APM2T60H200512GAN-3TM
    APACERMEMORYAMERICA(宇瞻科技)
    Solid State Drive (SSD) 512GB SATA III FLASH - NAND (MLC) M.2 Module 3.3V
APM2T60H200512GAN-3TM 数据手册
RoHS Recast Compliant M.2 2260 Flash Drive H200-M Product Specifications March 6, 2015 Version 1.0 Apacer Technology Inc. 1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C Tel: +886-2-2267-8000 www.apacer.com Fax: +886-2-2267-2261 M.2 2260 Flash Drive APM2T60H200xxxxAN-xTMx Features:  Standard SATA Interface Compliance – Serial ATA Revision 3.1 compliance – SATA 6.0 Gbps interface – ATA-8 command set  Capacities – 64, 128, 256, 512 GB     Temperature ranges – Operating: Standard: 0°C to 70°C Extended: -40°C to +85°C – Storage: -40°C to 85°C  Supply voltage – 3.3 V ± 5%  Power consumption (typical)* – Active mode: 2,250 mW – Idle mode: 250 mW Flash Management – Built-in hardware ECC, enabling up to 72 bit correction per 1K bytes – Static/dynamic wear-leveling – Flash bad-block management – S.M.A.R.T. – Power Failure Management – ATA Secure Erase – TRIM  Connector type – 75-pin SATA-based M.2 module pinout  Form factor – M.2 2260 form factor – Dimensions: 60.00x 22.00x3.88, unit: mm  Shock & Vibration*** – Shock:1500 G – Vibration: 15 G NAND Flash Type: MLC  MTBF: >1,000,000 hours  RoHS Recast compliant (complies with 2011/65/EU standard) Performance* – Interface burst read/write: 600 MB/sec – Sustained read: up to 520 MB/sec – Sustained write: up to 380 MB/sec *Varies from capacities. The values for performances and power consumptions presented are typical and may vary depending on flash configurations or platform settings. The term idle refers to the standby state of the device. **Non-operating 1 © 2015 Apacer Technology Inc. Rev. 1.0 M.2 2260 Flash Drive APM2T60H200xxxxAN-xTMx Table of Contents 1. GENERAL DESCRIPTION .................................................................................................... 3 2. PIN ASSIGNMENTS ............................................................................................................... 3 3. PRODUCT SPECIFICATIONS .............................................................................................. 6 3.1 CAPACITY ............................................................................................................................................................. 6 3.2 PERFORMANCE .....................................................................................................................................................6 3.3 ENVIRONMENTAL SPECIFICATIONS .......................................................................................................................7 3.4 MEAN TIME BETWEEN FAILURES (MTBF) ...........................................................................................................7 3.5 CERTIFICATION AND COMPLIANCE .......................................................................................................................7 4. FLASH MANAGEMENT ....................................................................................................... 8 4.1 ERROR CORRECTION/DETECTION .........................................................................................................................8 4.2 BAD BLOCK MANAGEMENT .................................................................................................................................8 4.3 WEAR LEVELING ..................................................................................................................................................8 4.4 POWER FAILURE MANAGEMENT........................................................................................................................... 8 4.5 ATA SECURE ERASE ............................................................................................................................................9 4.6 TRIM ...................................................................................................................................................................9 4.7 SATA POWER MANAGEMENT .............................................................................................................................. 9 5. SOFTWARE INTERFACE .................................................................................................. 