SFSA32GBU1BR4TO-C-NC-236-STD
    SWISSBIT
    Solid State Drive (SSD) 32GB SATA II FLASH - NAND (SLC) mSATA 3.3V
SFSA32GBU1BR4TO-C-NC-236-STD 数据手册
Product fact sheet Industria Industrial mSATA SSD (MO(MO-300 full size) size) X-200 200m Series SATA II - 3.0Gb/s up to UDMA6 / MDMA2 / PIO4 Standard and industrial temperature grade BU : S w is sb it Group D a te: Fe bru ar y 07, 2 0 1 3 Re v is io n: 1 . 10 X- 200 m_f ac t_s hee t_ SA -UxBR _Rev 1 10.do c Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Swissbit reserves the right to change products or specifications without notice. www.swissbit.com info@swissbit.com Revision: 1.10 X-200m_fact_sheet_SA-UxBR_Rev110 Page 1 of 4 X-200m 200m Series – Industrial MSATA Solid State Drive 2GByte up to 64G 64GByte (MO(MO-300 full size) size) Feature summary • • • • • • • • • • • • • • • • Form factor: o Full-sized mSATA form factor o JEDEC MO-300 full size Solid State Drive (SSD) o 50.8mm x 29.85mm x 3.3mm o 52 pin PCI Express (PCIe) mini-connector (SATA II) Interface: o SATA Rev 2.6 - 3Gbit/s (1.5Gbit/s compatible) o mechanical identical to mini-PCIe and eeePC card connector, but different pin out Highly-integrated memory controller o max. UDMA6 supported o max. PIO mode 4, MDMA2 supported o SLC NAND Flash o Hardware BCH-code ECC (8 Bit correction per sector for SLC) o fix drive configuration Low-power CMOS technology 3.3V ± 5% power supply optional activity LED and write protect switch on request No mechanical noise Wear Leveling: active wear leveling of static and dynamic data The wear leveling assures that dynamic data as well as static data is balanced evenly across the memory. With that the maximum write endurance of the device is guaranteed. High reliability o MTBF > 2,500,000 hours o Data reliability: < 1 non-recoverable error per 1014 bits read High performance o Up to 300MB/s burst transfer rate in SATA II - 3.0Gb/sec o Sustained Write performance: up to 95MB/s o Sustained Read Performance: up to 120MB/s Available densities o 2GByte up to 64GByte (SLC NAND Flash) S.M.A.R.T. support 2 Temperature ranges o Commercial Temperature range 0 … +70°C o Industrial Temperature range -40 … +85°C Life Cycle Management Controlled BOM RoHS compatible Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Swissbit reserves the right to change products or specifications without notice. www.swissbit.com info@swissbit.com Revision: 1.10 X-200m_fact_sheet_SA-UxBR_Rev110 Page 2 of 4 Pin out The Mini-SATA connector is the same as the miniPCIE and eeePC card connector, but the pinout is different. Table 1: Pin Assignment, name, and description Description Assignment No Connect N/A No Connect N/A No Connect N/A No Connect N/A Return Current Path GND No Connect N/A No Connect N/A Return Current Path GND No Connect No Connect Return Current Path + SATA differential transmit signal - SATA differential transmit signal Return Current Path Return Current Path - SATA differential receive signal + SATA differential receive signal Return Current Path Return Current Path 3.3V Source 3.3V Source Return Current Path No Connect No Connect Device activity / LED (optional) *) Pulled to GND by Device Pin 1 3 5 7 9 11 13 15 Pin 2 4 6 8 10 12 14 16 Assignment +3.3V GND +1.5V N/A N/A N/A N/A N/A Description 3.3V Source Return Current Path No Connect No Connect No Connect No Connect No Connect No Connect N/A N/A GND B+ BGND GND AA+ GND GND 3.3V 3.3V GND Reserved Reserved DA 17 19 21 23 25 27 29 31 33 35 37 39 41 43 45 47 49 18 20 22 24 26 28 30 32 34 36 38 40 42 44 46 48 50 GND N/A N/A 3.3V GND 1.5V N/A N/A GND N/A N/A GND N/A N/A N/A +1.5V N/A Presence detection 51 52 3.3V Return Current