APM016GM1AN-2TW
APM016GM1AN-2TW
    APACERMEMORYAMERICA(宇瞻科技)
    SSD16GBMSATASLCSATAIII3.3V
APM016GM1AN-2TW 数据手册
RoHS Compliant Serial ATA Flash Drive mSATA H1 Product Specifications July 13, 2015 Version 1.0 Apacer Technology Inc. 1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C Tel: +886-2-2267-8000 www.apacer.com http://www.apacer.com http://www.apacer.com Fax: +886-2-2267-2261 mSATA Flash Drive APMxxxxM1XX-2TX Features:  Compliance with SATA Revision 3.1 – SATA 6.0 Gbps interface – Backward compatible with SATA 1.5/3.0 Gbps interfaces – ATA command set  Temperature ranges – Operating: Standard: 0°C to 70°C Extended: -40°C to 85°C – Storage: -40°C to 100°C  Capacities – 1, 2, 4, 8,16, 32, 64 GB  Supply voltage – 3.3 V ± 5%  Performance* – Interface burst read/write: 600 MB/sec – Sustained read: up to 130 MB/sec – Sustained write: up to 110 MB/sec  Power consumption (typical)* – Active mode: 380 mA – Idle mode: 100 mA  Form factor – JEDEC MO-300 – Dimensions (50.80 x 29.85 x 1.00, unit: ㎜)  Connector – 52-pin mSATA signal connector  RoHS compliant  Thermal sensor (optional)   Flash Management – Built-in hardware ECC – Wear leveling – Bad block management – S.M.A.R.T. – Power Failure Management – TRIM NAND Flash Type: SLC *Varies from capacities. The values addressed here are typical and may vary depending on host system settings. 1 © 2015 Apacer Technology Inc. Rev. 1.1 mSATA Flash Drive APMxxxxM1XX-2TX Table of Contents 1. Product Description ............................................................................................ 3 1.1 1.2 1.3 1.4 Introduction .................................................................................................................................. 3 Capacity Specification ................................................................................................................. 3 Performance ................................................................................................................................. 3 Pin Assignments .......................................................................................................................... 4 2. Software Interface ............................................................................................... 5 2.1 Command Set ............................................................................................................................... 5 2.2 S.M.A.R.T....................................................................................................................................... 5 3. Flash Management .............................................................................................. 6 3.1 3.2 3.3 3.4 3.5 3.6 Error Correction/Detection .......................................................................................................... 6 Bad Block Management ............................................................................................................... 6 Wear Leveling ............................................................................................................................... 6 Power Failure Management......................................................................................................... 6 TRIM ............................................................................................................................................... 6 Secure Erase................................................................................................................................. 6 4. Environment Specifications.............................................................................. 7 4.1 Environmental .............................................................................................................................. 7 4.2 Mean Time Between Failures (MTBF) ........................................................................................ 7 4.3 Certification and Compliance ..................................................................................................... 7 5. Electrical Characteristics ................................................................................. 8 5.1 Operating Voltage ........................................................................................................................ 8 5.2 Power Consumption .................................................................................................................... 