ...................................................................................................................................................... 13
8. PRODUCT ORDERING INFORMATION ........................................................................ 14
2
Rev. 1.2
1. General Description
Apacer P100 is the next generation modularized Solid State Drive (SSD) with the shape of all new M.2
form factor, with the aim to be the more suitable for mobile and compact computers with standard width at
only 22.00 mm. P100 appears in M.2 2242 mechanical dimensions and is believed to be the leading addin storage solution for future host computing systems.
The M.2 SSD is designed with SATA-based connector pinouts, providing full compliance with the latest
SATA Revision 3.1 interface specifications. Aside from SATA compliance, P100 delivers exceptional
performance and power efficiency. On the other hand, the extreme thin and light form factor makes P100
the ideal choice for mobile computing systems, which appears to be the trend in near future.
Regarding reliability, P100 is built with a powerful SATA controller that supports on-the-module ECC as
well as efficient wear leveling scheme. Since it is operating under SATA 6.0 Gbps interface, P100 is
provided with Apacer latest S.M.A.R.T. that are primarily oriented for the latest SATA interface SSD, for
drive lifetime monitoring and analyzing.
2. Pin Assignments
This connector does not support hot plug capability. There are a total of 75 pins. 12 pin locations are used
for mechanical key locations; this allows such a module to plug into both Key B and Key M connectors.
Notch B
Notch M
Pin1
Pin
Type
Description
1
CONFIG_3
Ground (according to M.2 configurations for SSD-SATA definition)
2
3.3V
Supply Pin, 3.3V
3
GND
Ground
4
3.3V
Supply pin, 3.3V
5
No connect
No connect
6
Not available
No connect (used for other purposes)
7
Not available
3
Rev. 1.2
8
Not available
9
No connect
No connect
10
DAS/DSS
Device Activity Signal/Disable Staggered Spin-up
11
No connect
12
(removed for key)
Mechanical notch B
13
(removed for key)
Mechanical notch B
14
(removed for key)
Mechanical notch B
15
(removed for key)
Mechanical notch B
16
(removed for key)
Mechanical notch B
17
(removed for key)
Mechanical notch B
18
(removed for key)
Mechanical notch B
19
(removed for key)
Mechanical notch B
Not available
21
CONFIG_0
22
Not available
23
Not available
24
Not available
25
Not available
26
Not available
27
GND
Ground
28
Not available
29
PERn1
Not used
30
Not available
31
PERp1
Not used
32
Not available
33
GND
Ground
34
Not available
35
PETn1
Not used
36
Not available
37
PETp1
Not used
38
DEVSLP
Device Sleep, input. If driven high the host is informing the SSD to
enter a low power state
39
GND
Ground
40
Not available
41
SATA-Rx+
Host receiver differential signal pair
42
Not available
43
SATA-Rx-
4
Rev. 1.2
44
Not available
45
GND
Ground
46
Not available
47
SATA-Tx-
Host transmitter differential pair
48
Not available
49
SATA-Tx+
50
PERST#
Not used
51
GND
Ground
52
CLKREQ#
Not used
53
REFCLKN
Not used
54
PEWAKE#
Not used
55
REFCLKP
Not used
56
MFG1
Manufacturing pin. Use determined by vendor (no connect on a host)
57
GND
Ground
58
MFG2
59
(removed for key)
Mechanical notch M
60
(removed for key)
Mechanical notch M
61
(removed for key)
Mechanical notch M
62
(removed for key)
Mechanical notch M
63
(removed for key)
Mechanical notch M
64
(removed for key)
Mechanical notch M
65
(removed for key)
Mechanical notch M
66
(removed for key)
Mechanical notch M
67
Not available
68
SUSCLK
Not used
69
CONFIG_1
Ground
70
3.3V
Supply pin, 3.3V
71
GND
Ground
72
3.3V
Supply pin, 3.3V
73
GND
Ground
74
3.3V
Supply pin, 3.3V
75
CONFIG_2
Ground
5
Rev. 1.2
3. Product Specifications
3.1 Capacity
Capacity specification of P100 is available as shown in Table 3-1. It lists the specific capacity and the
default numbers of heads, sectors and cylinders for each product line.
