APS1867128G-3BTM
APS1867128G-3BTM
    APACERMEMORYAMERICA(宇瞻科技)
    SSD 128GB 1.8" MLC SATA III 5V
APS1867128G-3BTM 数据手册
SFD18S6-M SFD18S6 SFD18S6-M Overview Apacer’s SFD18S6-M is a well-balanced balanced solid-state solid disk (SSD) drive with compact form factor and great performance. Designed in SATA 6.0 Gbps interface, the SSD is able to deliver exceptional read/write speed, making it the ideal companion for heavy-loading loading industrial or server operations. For data efficiency, the internal controlling unit of the SSD is engineered with DRAM for enhanced random performance. In regard of reliability, the drive comes with various implementations including powerful hardware ECC engine, power saving modes, wear leveling, flash block management, S.M.A.R.T., TRIM, and power failure management. Feature ‧ Compliant with JEDEC MO-297 297 standard ‧ Global Wear-leveling leveling and Block Management ‧ Built-in in ATA Secure Erase and S.M.A.R.T. Functions ‧ TRIM Command Support ‧ DEVSLP Support (Optional) ‧ Power failure management Specifications Model SFD18S6-M Interface SATA 3.0 (6Gb/s) Connector (7+15) pin male Form Factor JEDEC (MO297) NAND Flash Type Capacity External DRAM MLC 32GB~512GB Yes Sustained Read Performance (MB/sec) Up to 510 Sustained Write Performance (MB/sec) Up to 355 ECC Engine Built-in 40-bit per 1K bytes BCH ECC Standard Operating Temperature ( °C ) 0 ~ + 70 Extended Operating Temperature ( °C ) -40 ~ + 85 Storage Temperature ( °C ) -40 ~ + 100 Thermal Sensor Shock Vibration Operating Voltage Power Consumption Dimension (L x W x H ) MTBF (hours) Optional 1500G (complied with MIL-STD810) 15G (complied with MIL-STD810) 5.0 V ± 5% Active mode: 870 mA & Idle mode: 110 mA 54 x 39.8 x 4 (mm) >1,000,000 Mechanical Specification Unit: mm For more information, contact your Apacer representative Global Presence Taiwan (Headquarters) Apacer Technology Inc. Tel: +886-2-2267-8000 Fax: +886-2-2267-2261 Europe Apacer Technology B.V. Tel: +31-40-267-0000 Fax: +31-40-290-0686 Japan Apacer Technology Corp. Tel: +81-3-5419-2668 Fax: +81-3-5419-0018 India Apacer Technologies Pvt. Ltd. Tel: +91-80-41529061~3 Fax: +91-80-41700215 U.S.A. Apacer Memory America, Inc. Tel: +1-408-518-8699 Fax: 1-510-249-9551 China Apacer Electronic(Shanghai) Co., Ltd. Tel: +86-21-6228-9939 DOC:20161116
APS1867128G-3BTM 价格&库存
很抱歉,暂时无法提供与“APS1867128G-3BTM”相匹配的价格&库存,您可以联系我们找货
