APS25AB7016G-BTW
APS25AB7016G-BTW
    APACERMEMORYAMERICA(宇瞻科技)
    Solid State Drive (SSD) 16GB SATA III FLASH - NAND (SLC) 2.5" 5V
APS25AB7016G-BTW 数据手册
RoHS Compliant Serial ATA Flash Drive SFD25A Product Specifications December 14, 2015 Version 1.5 Apacer Technology Inc. 1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C Tel: +886-2-2267-8000 www.apacer.com Fax: +886-2-2267-2261 Serial ATA Flash Drive APS25AXXxxxx-XTX Features: Compliance with SATA Revision 3.1 Serial ATA Revision 3.1 SATA 6.0 Gbps interface Backward compatible with SATA 1.5 and 3.0 Gbps interfaces ATA-8 command set Temperature Range Operating: Standard: 0°C to 70°C Extended: -40°C to 85°C Storage: -40°C to 100°C Supply Voltage 5.0 V 5% Capacity 8, 16, 32, 64, 128, 256 GB Power Consumption* Standard: Active mode: 275 mA Idle mode: 105 mA High speed: Active mode: 500 mA Idle mode: 65 mA Performance* Interface burst read/write: 600 MB/sec Standard speed: Sustained read: up to 160 MB/sec Sustained write: up to 150 MB/sec High speed: Sustained read: up to 530 MB/sec Sustained write: up to 445 MB/sec Random read (4K): up to 88,000 IOPS Random write (4K): up to 76,000 IOPS Form Factor 2.5 Dimensions with 7mm enclosure: 100.00 x 69.85 x 6.90, unit: mm Dimensions with 9.5mm enclosure: 100.00 x 69.84 x 9.30, unit: mm Flash Management Built-in hardware ECC Static/dynamic wear leveling Flash bad-block management S.M.A.R.T. Power Failure Management ATA Secure Erase TRIM Connector 7-pin SATA signal connector 15-pin SATA power connector NAND Flash Type: SLC Shock & Vibration** Shock: 1,500 G Vibration: 15 G SATA Power Management Modes Device Sleep Mode (optional) RoHS Compliant *The values addressed here are typical and may vary depending on settings and platforms. **Non-operating 1 ©2015 Apacer Technology Inc. Rev. 1.5 Serial ATA Flash Drive APS25AXXxxxx-XTX Table of Contents 1. Product Description ............................................................................................... 3 1.1 1.2 1.3 1.4 Introduction ................................................................................................................................................3 Capacity Specification ................................................................................................................................3 Performance ................................................................................................................................................3 Pin Assignments ..........................................................................................................................................4 2. Software Interface ..................................................................................................... 6 2.1 Command Set ..............................................................................................................................................6 2.2 S.M.A.R.T. ...................................................................................................................................................6 3. Flash Management ................................................................................................. 8 3.1 3.2 3.3 3.4 3.5 3.6 3.7 4. Reliability Specifications ..................................................................................... 10 4.1 4.2 4.3 5. Operating Voltage ..................................................................................................................................... 11 Power Consumption ................................................................................................................................. 11 Mechanical Specifications ................................................................................... 12 6.1 6.2 7. Environmental .......................................................................................................................................... 