Table 3-1: Capacity specifications
Capacity
Total bytes*
Cylinders
Heads
Sectors
Max LBA
4 GB
4,011,614,208
15,525
16
63
7,835,184
8 GB
8,012,390,400
15,525
16
63
15,649,200
16 GB
16,013,942,784
16,383
16
63
31,277,232
32 GB
32,017,047,552
16,383
16
63
62,533,296
64 GB
64,023,257,088
16,383
16
63
125,045,424
*Display of total bytes varies from file systems, which means not all of the bytes can be used for storage.
**Notes: 1 GB = 1,000,000,000 bytes; 1 sector = 512 bytes.
LBA count addressed in the table above indicates total user storage capacity and will remain the same throughout the lifespan of the
device. However, the total usable capacity of the SSD is most likely to be less than the total physical capacity because a small portion
of the capacity is reserved for device maintenance usages.
3.2 Performance
Performances of P100 are listed below in table 3-2.
Table 3-2: Performance
Capacity
4 GB
8 GB
16 GB
32 GB
64 GB
Sustained read (MB/s)
30
285
500
500
500
Sustained write (MB/s)
25
85
145
150
150
Performance
Note: Results may differ from various flash configurations or host system setting
6
Rev. 1.2
3.3 Environmental Specifications
Environmental specification of P100 series follows MIL-STD-810, as shown in Table 3-3.
Table 3-3 P100 environmental specifications
Item
Specification
Temperature
0°C to 70°C (Operating) / -40°C to +85°C (Extended)
-40°C to 85°C (in storage)
Humidity
RH 90% under 40°C
Shock
Bending
1500G, 0.5ms
20Hz~80Hz/1.52mm (frequency/displacement)
80Hz~2000Hz/20G (frequency/displacement)
X, Y, Z axis/60mins each
80cm free fall, 6 face of each
≧20N, hold 1min/5times
Torque
0.5N-m or 5deg, hold 5min/5times
ESD
Pass
Vibration
Drop
3.4 Mean Time Between Failures (MTBF)
Mean Time Between Failures (MTBF) is predicted based on reliability data for the individual components
in P100. The prediction result for P100 is more than 2,000,000 hours.
Notes about the MTBF:
The MTBF is predicated and calculated based on “Telcordia Technologies Special Report, SR-332, Issue
2” method.
3.5 Certification and Compliance
P100 complies with the following standards:
CE
FCC
RoHS Recast
MIL-STD-810
BSMI
7
Rev. 1.2
4. Flash Management
4.1 Error Correction/Detection
P100 implements a hardware ECC scheme, based on the BCH algorithm. It can detect and correct up to
72 bits error in 1K bytes.
4.2 Bad Block Management
Bad blocks are blocks that include one or more invalid bits, and their reliability is not guaranteed. Blocks
that are identified and marked as bad by the manufacturer are referred to as “Initial Bad Blocks”. Bad
blocks that are developed during the lifespan of the flash are named “Later Bad Blocks”. Apacer
implements an efficient bad block management algorithm to detect the factory-produced bad blocks and
manages any bad blocks that appear with use. This practice further prevents data being stored into bad
blocks and improves the data reliability.
4.3 Wear Leveling
NAND flash devices can only undergo a limited number of program/erase cycles, and in most cases, the
flash media are not used evenly. If some areas get updated more frequently than others, the lifetime of
the device would be reduced significantly. Thus, Wear Leveling is applied to extend the lifespan of NAND
flash by evenly distributing write and erase cycles across the media.
Apacer provides advanced Wear Leveling algorithm, which can efficiently spread out the flash usage
through the whole flash media area. Moreover, by implementing both dynamic and static Wear Leveling
algorithms, the life expectancy of the NAND flash is greatly improved.
4.4 Power Failure Management
Power Failure Management plays a crucial role when experiencing unstable power supply. Power
disruption may occur when users are storing data into the SSD. In this urgent situation, the controller
would run multiple write-to-flash cycles to store the metadata for later block rebuilding. This urgent
operation requires about several milliseconds to get it done. At the next power up, the firmware will
perform a status tracking to retrieve the mapping table and resume previously programmed NAND blocks
to check if there is any incompleteness of transmission.
4.5 ATA Secure Erase
ATA Secure Erase is a standard ATA command and will write all “0xFF” to fully wipe all the data on hard
drives and SSDs. When this command is issued, the SSD controller will empty its storage blocks and
return to its factory default settings.
