SFSA480GQ1AA4TO-C-OC-216-STD
    SWISSBIT
    SSD480GB2.5"MLCSATAIII
SFSA480GQ1AA4TO-C-OC-216-STD 数据手册
Product Fact Sheet durabit™ “the better MLC” Industrial 2.5” SATA SSD X-60 Series SATA Gen3 - 6.0 Gbit/s, MLC Commercial and Industrial Temperature Grade Date : Re vi si o n: N ove m be r 05 , 2 0 2 1 1 .0 3 Product Fact Sheet X-60 Series Product Summary      Capacities: 30 GBytes, 60 GBytes, 120 GBytes, 240 GBytes, 480 GBytes, 960 GBytes Form Factor: 2.5" SATA Solid State Drive (70 mm x 100 mm x 7 mm) Compliance: SATA Gen3 - 6 Gbit/s (Gen2 - 3 Gbit/s and Gen1 - 1.5 Gbit/s backward compatible) Command Sets: Supports ATA/ATAPI-8 and ACS-2 Performance: o Read Performance: Sequential Read up to 525 MBytes/s, Random Read 4K up to 74,300 IOPS o Write Performance: Sequential Write up to 460 MBytes/s, Random Write 4K up to 77,900 IOPS  Operating Temperature Range1: o Commercial: 0 °C to 70 °C o Industrial: -40 °C to 85 °C  Storage Temperature Range: -40 °C to 85 °C  Operating Voltage: 5 V ± 10% (3.3 V available upon request)  Power (Max): Read (Active): 2.1 W; Write (Active): 4.0 W; Idle: 525 mW; Slumber: 125 mW  Data Retention: 10 Years @ Life Begin / 1 Year @ Life End  Endurance in TeraBytes Written (TBW) @ Max Capacity2: Client ≥ 2,380; Embedded ≥ 660; Enterprise ≥ 610  Shock/Vibration: 1,500 g / 50 g  High-Performance 32-Bit Processor with Integrated, Parallel Flash Interface Engines: o Multi-Level Cell (MLC) NAND Flash o Hardware BCH Code ECC (up to 66 bit correction per 1 KByte page)   Mean Time Between Failure (MTBF): > 2,000,000 hours Data Reliability: < 1 non-recoverable error per 1016 bits read Product Features     Best-in-Class Performance and Endurance with durabit™ Technology Dynamic and Static Wear Leveling Active and Passive Data Care Management Lifetime Enhancements o Dynamic Bad Block Remapping o Write Amplification Reduction          On-Board Power Fail Protection AHCI, TRIM, and NCQ Support ATA Security Feature Set Support DEVSLP Compatible In-Field Firmware Update Enterprise-Grade Self-Monitoring, Analysis, and Reporting Technology (S.M.A.R.T.) 30 µinch Gold-Plated Connector (IPC-6012B Class 2 Compliant) AES256 Encryption (on request) Swissbit Life Time Monitoring (SBLTM) Tool and SDK for SBLTM (on request) Why Swissbit? Swissbit is focused on the design, development, manufacture, and support of leading edge memory and storage solutions for the worldwide OEM/ODM marketplace. As a global supplier, Swissbit recognizes and addresses the higher level of application requirements of today’s industrial, Netcom, and automotive customers by providing best-in-class products and services, with uncompromised attention to driving overall value and quality. 1 2 Adequate airflow is required to ensure the temperature, as reported in the S.M.A.R.T. data, does not exceed 115°C (industrial temperature drive) and 100°C (commercial temperature drive) respectively. According to JEDEC (JESD47I), the time to write the full TBW is a minimum of 18 months. Higher average daily data volume reduces the specified TBW. The values listed are estimates and are subject to change without notice. Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland TLP: Swissbit public www.swissbit.com/contact Revision: 1.03 Template: Doc-4991 File: X-60_fact_sheet_Rev103 Page 2 of 2
SFSA480GQ1AA4TO-C-OC-216-STD 价格&库存
很抱歉,暂时无法提供与“SFSA480GQ1AA4TO-C-OC-216-STD”相匹配的价格&库存,您可以联系我们找货