10 5.1 COMMAND SET ................................................................................................................................................... 10 5.2 S.M.A.R.T.......................................................................................................................................................... 11 6. ELECTRICAL SPECIFICATION ...................................................................................... 12 7. MECHANICAL SPECIFICATIONS .................................................................................. 13 8. PRODUCT ORDERING INFORMATION ........................................................................ 14 2 © 2015 Apacer Technology Inc. Rev. 1.0 M.2 2260 Flash Drive APM2T60H200xxxxAN-xTMx 1.General Description Apacer’s H200-M is the next generation modularized Solid State Drive (SSD) with the shape of all new M.2 form factor, aimed to be the more suitable for mobile and compact computers with standard width at only 22.00 mm. H200-M appears in M.2 2260 mechanical dimensions and is believed to be the leading add-in storage solution for future host computing systems. The M.2 SSD is designed with SATA-based connector pinouts, providing full compliance with the latest SATA Revision 3.1 interface specifications. Aside from SATA compliance, H200-M delivers exceptional performance and power efficiency. On the other hand, the extreme thin and light form factor makes H200M the ideal choice for mobile computing systems, which appears to be the trend in near future. Regarding reliability, H200-M is built with a powerful SATA controller that supports on-the-module ECC as well as efficient wear leveling scheme. In terms of power efficiency, H200-M is compliant with SATA 6.0 Gbps interface standard so that it can operate on SATA power management modes, which greatly save on power consumption. 2. Pin Assignments This connector does not support hot plug capability. There are a total of 75 pins. 12 pin locations are used for mechanical key locations; this allows such a module to plug into both Key B and Key M connectors. Notch M Notch B Pin1 Pin Type Description 1 CONFIG_3 Ground (according to M.2 configurations for SSD-SATA definition) 2 3.3V Supply Pin, 3.3V 3 GND Ground 4 3.3V Supply pin, 3.3V 5 No connect No connect 6 Not available No connect (used for other purposes) 7 Not available No connect (used for other purposes) 8 Not available No connect (used for other purposes) 9 No connect No connect 10 DAS/DSS Device Activity Signal/Disable Staggered Spin-up 3 © 2015 Apacer Technology Inc. Rev. 1.0 M.2 2260 Flash Drive APM2T60H200xxxxAN-xTMx 11 No connect No connect (used for other purposes) 12 Module key 13 Module key 14 Module key 15 Module key 16 Module key 17 Module key 18 Module key 19 Module key 20 Not available No connect (used for other purposes) 21 CONFIG_0 Ground (according to M.2 configurations for SSD-SATA definition) 22 Not available No connect (used for other purposes) 23 Not available No connect (used for other purposes) 24 Not available No connect (used for other purposes) 25 Not available No connect (used for other purposes) 26 Not available No connect (used for other purposes) 27 GND Ground 28 Not available No connect (used for other purposes) 29 Not available No connect 30 Not available No connect (used for other purposes) 31 Not available No connect 32 Not available No connect (used for other purposes) 33 GND Ground 34 Not available No connect (used for other purposes) 35 Not available No connect 36 Not available No connect (used for other purposes) 37 Not available No connect 38 Not available No connect 39 GND Ground 40 Not available No connect (used for other purposes) 41 SATA-Rx+ Host receiver differential signal pair 42 Not available No connect (used for other purposes) 43 SATA-Rx- Host receiver differential signal pair 44 Not available No connect (used for other purposes) 45 GND Ground 46 Not available No connect (used for other purposes) 47 SATA-Tx- Host transmitter differential pair 4 © 2015 Apacer Technology Inc. Rev. 1.0 M.2 2260 Flash Drive APM2T60H200xxxxAN-xTMx 48 Not available No connect (used for other purposes) 49 SATA-Tx+ Host transmitter differential pair 50 Not available No connect 51 GND Ground 52 Not available Not used 53 Not available Not used 54 Not available Not used 55 Not available Not used 56 Reserved for MFG Data Manufacturing Data line. Used for SSD manufacturing only. Not used in normal operation. Pins should be left N/C in platform Socket. 