10 Mean Time Between Failures (MTBF) ................................................................................................... 10 Certification and Compliance .................................................................................................................. 10 Electrical Characteristics ..................................................................................... 11 5.1 5.2 6. Error Correction/Detection ....................................................................................................................... 8 Bad Block Management .............................................................................................................................8 Wear Leveling ............................................................................................................................................. 8 Power Failure Management .......................................................................................................................8 ATA Secure Erase.......................................................................................................................................8 TRIM ........................................................................................................................................................... 9 SATA Power Management ........................................................................................................................ 9 7mm Type Dimensions ............................................................................................................................. 12 9. 5mm Type Dimensions ......................................................................................................................... 13 Product Ordering Information ............................................................................. 14 7.1 7.2 Product Code Designation........................................................................................................................14 Valid Combination.................................................................................................................................... 15 2 ©2015 Apacer Technology Inc. Rev. 1.5 Serial ATA Flash Drive APS25AXXxxxx-XTX 1. Product Description 1.1 Introduction SFD25A is a well-balanced solid-state disk (SSD) drive with standard form factor and great performance. Designed in SATA 6.0 Gbps interface, the SSD is able to deliver exceptional read/write speed, making it the ideal companion for heavy-loading industrial or server operations. In regard of reliability, the drive comes with various implementations including powerful hardware ECC engine, power saving modes, wear leveling, flash block management, S.M.A.R.T., TRIM, and power failure management. 1.2 Capacity Specifications Table 1-1 Capacity Specifications Capacity Total Bytes* Cylinders Heads Sectors Max LBA* 8 GB 8,012,390,400 15,525 16 63 15,649,200 16 GB 16,013,942,784 16,383 16 63 31,277,232 32 GB 32,017,047,552 16,383 16 63 62,533,296 64 GB 64,023,257,088 16,383 16 63 125,045,424 128 GB 128,035,676,160 16,383 16 63 250,069,680 256 GB 256,060,514,304 16,383 16 63 500,118,192 *Display of total bytes varies from file systems. **Cylinders, heads or sectors are not applicable for these capacities. Only LBA addressing applies. ***LBA count addressed in the table above indicates total user storage capacity and will remain the same throughout the lifespan of the device. However, the total usable capacity of the SSD is most likely to be less than the total physical capacity because a small portion of the capacity is reserved for device maintenance usages. 