8 6. Mechanical Characteristics.............................................................................. 9 6.1 Dimensions ................................................................................................................................... 9 7. Product Ordering Information ........................................................................ 10 7.1 Product Code Designations ...................................................................................................... 10 7.2 Valid Combinations .................................................................................................................... 11 2 © 2015 Apacer Technology Inc. Rev. 1.1 mSATA Flash Drive APMxxxxM1XX-2TX 1. Product Description 1.1 Introduction Apacer’s mSATA H1 delivers all the advantages of flash disk technology with the Serial ATA 6.0 Gbps interface and is fully compliant with the standard mSATA form factor, known as JEDEC MO-300 standard. The module is designed to operate at optimal efficiency and reliability. Its performance can reach up to 130 MB/s read and up to 110MB/s write. Meanwhile, the power consumption of the mSATA module is much lower than traditional hard drives. 1.2 Capacity Specification Table 1-1 Capacity specification Capacity Total Bytes Cylinders Heads Sectors Max LBA 1 GB 2 GB 4 GB 8 GB 16 GB 32 GB 64 GB 1,011,032,064 2,011,226,112 4,011,614,208 8,012,390,400 16,013,942,784 32,017,047,552 64,023,257,088 15,525 15,525 15,525 15,525 16,383 16,383 16,383 16 16 16 16 16 16 16 63 63 63 63 63 63 63 1,974,672 3,928,176 7,835,184 15,649,200 31,277,232 62,533,296 125,045,424 *Display of total bytes varies from file systems. **Cylinders, heads or sectors are not applicable for these capacities. Only LBA addressing applies. LBA count addressed in the table above indicates total user storage capacity and will remain the same throughout the lifespan of the device. However, the total usable capacity of the SSD is most likely to be less than the total physical capacity because a small portion of the capacity is reserved for device maintenance usages. 1.3 Performance Performance of mSATA H1 is shown in Table 1-2. Table 1-2 Performance specification Capacity Performance Sustained Read (MB/s) Sustained Write (MB/s) 1 GB 2 GB 4 GB 8 GB 16 GB 32 GB 64 GB 30 65 130 130 130 130 130 20 40 75 85 95 100 100 Note: Performance varies from flash configurations or host system settings. 3 © 2015 Apacer Technology Inc. Rev. 1.1 mSATA Flash Drive APMxxxxM1XX-2TX 1.4 Pin Assignments Pin assignment of the mSATA H1 is shown in Figure 1-2 and described in Table 1-3. Pin 1 Pin 51 Figure 1-2 Apacer mSATA H1 pin assignment Table 1-3 Pin Assignment Description Pin # mSATA Pin Description Pin # mSATA Pin Description 1 NC No Connect 27 SATA GND SATA Ground Return Pin 2 +3.3V 3.3V Source 28 NC No Connect 3 NC No Connect 29 SATA GND SATA Ground Return Pin 4 DGND Digital GND 30 NC 5 NC No Connect 31 -A 6 NC No Connect 32 NC 7 NC No Connect 33 +A 8 NC No Connect 34 DGND No Connect Host Transmitter Differential Signal Pair No Connect Host Transmitter Differential Signal Pair Digital GND 9 DGND Digital GND 35 SATA GND SATA Ground Return Pin 10 NC No Connect 36 NC No Connect 11 NC No Connect 37 SATA GND SATA Ground Return Pin 12 NC No Connect 38 NC No Connect 13 NC No Connect 39 +3.3V 3.3V Source 14 NC No Connect 40 DGND Digital GND 15 DGND Digital GND 41 +3.3V 3.3V Source 16 NC No Connect 42 NC No Connect 17 NC No Connect 43 NC No Connect 18 DGND Digital GND 44 NC No Connect 19 NC No Connect 45 Vendor Vendor specific 20 NC No Connect 46 NC No Connect 21 SATA GND SATA Ground Return Pin 47 Vendor Vendor specific 22 NC No Connect 48 NC No Connect 23 +B Host Receiver Differential Signal Pair 49 DA/DSS Device activity signal 24 +3.3V 3.3V Source 50 DGND Digital GND 25 -B Host Receiver Differential Signal Pair 51 GND Default connect to GND 26 SATA GND SATA Ground Return Pin 52 +3.3V 3.3V Source 4 © 2015 Apacer Technology Inc. Rev. 1.1 mSATA Flash Drive APMxxxxM1XX-2TX 2. Software Interface 2.1 Command Set Table 2-1 summarizes the ATA commands supported by mSATA H1. Table 2-1: Command set Code Command Code Command E5h Check power mode F6h Security Disable Password 06h Data Set management F3h Security Erase Prepare B1H DCO F4h Security Erase Unit 92h Download Microcode PIO F5h Security Freeze Lock 93h Download Microcode DMA F1h Security Set Password 90h Execute drive diagnostic F2h Security Unlock E7h Flush cache 70h Seek EAh Flush cache Ext EFh Set