57 GND Ground 58 Reserved for MFG clock Manufacturing Clock line. Used for SSD manufacturing only. Not used in normal operation. Pins should be left N/C in platform Socket 59 Module key 60 Module key 61 Module key 62 Module key 63 Module key 64 Module key 65 Module key 66 Module key 67 Not available No connect (used for other purposes) 68 SUSCLK 32 kHz clock supply input that is provided by PCH to reduce power and cost for the module 69 CONFIG_1 Defines module type 70 3.3V Supply pin, 3.3V 71 GND Ground 72 3.3V Supply pin, 3.3V 73 GND Ground 74 3.3V Supply pin, 3.3V 75 CONFIG_2 Ground 5 © 2015 Apacer Technology Inc. Rev. 1.0 M.2 2260 Flash Drive APM2T60H200xxxxAN-xTMx 3. Product Specifications 3.1 Capacity Capacity specification of H200-M is available as shown in Table 3-1. It lists the specific capacity and the default numbers of heads, sectors and cylinders for each product line. Table 3-1: Capacity specifications Capacity Total Bytes Cylinders Heads Sectors Max LBA 64 GB 64,023,257,088 16,383 16 63 125,045,424 128 GB 128,035,676,160 16,383 16 63 250,069,680 256 GB 256,060,514,304 16,383 16 63 500,118,192 512 GB 512,110,190,592 16,383 16 63 1,000,215,216 *Display of total bytes varies from file systems, which means not all of the bytes can be used for storage. **Notes: 1 GB = 1,000,000,000 bytes; 1 sector = 512 bytes. LBA count addressed in the table above indicates total user storage capacity and will remain the same throughout the lifespan of the device. However, the total usable capacity of the SSD is most likely to be less than the total physical capacity because a small portion of the capacity is reserved for device maintenance usages. 3.2 Performance Performances of H200-M are listed below in table 3-2. Table 3-2: Performance Capacity 64 GB 128 GB 256 GB 512 GB Sustained read (MB/s) 520 520 520 520 Sustained write (MB/s) 190 350 370 380 Performance Note: Results were measured by CrystalDiskMark benchmark and may differ from various flash configurations or host system setting 6 © 2015 Apacer Technology Inc. Rev. 1.0 M.2 2260 Flash Drive APM2T60H200xxxxAN-xTMx 3.3 Environmental Specifications Environmental specification of H200-M series follows MIL-STD-810 standards as shown in Table 3-3. Table 3-3 H200-M environmental specifications Item Specification Operating temperature 0℃~70℃(standard) ; -40℃~85℃(extended) ; Non-operating temperature -40℃~85℃ Operating humidity 40℃, 90%RH Non-operating humidity 40℃, 93%RH Frequency/Displacement: 20Hz~80Hz/1.52mm Frequency/Acceleration: 80Hz~2000Hz/20G X, Y, Z axis/30mins 500G, 2ms Vibration (Non-operating) shock (Non-operating) Drop (Non-operating) Bending (non-operating) Torque (non-operating) ESD (Electrostatic) 110cm free fall, 6 face of each unit ≧10N, hold 1min/5times 0.5N-m or 5 deg, hold 5min/5times Passed (at relative temp/humidity: 24℃, 49%RH) 3.4 Mean Time Between Failures (MTBF) Mean Time Between Failures (MTBF) is predicted based on reliability data for the individual components in H200-M. The prediction result for H200-M is more than 1,000,000 hours. Notes about the MTBF: The MTBF is predicated and calculated based on “Telcordia Technologies Special Report, SR-332, Issue 2” method. 3.5 Certification and Compliance H200-M complies with the following standards:     CE FCC BSMI RoHS Recast 7 © 2015 Apacer Technology Inc. Rev. 1.0 M.2 2260 Flash Drive APM2T60H200xxxxAN-xTMx 4. Flash Management 4.1 Error Correction/Detection H200-M implements a hardware ECC scheme, based on the BCH algorithm. It can detect and correct up to 72 bits error in 1K bytes. 4.2 Bad Block Management Bad blocks are blocks that include one or more invalid bits, and their reliability is not guaranteed. Blocks that are identified and marked as bad by the manufacturer are referred to as “Initial Bad Blocks”. Bad blocks that are developed during the lifespan of the flash are named “Later Bad Blocks”. Apacer implements an efficient bad block management algorithm to detect the factory-produced bad blocks and manages any bad blocks that appear with use. This practice further prevents data being stored into bad blocks and improves the data reliability. 