4.6 TRIM
TRIM is a feature which helps improve the read/write performance and speed of solid-state drives (SSD).
Unlike hard disk drives (HDD), SSDs are not able to overwrite existing data, so the available space
gradually becomes smaller with each use. With the TRIM command, the operating system can inform the
8
Rev. 1.2
SSD which blocks of data are no longer in use and can be removed permanently. Thus, the SSD will
perform the erase action, which prevents unused data from occupying blocks all the time.
4.7 SATA Power Management
By complying with SATA 6.0 Gb/s specifications, the SSD supports the following SATA power saving
modes:
ACTIVE: PHY ready, full power, Tx & Rx operational
PARTIAL: Reduces power, resumes in under 10 µs (microseconds)
SLUMBER: Reduces power, resumes in under 10 ms (milliseconds)
HIPM: Host-Initiated Power Management
DIPM: Device-Initiated Power Management
AUTO-SLUMBER: Automatic transition from partial to slumber.
Device Sleep (DevSleep or DEVSLP): PHY powered down; power consumption ≦ 5 mW; host
assertion time ≦ 10 ms; exit timeout from this state ≦ 20 ms (unless specified otherwise in SATA
Identify Device Log).
Note:
1. The behaviors of power management features would depend on host/device settings.
2. Device Sleep mode is optional, depending on product ordering selections.
4.8 Endurance
The endurance of a storage device is predicted by Tera Bytes Written based on several factors related to
usage, such as the amount of data written into the drive, block management conditions, and daily
workload for the drive. Thus, key factors, such as Write Amplifications and the number of P/E cycles, can
influence the lifespan of the drive.
Capacity
Tera Bytes Written
4 GB
4
8 GB
7
16 GB
14
32 GB
28
64 GB
57
Notes:
The measurement assumes the data written to the SSD for test is under a typical and constant rate.
The measurement follows the standard metric: 1 TB (Terabyte) = 1000 GB.
This estimation complies with JEDEC JESD-219, enterprise endurance workload of random data
with payload size distribution.
9
Rev. 1.2
5. Software Interface
5.1 Command Set
This section defines the software requirements and the format of the commands the host sends to P100.
Commands are issued to P100 by loading the required registers in the command block with the supplied
parameters, and then writing the command code to the Command register.
Table 5-1: Command set
Command
Code
Command
Code
NOP
00h
Idle
97h
Data Set Management
06h
Check Power Mode
98h
Sleep
99h
Recalibrate
10f-1Fh
Read Sectors
20h
SMART
B0h
Read Sectors without Retry
21h
Device Configuration
B1h
Read Sectors EXT
24h
Read Multiple
C4h
Read DMA EXT
25h
Write Multiple
C5h
Read Native Max Address EXT
27h
Set Multiple Mode
C6h
Read Multiple EXT
29h
Read DMA
C8h
Read Log EXT
2Fh
Read DMA without Retry
C9h
Write Sectors
30h
Write DMA
CAh
Write Sectors Without Retry
31h
Write DMA without Retry
CBh
Write Sectors EXT
34h
Write Multiple FUA EXT
CEh
Write DMA EXT
35h
Standby Immediate
E0h
Set Native Max Address EXT
37h
Idle Immediate
E1h
CFA Write Sectors without erase
38h
Standby
E2h
Write Multiple EXT
39h
Idle
E3h
Write DMA FUA EXT
3Dh
Read Buffer
E4h
Write Long EXT
3Fh
Check Power Mode
E5h
Read Verify Sectors
40h
Sleep
E6h
Read Verify Sectors without Retry
41h
Flush Cache
E7h
Read Verify Sectors EXT
42h
Write Buffer
E8h
Write Uncorrectable EXT
45h
Flush Cache EXT
EAh
Read FPDMA Queued
60h
Identify Device
ECh
Write FPDMA Queued
61h
Set Features
EFh
Security Set Password
F1h
Seek
70h-7Fh
Execute Device Diagnostic
90h
Security Unlock
F2h
Initialize Device Parameters
91h
Security Erase Prepare
F3h
10
Rev. 1.2
Download Microcode
92h
Security Erase Unit
F4h
Download Microcode DMA
93h
Security Freeze Lock
F5h
Standby Immediate
94h
Security Disable Password
F6h
Idle Immediate
95h
F8h
Standby
96h
Set Max Address
F9h
5.2 S.M.A.R.T.
SMART, an acronym for Self-Monitoring, Analysis and Reporting Technology, is an open standard that
allows a hard disk drive to automatically detect its health and report potential failures. When a failure is
recorded by SMART, users can choose to replace the drive to prevent unexpected outage or data loss.