Path No Connect No Connect 3.3V Source Return Current Path No Connect No Connect No Connect Return Current Path No Connect No Connect Return Current Path No Connect No Connect No Connect No Connect optional Return Current Path**) 3.3V Source *) Device Activity Pin is low in idle mode and high (flickering) during data transfer. It can be optional disconnected on the module on request. **) In standard products pin50 is not connected on the SSD to prevent power short circuit if connected to an eeePC card connector, but could be optional connected to GND Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Swissbit reserves the right to change products or specifications without notice. www.swissbit.com info@swissbit.com Revision: 1.10 X-200m_fact_sheet_SA-UxBR_Rev110 Page 3 of 4 Table 2: System Performance System Performance Data transfer Rate (SATA burst) Sustained Read (max. measured) Sustained Write (max. measured) 1. 2. 2GB 4GB 8...32GB 64GB 64GB ~120 ~95 ~110 ~91 Unit Unit Gbit/s 3.0 (1.5) ~60 ~26 ~110 ~47 MB/s All values refer to modules with Toshiba or Micron Flash chips in UDMA mode 5, SATA 3.0Gbit/s, write/read data sequential 256 Sectors/Transfer command. Sustained speed depends on flash type and number, file size, and burst speed Table 3: Current consumption(1) at 3.3V 3.3V ± 5% Current Consumption Write (UDMA6) Read (UDMA6) Standby 1. Typical 2GB 400 280 180 Typical 4…32GB 450 320 180 Typical 64GB 64GB 400 380 180 max 490 400 200 Unit mA All values are typical at 25° C and nominal supply voltage. Table 4: Environmental Specifications Environmental Specifications Temperature (commercial) Temperature (industrial) Humidity (non-condensing) Vibration (peak -to-peak) Shock Operating Non Operating 0 to 70°C -50 to 100°C -40 to 85°C -50 to 100°C 85% RH, at 85°C max. 95% RH, at 85°C 20G Peak, 10…2000Hz, depends on connector 1500G, 0.5ms duration, half sine wave Table 5: Physical Dimensions Physical Dimensions Unit Width Height Thickness max. Weight (typ.) 29.85 50.8 3.6 10 mm g Table 6: SSD capacity specification Capacity Default_cylinders Default_heads 2GB 4GB 8GB 16GB 32GB 64GB 3,886 7,732 15,498 16,383*) 16,383*) 16383*) 16 16 16 16 16 16 Default_sectors _track 63 63 63 63 63 63 Sectors_drive Sectors_drive 3,896,928 7,793,856 15,621,984 31,277,056 62,586,880 125’313’024 Total addressable capacity (Byte) 1,995,227,136 3,990,454,272 7,998,455,808 16,013,852,672 32,044,482,560 64‘160‘268‘288 *) The CHS addressing is limited to about 8GB. Larger drives should be used in LBA mode. Table 7: System Reliability and Maintenance MTBF (at 25°C) Data Reliability > 2,500,000 hours < 1 Non-Recoverable Error per 1014 bits Read (1) Dependent on final system qualification data. For more information on MO-300 full size mechanical standard, please visit JEDEC at www.jedec.org. For more information on Serial ATA Revision 2.6, please visit Serial ATA International Organization at www.serialata.org Why Swissbit? Swissbit strives to create innovative technologies for future market opportunities utilizing a highly skilled in-house product research and development team. Swissbit maintains a marketing edge by continuing to manufacture world-class high quality memory products and providing customers with both high value and low cost of ownership achieved through efficient processes and procedures. Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Swissbit reserves the right to change products or specifications without notice. www.swissbit.com info@swissbit.com Revision: 1.10 X-200m_fact_sheet_SA-UxBR_Rev110 Page 4 of 4
SFSA32GBU1BR4TO-C-NC-236-STD 价格&库存
很抱歉,暂时无法提供与“SFSA32GBU1BR4TO-C-NC-236-STD”相匹配的价格&库存,您可以联系我们找货