1.3 Performance Table 1-2 Performance (Standard) Capacity Performance Sustained Read (MB/s) Sustained Write (MB/s) 8 GB 16 GB 32 GB 64 GB 128 GB 155 155 160 160 160 110 145 145 150 150 Table 1-3 Performance (High-speed) Capacity Performance Sustained Read (MB/s) Sustained Write (MB/s) Random Read IOPS (4K) Random Write IOPS (4K) 32 GB 64 GB 128 GB 256 GB 530 530 530 310 270 440 445 440 81,000 82,000 82,000 88,000 62,000 73,000 76,000 76,000 Note: Performance varies from flash configurations or host system settings. IOPS: measured on 8GB span (16777216 sectors Disk Size), 32 Outstanding I/Os (QD=32), Full Random Data pattern, 4KB Align I/Os and test durations 15minutes. 3 ©2015 Apacer Technology Inc. Rev. 1.5 Serial ATA Flash Drive APS25AXXxxxx-XTX 1.4 Pin Assignments Table 1-4 describes the SFD signal segment, and Table1-5, power segment. Figure 1-1 SATA Connectors Table 1-4 Signal Segment Pin Type S1 GND Table 1-5 Power Segment Description S2 RxP + Differential Receive S3 RxN - Differential Receive S4 GND S5 TxN - Differential Transmit S6 TxP + Differential Transmit S7 GND Pin Signal/Description P1 Unused (3.3V) P2 Unused (3.3V) P3 Unused or Device Sleep* P4 Ground P5 Ground P6 Ground P7 5V P8 5V P9 5V P10 Ground P11 DAS P12 Ground P13 Unused (12V) P14 Unused (12V) P15 Unused (12V) *P3 can be configured as Device Sleep trigger by option 4 ©2015 Apacer Technology Inc. Rev. 1.5 Serial ATA Flash Drive APS25AXXxxxx-XTX Figure 1-3 SATA Cable/Connector Connection Diagram The connector on the left represents the Host with TX/RX differential pairs connected to a cable. The connector on the right shows the Device with TX/RX differential pairs also connected to the cable. Notice also the ground path connecting the shielding of the cable to the Cable Receptacle. 5 ©2015 Apacer Technology Inc. Rev. 1.5 Serial ATA Flash Drive APS25AXXxxxx-XTX 2. Software Interface 2.1 Command Set Table 2-1 summarizes the ATA commands supported by SFD25A. Table 2-1: Command Set Code Command Code Command E5h Check Power Mode F6h Security Disable Password 90h Execute Diagnostics F3h Security Erase Prepare E7h Flush Cache F4h Security Erase Unit ECh Identify Device F5h Security Freeze Lock E3h Idle F1h Security Set Password E1h Idle Immediate F2h Security Unlock 91h Initialize Device Parameters 7Xh Seek C8h Read DMA EFh Set Features 25h Read DMA EXT C6h Set Multiple Mode 60h Read FPDMA Queued E6h Sleep 47h Read Log DMA EXT B0h S.M.A.R.T. 2Fh Read Log EXT E2h Standby C4h Read Multiple E0h Standby Immediate 20 or 21h Read Sector(s) CAh Write DMA 40 or 41h Read Verify Sector(s) 35h Write DMA EXT 10h Recalibrate 61h Write FPDMA Queued 57h Write Log DMA EXT 3Fh Write Log EXT C5h Write Multiple 30h or 31h Write Sector(s) 2.2 S.M.A.R.T. S.M.A.R.T. is an abbreviation for Self-Monitoring, Analysis and Reporting Technology, a self-monitoring system that provides indicators of drive health as well as potential disk problems. It serves as a warning for users from unscheduled downtime by monitoring and displaying critical drive information. Ideally, this should allow taking proactive actions to prevent drive failure and make use of S.M.A.R.T. information for future product development reference. Apacer devices use the standard SMART command B0h to read data out from the drive to activate our S.M.A.R.T. feature that complies with the ATA/ATAPI specifications. S.M.A.R.T. Attribute IDs shall include initial bad block count, total later bad block count, maximum erase count, average erase count, power on hours and power cycle. When the S.M.A.R.T. Utility running on the host, it analyzes and reports the disk status to the host before the device reaches in critical condition. Note: attribute IDs may vary from product models due to various solution design and supporting capabilities. 