features ECh Identify device F9h Set Max Address E3h Idle 37h Set Max Address Ext E1h Idle immediate C6h Set multiple mode 91h Initialize drive parameters E6h Sleep E4h Read buffer B0h Smart C9h Read DMA (w/o retry) E2h Standby C8h Read DMA (w/retry) E0h Standby immediate 25h Read DMA Ext E8h Write buffer 60h Read FPDMA QUEUED CBh Write DMA (w/o retry) 2Fh Read Log Ext CAh Write DMA (w/retry) C4h Read multiple 35h Write DMA Ext 29h Read multiple Ext 3Dh Write DMA FUA Ext F8h Read native max address 61h Write FPDMA QUEUED 27h Read native max Ext 3Fh Write Log Ext 21h Read sector(s) (w/o retry) C5h Write multiple 20h Read sector(s) (w/retry) 39h Write multiple Ext 24h Read sector(s) Ext CEh Write multiple FUA Ext 42h Read Verify Ext 31h Write sector(s) (w/o retry) 41h Read verify sector(s) (w/o retry) 30h Write sector(s) (w/retry) 40h Read verify sector(s) (w/retry) 34h Write sector(s) Ext 10h Recalibrate 45h Write uncorrectable Note. Security command will only be workable when device runs in non-OPAL compliant mode. 2.2 S.M.A.R.T. SMART, an acronym for Self-Monitoring, Analysis and Reporting Technology, is an open standard that allows a hard disk drive to automatically detect its health and report potential failures. When a failure is recorded by SMART, users can choose to replace the drive to prevent unexpected outage or data loss. Moreover, SMART can inform users of impending failures while there is still time to perform proactive actions, such as copy data to another device. 5 © 2015 Apacer Technology Inc. Rev. 1.1 mSATA Flash Drive APMxxxxM1XX-2TX 3. Flash Management 3.1 Error Correction/Detection Flash memory cells will deteriorate with use, which might generate random bit errors in the stored data. Thus, this mSATA SSD module applies the BCH ECC Algorithm, which can detect and correct errors occur during Read process, ensure data been read correctly, as well as protect data from corruption. This device can correct up to 72bit/1K data. 3.2 Bad Block Management Bad blocks are blocks that include one or more invalid bits, and their reliability is not guaranteed. Blocks that are identified and marked as bad by the manufacturer are referred to as “Initial Bad Blocks”. Bad blocks that are developed during the lifespan of the flash are named “Later Bad Blocks”. Apacer implements an efficient bad block management algorithm to detect the factory-produced bad blocks and manages any bad blocks that appear with use. This practice further prevents data being stored into bad blocks and improves the data reliability. 3.3 Wear Leveling NAND Flash devices can only undergo a limited number of program/erase cycles, and in most cases, the flash media are not used evenly. If some areas get updated more frequently than others, the lifetime of the device would be reduced significantly. Thus, Wear Leveling technique is applied to extend the lifespan of NAND Flash by evenly distributing write and erase cycles across the media. Apacer provides advanced Wear Leveling algorithm, which can efficiently spread out the flash usage through the whole flash media area. Moreover, by implementing both dynamic and static Wear Leveling algorithms, the life expectancy of the NAND Flash is greatly improved. 3.4 Power Failure Management Power Failure Management plays a crucial role when experiencing unstable power supply. Power disruption may occur when users are storing data into the SSD. In this urgent situation, the controller would run multiple flush cycles to store the metadata for later block rebuilding. This urgent operation requires about several milliseconds to get it done. At the next power up, the firmware will perform a status tracking to retrieve the mapping table and resume previously programmed NAND blocks to check if there is any incompleteness of transmission. 3.5 TRIM TRIM is a feature which helps improve the read/write performance and speed of solid-state drives (SSD). Unlike hard disk drives (HDD), SSDs are not able to overwrite existing data, so the available space gradually becomes smaller with each use. With the TRIM command, the operating system can inform the SSD which blocks of data are no longer in use and can be removed permanently. Thus, the SSD will perform the erase action, which prevents unused data from occupying blocks all the time. 3.6 Secure Erase Secure Erase is a standard ATA command and will write all “0xFF” to fully wipe all the data on hard drives and SSDs. When this command is issued, the SSD controller will empty its storage blocks and return to its factory default settings. Note. Secure erase command belongs to ATA security command. 