Moreover, SMART can inform users of impending failures while there is still time to perform proactive
actions, such as copy data to another device.
11
Rev. 1.2
6. Electrical Specification
Table 6-1: Operating range
Ambient Temperature
Supply Voltage
0°C to +85°C
3.3V±5% (3.135-3.465V)
Table 6-2: Typical power consumption
Capacity
Modes
Active (mA)
4 GB
8 GB
16 GB
32 GB
64 GB
235
320
320
410
440
100
100
100
100
105
Idle (mA)
12
Rev. 1.2
7. Mechanical Specifications
7.1 Dimensions
Unit: ㎜
Tolerance: ± 0.25
13
Rev. 1.2
8. Product Ordering Information
8.1
AP
Product Code Designations
M2
T42
P100
x x x x AN – X
T
X
Temperature Range
Blank: Standard
W: Extended Temperature
Flash Type
Version Control
Apacer Brand
Capacities:
004G =
008G =
016G =
032G =
064G =
4GB
8GB
16GB
32GB
64GB
Solution version
Form Factor
M.2
Apacer Product Code
14
Rev. 1.2
8.2
Valid Combinations
8.2.1 Standard Temperature
Capacity
No DEVSLP
4GB
8GB
16GB
APM2T42P100004GAN-7T
APM2T42P100016GAN-7T
32GB
64GB
APM2T42P100032GAN-7T
APM2T42P100064GAN-7T
8.2.2 Extended Temperature
Capacity
4GB
8GB
16GB
32GB
64GB
No DEVSLP
APM2T42P100004GAN-7TW
APM2T42P100008GAN-7TW
APM2T42P100016GAN-7TW
APM2T42P100032GAN-7TW
APM2T42P100064GAN-7TW
Note: Valid combinations are those products in mass production or will be in mass production. Consult
your Apacer sales representative to confirm availability of valid combinations and to determine availability
of new combinations.
15
Rev. 1.2
Revision History
Revision
Date
Description
Remark
0.1
11/03/2014
Preliminary release
1.0
12/05/2014
Official release
1.1
06/18/2015
- Revised dimension of feature page:
42.00x22.00x3.75->42.00x22.00x3.65
- Changed power consumption unit: mW->mA
1.2
06/20/2015
- Added 4GB support
- Revised product ordering information
16
Rev. 1.2
Global Presence
Taiwan (Headquarters)
1F., No.32, Zhongcheng Rd., Tucheng Dist.,
New Taipei City 236, Taiwan R.O.C.
Tel: 886-2-2267-8000
Fax: 886-2-2267-2261
amtsales@apacer.com
U.S.A.
Apacer Memory America, Inc.
386 Fairview Way, Suite102,
Milpitas, CA 95035
Tel: 1-408-518-8699
Fax: 1-408-935-9611
sa@apacerus.com
Japan
Apacer Technology Corp.
5F, Matsura Bldg., Shiba, Minato-Ku
Tokyo, 105-0014, Japan
Tel: 81-3-5419-2668
Fax: 81-3-5419-0018
jpservices@apacer.com
Europe
Apacer Technology B.V.
Science Park Eindhoven 5051 5692 EB Son,
The Netherlands
Tel: 31-40-267-0000
Fax: 31-40-267-0000#6199
sales@apacer.nl
China
Apacer Electronic (Shanghai) Co., Ltd
1301, No.251,Xiaomuqiao Road, Shanghai,
200032, China
Tel: 86-21-5529-0222
Fax: 86-21-5206-6939
sales@apacer.com.cn
India
Apacer Technologies Pvt Ltd,
# 535, 1st Floor, 8th cross, JP Nagar 3rd Phase,
Bangalore – 560078, India
Tel: 91-80-4152-9061
sales_india@apacer.com
17
Rev. 1.2