6 ©2015 Apacer Technology Inc. Rev. 1.5 Serial ATA Flash Drive APS25AXXxxxx-XTX Apacer memory products come with S.M.A.R.T. commands and subcommands for users to obtain information of drive status and to predict potential drive failures. Users can take advantage of the following commands/subcommands to monitor the health of the drive. Code D0h D1h D2h D4h D5h D6h D8h D9h Dah Byte 0 1 2 3 4 5*-11 SMART Subcommand READ DATA READ ATTRIBUTE THRESHOLDS Enable/Disable Attribute Autosave Execute Off-line Immediate Read Log (optional) Write Log (optional) Enable Operations Disable operations Return Status General SMART attribute structure Description ID (Hex) Status flag Value Worst Raw Data *Byte 5: LSB ID (Hex) 9 (0x09) 12 (0x0C) 163 (0xA3) 164 (0xA4) 166 (0xA6) 167 (0xA7) 168 (0xA8) 175 (0xAF) 192 (0xC0) 194 (0xC2) 241 (0xF1) SMART attribute ID list Attribute Name Power-on hours Power cycle count Max. erase count Avg. erase count Total later bad block count SSD Protect Mode (vendor specific) SATA PHY Error Count Bad Cluster Table Count Unexpected Power Loss Count Temperature Total sectors of write 7 ©2015 Apacer Technology Inc. Rev. 1.5 Serial ATA Flash Drive APS25AXXxxxx-XTX 3. Flash Management 3.1 Error Correction/Detection SFD25A implements a hardware ECC scheme, based on the BCH algorithm. It can detect and correct up to 40 bits error in 1K bytes. 3.2 Bad Block Management Current production technology is unable to guarantee total reliability of NAND flash memory array. When a flash memory device leaves factory, it comes with a minimal number of initial bad blocks during production or out-of-factory as there is no currently known technology that produce flash chips free of bad blocks. In addition, bad blocks may develop during program/erase cycles. When host performs program/erase command on a block, bad block may appear in Status Register. Since bad blocks are inevitable, the solution is to keep them in control. Apacer flash devices are programmed with ECC, block mapping technique and S.M.A.R.T to reduce invalidity or error. Once bad blocks are detected, data in those blocks will be transferred to free blocks and error will be corrected by designated algorithms. 3.3 Wear Leveling Flash memory devices differ from Hard Disk Drives (HDDs) in terms of how blocks are utilized. For HDDs, when a change is made to stored data, like erase or update, the controller mechanism on HDDs will perform overwrites on blocks. Unlike HDDs, flash blocks cannot be overwritten and each P/E cycle wears down the lifespan of blocks gradually. Repeatedly program/erase cycles performed on the same memory cells will eventually cause some blocks to age faster than others. This would bring flash storages to their end of service term sooner. Wear leveling is an important mechanism that level out the wearing of blocks so that the wearing-down of blocks can be almost evenly distributed. This will increase the lifespan of SSDs. Commonly used wear leveling types are Static and Dynamic. 3.4 Power Failure Management Power Failure Management plays a crucial role when experiencing unstable power supply. Power disruption may occur when users are storing data into the SSD. In this urgent situation, the controller would run multiple write-to-flash cycles to store the metadata for later block rebuilding. This urgent operation requires about several milliseconds to get it done. At the next power up, the firmware will perform a status tracking to retrieve the mapping table and resume previously programmed NAND blocks to check if there is any incompleteness of transmission. Note: The controller unit of this product model is designed with a DRAM as a write cache for improved performance and data efficiency. Though unlikely to happen in most cases, the data cached in the volatile DRAM might be potentially affected if a sudden power loss takes place before the cached data is flushed into non-volatile NAND flash memory. 3.5 ATA Secure Erase ATA Secure Erase is an ATA disk purging command currently embedded in most of the storage drives. Defined in ATA specifications, (ATA) Secure Erase is part of Security Feature Set that allows storage drives to erase all user data areas. The erase process usually runs on the firmware level as most of the ATA-based storage media currently in the market are built-in with this command. ATA Secure Erase can securely wipe out the user data in the drive and protects it from malicious attack. 