6 © 2015 Apacer Technology Inc. Rev. 1.1 mSATA Flash Drive APMxxxxM1XX-2TX 4. Environment Specifications 4.1 Environmental Table 4-1 mSATA H1 environmental specifications Environment Specification 0°C to 70°C (Operating) -40°C to 85°C (Extended) Temperature -40°C to 100°C (in storage) RH 90% under 40°C Humidity 1500G, 0.5ms Shock 20Hz~80Hz/1.52mm (frequency/displacement) 80Hz~2000Hz/20G (frequency/displacement) Vibration X, Y, Z axis/60mins each 80cm free fall, 6 face of each Drop ≧20N, hold 1min/5times Bending 0.5N-m or 5deg, hold 5min/5times Torque Pass ESD Note: Shock and Vibration specifications are subject to change without notice. 4.2 Mean Time Between Failures (MTBF) MTBF, an acronym for Mean Time Between Failures, is a measure of a device’s reliability. Its value represents the average time between a repair and the next failure. The measure is typically in units of hours. The higher the MTBF value, the higher the reliability of the device. The predicted result of this mSATA device is higher than 2,000,000 hours. 4.3 Certification and Compliance mSATA H1 complies with the following standards:        SATA Revision 3.1 RoHS ATA/ATAPI FCC CE BSMI MIL-STD-810G 7 © 2015 Apacer Technology Inc. Rev. 1.1 mSATA Flash Drive APMxxxxM1XX-2TX 5. Electrical Characteristics 5.1 Operating Voltage Table 5-1 lists the supply voltage for mSATA H1. Table 5-1 mSATA H1 operating voltage Parameter Conditions Supply Voltage 3.3V ±5% 5.2 Power Consumption Table 5-2 lists the power consumption for mSATA H1. Table 5-2 mSATA H1 power consumption (typical) Capacity Mode Active (mA) Idle (mA) 1 GB 2 GB 4 GB 8 GB 16 GB 32 GB 64 GB 185 205 250 325 325 380 380 100 100 100 100 100 100 100 Note: Power consumptions may vary depending on host system settings . 8 © 2015 Apacer Technology Inc. Rev. 1.1 mSATA Flash Drive APMxxxxM1XX-2TX 6. Mechanical Characteristics 6.1 Dimensions Unit: ㎜ Tolerance: ± 0.2 9 © 2015 Apacer Technology Inc. Rev. 1.1 mSATA Flash Drive APMxxxxM1XX-2TX 7. Product Ordering Information 7.1 Product Code Designations 1 X X–2 T X AP M xxxx M Temperature Range Blank: Standard W: Extended Temperature Flash Type FW Version Configuration N: Standard D: Hi-Speed A : Standad T : Thermal Sensor Solution version Form Factor: N: mSATA H1 Capacity: 001G: 01GB 002G: 02GB 004G: 04GB 008G: 08GB 016G: 16GB 032G: 32GB 064G: 64GB mSATA Apacer Product Code 10 © 2015 Apacer Technology Inc. Rev. 1.1 mSATA Flash Drive APMxxxxM1XX-2TX 7.2 Valid Combinations 7.2.1 mSATA H1 without thermal sensor Capacity 7.2.2 Standard Extended Temperature 1GB APM001GM1AN-2T APM001GM1AN-2TW 2GB APM002GM1AN-2T APM002GM1AN-2TW 4GB APM004GM1AN-2T APM004GM1AN-2TW 8GB APM008GM1AN-2T APM008GM1AN-2TW 16GB APM016GM1AN-2T APM016GM1AN-2TW 32GB APM032GM1AN-2T APM032GM1AN-2TW 64GB APM064GM1AN-2T APM064GM1AN-2TW mSATA H1 with thermal sensor Capacity Standard Extended Temperature 1GB 2GB 4GB 8GB 16GB 32GB 64GB APM001GM1TN-2T APM002GM1TN-2T APM004GM1TN-2T APM008GM1TN-2T APM016GM1TN-2T APM032GM1TN-2T APM064GM1TN-2T APM001GM1TN-2TW APM002GM1TN-2TW APM004GM1TN-2TW APM008GM1TN-2TW APM016GM1TN-2TW APM032GM1TN-2TW APM064GM1TN-2TW 11 © 2015 Apacer Technology Inc. Rev. 1.1 mSATA Flash Drive APMxxxxM1XX-2TX Revision History Revision Description Date 1.0 First release 06/03/2014 1.1 Changed dimension picture - add max component height 07/13/2015 12 © 2015 Apacer Technology Inc. Rev. 1.1 mSATA Flash Drive APMxxxxM1XX-2TX Global Presence Taiwan (Headquarters) Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: 886-2-2267-8000 Fax: 886-2-2267-2261 amtsales@apacer.com U.S.A. Apacer Memory America, Inc. 386 Fairview Way, Suite102, Milpitas, CA 95035 Tel: 1-408-518-8699 Fax: 1-408-935-9611 sa@apacerus.com Japan Apacer Technology Corp. 5F, Matsura Bldg., Shiba, Minato-Ku Tokyo, 105-0014, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Europe Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-267-0000#6199 sales@apacer.nl China Apacer Electronic (Shanghai) Co., Ltd Room D,22/FL,No2,Lane600,JieyunPlaza, Tianshan RD,Shanghai,200051,China Tel: 86-21-6228-9939 Fax: 86-21-6228-9936 sales@apacer.com.cn India Apacer Technologies Pvt Ltd, # 535, 1st Floor, 8th cross, JP Nagar 3rd Phase, Bangalore – 560078, India Tel: 91-80-4152-9061 sales_india@apacer.com 13 © 2015 Apacer Technology Inc. Rev. 1.1
APM016GM1AN-2TW 价格&库存
很抱歉,暂时无法提供与“APM016GM1AN-2TW”相匹配的价格&库存,您可以联系我们找货