4.3 Wear Leveling NAND flash devices can only undergo a limited number of program/erase cycles, and in most cases, the flash media are not used evenly. If some areas get updated more frequently than others, the lifetime of the device would be reduced significantly. Thus, Wear Leveling is applied to extend the lifespan of NAND flash by evenly distributing write and erase cycles across the media. Apacer provides advanced Wear Leveling algorithm, which can efficiently spread out the flash usage through the whole flash media area. Moreover, by implementing both dynamic and static Wear Leveling algorithms, the life expectancy of the NAND flash is greatly improved. 4.4 Power Failure Management Power Failure Management is a mechanism to prevent data loss during unexpected power failure. DRAM is a volatile memory and frequently used as temporary cache or buffer between the controller and the NAND flash to improve the SSD performance. However, one major concern of the DRAM is that it is not able to keep data during power failure. Accordingly, H200-M applies the flush mechanism, which requests the controller to transfer data to the cache. For H200-M, DDR performs as a cache. Only when the data is fully committed to the NAND flash will the controller send acknowledgement (ACK) to the host. Such implementation can prevent false-positive performance and the risk of power cycling issues. Additionally, it is critical for a controller to shorten the time the in-flight data stays in the cache. Thus, H200-M applies an algorithm to reduce the amount of data resides in the cache to provide a better performance. This algorithm allows incoming data to only have a “pit stop” in the cache and then move to the NAND flash at once. If the flash is jammed due to particular file sizes (such as random 4KB data), the cache will be treated as an “organizer”, consolidating incoming data into groups before written into the flash to improve write amplification. In sum, Power Failure Management proves to provide the reliability required by consumer, industrial, and enterprise-level applications. 8 © 2015 Apacer Technology Inc. Rev. 1.0 M.2 2260 Flash Drive APM2T60H200xxxxAN-xTMx 4.5 ATA Secure Erase ATA Secure Erase is a standard ATA command and will write all “0xFF” to fully wipe all the data on hard drives and SSDs. When this command is issued, the SSD controller will empty its storage blocks and return to its factory default settings. 4.6 TRIM TRIM is a feature which helps improve the read/write performance and speed of solid-state drives (SSD). Unlike hard disk drives (HDD), SSDs are not able to overwrite existing data, so the available space gradually becomes smaller with each use. With the TRIM command, the operating system can inform the SSD which blocks of data are no longer in use and can be removed permanently. Thus, the SSD will perform the erase action, which prevents unused data from occupying blocks all the time. 4.7 SATA Power Management By complying with SATA 6.0 Gb/s specifications, the SSD supports the following SATA power saving modes:  ACTIVE: PHY ready, full power, Tx & Rx operational  PARTIAL: Reduces power, resumes in under 10 µs (microseconds)  SLUMBER: Reduces power, resumes in under 10 ms (milliseconds)  HIPM: Host-Initiated Power Management  DIPM: Device-Initiated Power Management Note: 1. The behaviors of power management features would depend on host/device settings. 9 © 2015 Apacer Technology Inc. Rev. 1.0 M.2 2260 Flash Drive APM2T60H200xxxxAN-xTMx 5. Software Interface 5.1 Command Set Table 5-1: Command set Command Code Command Code CHECK Power Mode E5h Security Disable Password F6h Data Set Management 06h Security Erase Prepare F3h DCO B1h Security Erase Unit F4h Download Microcode PIO 92h Security Freeze Lock F5h Download Microcode DMA 93h Security Set Password F1h Execute Drive Diagnostic 90h Security Unlock F2h Flush Cache E7h Seek 70h Flush Cache Ext Eah Set Features Efh Identify Device Ech Set Max Address F9h Idle E3h Set Max Address Ext 37h Idle Immediate E1h Set Multiple Mode C6h Initialize Drive Parameters 91h Sleep E6h Read Buffer E4h SMART B0h Read DMA (W/O retry) C9h Standby E2h Read DMA (W/ retry) C8h Standby Immediate E0h Read DMA Ext 25h Write Buffer E8h Read FPDMA Queued 60h Write DMA (W/O retry) CBh Read Log Ext 2Fh Write DMA (W/ retry) Cah Read Multiple C4h Write DMA Ext 35h Read Multiple Ext 29h Write DMA FUA Ext 3Dh Read Native Max Address