8 ©2015 Apacer Technology Inc. Rev. 1.5 Serial ATA Flash Drive APS25AXXxxxx-XTX 3.6 TRIM TRIM is a SATA command that helps improve the read/write performance and efficiency of solid-state drives (SSD). The command enables the host operating system to inform SSD controller which blocks contain invalid data, mostly because of the erase commands from host. The invalid will be discarded permanently and the SSD will retain more space for itself. 3.7 SATA Power Management By complying with SATA 6.0 Gb/s specifications, the SSD supports the following SATA power saving modes: ACTIVE: PHY ready, full power, Tx & Rx operational PARTIAL: Reduces power, resumes in under 10 µs (microseconds) SLUMBER: Reduces power, resumes in under 10 ms (milliseconds) HIPM: Host-Initiated Power Management DIPM: Device-Initiated Power Management AUTO-SLUMBER: Automatic transition from partial to slumber. Device Sleep (DevSleep or DEVSLP): PHY powered down; power consumption 5 mW; host assertion 10 ms; exit timeout from this state 20 ms (unless specified otherwise in SATA Identify Device time Log). Note: 1. The behaviors of power management features would depend on host/device settings. 2. Device Sleep mode is optional, depending on product ordering selections. 9 ©2015 Apacer Technology Inc. Rev. 1.5 Serial ATA Flash Drive APS25AXXxxxx-XTX 4. Reliability Specifications 4.1 Environmental SFD25A environmental specifications follow MIL-STD-810F, as indicated in the following table. Table 4-1 SFD25A Environmental Specifications Environment Temperature Humidity Vibration Shock Specifications 0°C to 70°C (Operating) / -40°C to 85°C (extended) -40°C to 100°C (Non-operating) RH 90% under 40°C Non-operating : Sine wave, 15(G), 10~2000(Hz), Operating : Random, 7.69(Grms), 20~2000(Hz) Non-operating: Acceleration, 1,500 G, 0.5 ms Operating: Peak acceleration, 50 G, 11 ms 4.2 Mean Time Between Failures (MTBF) Mean Time Between Failures (MTBF) is predicted based on reliability data for the individual components in SFD drive. The prediction result for the SFD25A is more than 2,000,000 hours. Notes about the MTBF: The MTBF is predicated and calculated based on Telcordia Technologies Special Report, SR-332, Issue 2 method. 4.3 Certification and Compliance SFD25A complies with the following standards: CE FCC RoHS MIL-STD-810F 10 ©2015 Apacer Technology Inc. Rev. 1.5 Serial ATA Flash Drive APS25AXXxxxx-XTX 5. Electrical Characteristics 5.1 Operating Voltage Table 5-1 lists the supply voltage for SFD25A. Table 5-1 SFD25A Operating Voltage Parameter Conditions Supply voltage 5V ± 5% ( 4.75-5.25 V) 5.2 Power Consumption Table 5-2 Power Consumption (Standard) Capacity 8 GB 16 GB 32 GB 64 GB 128 GB Active (mA) 220 275 275 275 275 Idle (mA) 100 100 100 100 105 Mode Table 5-2 Power Consumption (High-speed) Capacity Mode 32 GB 64 GB 128 GB 256 GB Active (mA) 320 460 470 500 Idle (mA) 95 95 95 65 Note: Power consumptions may vary depending on settings and platforms. 11 ©2015 Apacer Technology Inc. Rev. 1.5 Serial ATA Flash Drive APS25AXXxxxx-XTX 6. Mechanical Specifications 6.1 7mm Type Dimensions Unit: Tolerance: ± 0.2 Figure 6-1 SFD25A with 7mm Housing Physical Dimensions 12 ©2015 Apacer Technology Inc. Rev. 1.5 Serial ATA Flash Drive APS25AXXxxxx-XTX 6.2 9. 5mm Type Dimensions Unit: Tolerance: ± 0.2 Figure 6-2 SFD25A with 9.5mm Housing Physical Dimensions 13 ©2015 Apacer Technology Inc. Rev. 1.5 Serial ATA Flash Drive APS25AXXxxxx-XTX 7. Product Ordering Information 7.1 Product Code Designation AP S 25A X X xxxx - X T X Temperature Range Blank: Standard W: Extended Temperature Flash Type Version Control Capacity 008G = 8GB 016G = 16GB 032G = 32GB 064G = 64GB 128G = 128GB 256G = 256GB Housing Type B= 9.5mm 7= 7mm Solution Version 2.5 inch Form Factor Serial ATA Flash Drive Apacer Product Code 14 ©2015 Apacer Technology Inc. Rev. 1.5 Serial ATA Flash Drive APS25AXXxxxx-XTX 7.2 Valid Combination A. Standard Speed 7.2.1 9.5mm Metal Housing / Operating Temperature ( 0°C ~ 70°C) Capacity 8 GB 16GB 32GB 64GB 128GB NO DEVSLP APS25ABB008G-AT APS25ABB016G-AT APS25ABB032G-AT APS25ABB064G-AT APS25ABB128G-AT DEVSLP APS25ABB008G-BT APS25ABB016G-BT APS25ABB032G-BT APS25ABB064G-BT APS25ABB128G-BT 7.2.2 9.5mm Metal Housing / Operating Temperature (-40°C ~ 85°C) Capacity 8 GB 16GB 32GB 64GB 128GB NO DEVSLP APS25ABB008G-ATW APS25ABB016G-ATW APS25ABB032G-ATW APS25ABB064G-ATW APS25ABB128G-ATW DEVSLP APS25ABB008G-BTW APS25ABB016G-BTW APS25ABB032G-BTW APS25ABB064G-BTW APS25ABB128G-BTW 7.2.3 7mm Housing / Operating Temperature (0°C ~ 70°C) Capacity 8 GB 16GB 32GB 64GB 128GB NO DEVSLP APS25AB7008G-AT APS25AB7016G-AT APS25AB7032G-AT APS25AB7064G-AT APS25AB7128G-AT DEVSLP APS25AB7008G-BT APS25AB7016G-BT APS25AB7032G-BT APS25AB7064G-BT APS25AB7128G-BT 7.2.4 7mm Housing / Operating Temperature (-40°C ~ 85°C) Capacity 8 GB 16GB 32GB 64GB 128GB NO DEVSLP APS25AB7008G-ATW APS25AB7016G-ATW APS25AB7032G-ATW APS25AB7064G-ATW APS25AB7128G-ATW DEVSLP APS25AB7008G-BTW APS25AB7016G-BTW APS25AB7032G-BTW APS25AB7064G-BTW APS25AB7128G-BTW 15 ©2015 Apacer Technology Inc. Rev. 1.5 Serial ATA Flash Drive APS25AXXxxxx-XTX B. High Speed 7.2.5 9.5mm Metal Housing / Operating Temperature ( 0°C ~ 70°C) Capacity 32GB 64GB 128GB 256GB NO DEVSLP APS25A7B032G-3AT APS25A7B064G-3AT APS25A7B128G-3AT APS25A7B256G-3AT DEVSLP APS25A7B032G-3BT APS25A7B064G-3BT APS25A7B128G-3BT APS25A7B256G-3BT 7.2.6 9.5mm Metal Housing / Operating Temperature (-40°C ~ 85°C) Capacity 32GB 64GB 128GB 256GB NO DEVSLP APS25A7B032G-3ATW APS25A7B064G-3ATW APS25A7B128G-3ATW APS25A7B256G-3ATW DEVSLP APS25A7B032G-3BTW APS25A7B064G-3BTW APS25A7B128G-3BTW APS25A7B256G-3BTW 7.2.7 7mm Housing / Operating Temperature (0°C ~ 70°C) Capacity 32GB 64GB 128GB 256GB NO DEVSLP APS25A77032G-3AT APS25A77064G-3AT APS25A77128G-3AT APS25A77256G-3AT DEVSLP APS25A77032G-3BT APS25A77064G-3BT APS25A77128G-3BT APS25A77256G-3BT 7.2.8 7mm Housing / Operating Temperature (-40°C ~ 85°C) Capacity 32GB 64GB 128GB 256GB NO DEVSLP APS25A77032G-3ATW APS25A77064G-3ATW APS25A77128G-3ATW APS25A77256G-3ATW DEVSLP APS25A77032G-3BTW APS25A77064G-3BTW APS25A77128G-3BTW APS25A77256G-3BTW Note: Please consult with Apacer sales representatives for availabilities. 16 ©2015 Apacer Technology Inc. Rev. 1.5 Serial ATA Flash Drive APS25AXXxxxx-XTX Revision History Revision Description Date 1.0 Official release 01/15/2014 1.1 Added 32, 64 and 128 GB high speed models 07/10/2014 1.2 Revised Product Ordering Information 08/15/2014 1.3 Revised part numbers of 32 GB in high speed models 10/07/2014 1.4 Added 256 GB high speed models 09/01/2015 1.5 Added humidity specifications 12/14/2015 17 ©2015 Apacer Technology Inc. Rev. 1.5 Serial ATA Flash Drive APS25AXXxxxx-XTX Global Presence Taiwan (Headquarters) Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: 886-2-2267-8000 Fax: 886-2-2267-2261 amtsales@apacer.com U.S.A. Apacer Memory America, Inc. 46732 Lakeview Blvd., Fremont, CA 94538 Tel: 1-408-518-8699 Fax: 1-510-249-9568 sa@apacerus.com Japan Apacer Technology Corp. 5F, Matsura Bldg., Shiba, Minato-Ku Tokyo, 105-0014, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Europe Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-267-0000#6199 sales@apacer.nl China Apacer Electronic (Shanghai) Co., Ltd Room D, 22/FL, No.2, Lane 600, JieyunPlaza, Tianshan RD, Shanghai, 200051, China Tel: 86-21-6228-9939 Fax: 86-21-6228-9936 sales@apacer.com.cn India Apacer Technologies Pvt Ltd, th Unit No.201, Brigade Corner 7 Block Jayanagar, Yediyur Circle, Bangalore 560082, India Tel: 91-80-4152-9061 Fax: 91-80-4170-0215 sales_india@apacer.com 18 ©2015 Apacer Technology Inc. Rev. 1.5
APS25AB7016G-BTW 价格&库存
很抱歉,暂时无法提供与“APS25AB7016G-BTW”相匹配的价格&库存,您可以联系我们找货