F8h Write FPDMA Queued 61h Read Native Max Ext 27h Write Log Ext 3Fh Read Sector(s) (W/O retry) 21h Write Multiple C5h Read Sector(s) (W/ retry) 20h Write Multiple Ext 39h Read Sector(s) Ext 24h Write Multiple FUA Ext Ceh Read Verify Ext 42h Write Sector(s) (W/O retry) 31h Read Verify Sector(s) (W/O retry) 41h Write Sector(s) (W/ retry) 30h Read Verify sector(s) (W/ retry) 40h Write Sector(s) Ext 34h Recalibrate 10h Write Uncorrectable 45h 10 © 2015 Apacer Technology Inc. Rev. 1.0 M.2 2260 Flash Drive APM2T60H200xxxxAN-xTMx 5.2 S.M.A.R.T. SMART, an acronym for Self-Monitoring, Analysis and Reporting Technology, is an open standard that allows a hard disk drive to automatically detect its health and report potential failures. When a failure is recorded by SMART, users can choose to replace the drive to prevent unexpected outage or data loss. Moreover, SMART can inform users of impending failures while there is still time to perform proactive actions, such as copy data to another device. 11 © 2015 Apacer Technology Inc. Rev. 1.0 M.2 2260 Flash Drive APM2T60H200xxxxAN-xTMx 6. Electrical Specification Table 6-1: Operating range Supply Voltage 3.3V±5% (3.135-3.465V) Table 6-2: Typical power consumption Capacity 64 GB 128 GB 256 GB 512 GB Active (mW) 1485 1620 1630 2250 Idle (mW) 220 230 250 250 Modes Note: Results may differ from various flash configurations or host system setting 12 © 2015 Apacer Technology Inc. Rev. 1.0 M.2 2260 Flash Drive APM2T60H200xxxxAN-xTMx 7. Mechanical Specifications Unit: ㎜ Tolerance: ± 0.25 13 © 2015 Apacer Technology Inc. Rev. 1.0 M.2 2260 Flash Drive APM2T60H200xxxxAN-xTMx 8. Product Ordering Information 8.1 AP Product Code Designations M2 T60 H200 xxxx AN – x TM x Blank: Standard W: Extended Flash Type Version Control Apacer Brand Capacities: 64G= 128G = 256G= 512G= 64GB 128GB 256GB 512GB Solution version Form Factor M.2 Apacer Product Code 14 © 2015 Apacer Technology Inc. Rev. 1.0 M.2 2260 Flash Drive APM2T60H200xxxxAN-xTMx 8.2 Valid Combinations Capacity Standard Extended 64GB 128GB 256GB APM2T60H200064GAN-3TM APM2T60H200128GAN-3TM APM2T60H200256GAN-3TM APM2T60H200064GAN-3TMW APM2T60H200128GAN-3TMW APM2T60H200256GAN-3TMW 512GB APM2T60H200512GAN-3TM APM2T60H200512GAN-3TMW Note: Valid combinations are those products in mass production or will be in mass production. Consult your Apacer sales representative to confirm availability of valid combinations and to determine availability of new combinations. 15 © 2015 Apacer Technology Inc. Rev. 1.0 M.2 2260 Flash Drive APM2T60H200xxxxAN-xTMx Revision History Revision 1.0 Date Description 03/06/2015 Official release Remark 16 © 2015 Apacer Technology Inc. Rev. 1.0 M.2 2260 Flash Drive APM2T60H200xxxxAN-xTMx Global Presence Taiwan (Headquarters) Apacer Technology Inc. Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: 886-2-2267-8000 Fax: 886-2-2267-2261 amtsales@apacer.com U.S.A. Apacer Memory America, Inc. 386 Fairview Way, Suite102, Milpitas, CA 95035 Tel: 1-408-518-8699 Fax: 1-408-935-9611 sa@apacerus.com Japan Apacer Technology Corp. 5F, Matsura Bldg., Shiba, Minato-Ku Tokyo, 105-0014, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Europe Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-267-0000#6199 sales@apacer.nl China Apacer Electronic (Shanghai) Co., Ltd 1301, No.251,Xiaomuqiao Road, Shanghai, 200032, China Tel: 86-21-5529-0222 Fax: 86-21-5206-6939 sales@apacer.com.cn India Apacer Technologies Pvt Ltd, # 535, 1st Floor, 8th cross, JP Nagar 3rd Phase, Bangalore – 560078, India Tel: 91-80-4152-9061 sales_india@apacer.com 17 © 2015 Apacer Technology Inc. Rev. 1.0
物料型号:APM2T60H200xxxxAN-xTMx
器件简介: - 支持SATA接口,符合Serial ATA Revision 3.1规范,SATA 6.0 Gbps接口和ATA-8命令集 - 容量可选:64GB、128GB、256GB、512GB - 具备硬件ECC,支持每1K字节72位错误校正 - 支持S.M.A.R.T.、电源故障管理和TRIM操作 - NAND Flash类型为MLC
引脚分配: - 总共75个引脚,12个用于机械键位 - 引脚2为3.3V供电,引脚3和4为地线 - 引脚41和43为SATA接收差分信号对,引脚47和49为SATA发送差分信号对
参数特性: - 工作温度范围:标准型0°C至70°C,扩展型-40°C至85°C - 存储温度范围:-40°C至85°C - 典型工作状态下的功耗:主动模式2250mW,空闲模式250mW - 抗冲击:1500G - 振动:15G - 平均无故障时间(MTBF):大于100万小时 - 符合RoHS Recast指令(2011/65/EU)
功能详解: - 支持静态/动态磨损平衡算法和闪存坏块管理 - 支持ATA安全擦除,以确保数据安全 - TRIM功能帮助提高固态硬盘的读写性能和速度
应用信息: - 适用于移动和紧凑型计算机,特别是那些宽度仅为22.00mm的设备 - 采用M.2 2260外形尺寸,是未来主机计算系统的主要附加存储解决方案
封装信息: - M.2 2260封装类型,尺寸为60.00x22.00x3.88毫米
APM2T60H200512GAN-3TM 价格&库存
很抱歉,暂时无法提供与“APM2T60H200512GAN-3TM”相匹配的价格&库存,您可以联系我们找货
