APS18SH1128G-2TM
APS18SH1128G-2TM
    APACERMEMORYAMERICA(宇瞻科技)
    Solid State Drive (SSD) 128GB SATA III FLASH - NAND (MLC) Slim-SATA 5V
APS18SH1128G-2TM 数据手册
RoHS Compliant SATA Flash Drive SFD18SH-M Product Specifications November 25th, 2014 Version 1.4 Apacer Technology Inc. 1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C Tel: +886-2-2267-8000 www.apacer.com Fax: +886-2-2267-2261 Serial ATA Flash Drive APS18SH1xxxx-XTMX Features: Serial ATA Revision 3.1 Compliance SATA 6.0 Gbps interface Backward compatible with SATA 3.0/1.5 Gbps interface ATA Command set Temperature ranges Operating: Standard: 0°C to 70°C Extended: -40°C to 85°C Storage: -40°C to 85°C Capacities 16, 32, 64, 128, 256 GB Supply voltage 5 V 5% Performance* Interface burst read/write: 600 MB/sec Sustained read: up to 510 MB/sec Sustained write: up to 190 MB/sec Power consumption (typical)* Active mode : 1,960 mW Idle mode : 285 mW Flash endurance design Built-in hardware ECC Wear-leveling Flash bad block management S.M.A.R.T. Power Failure Management TRIM Connector 7-pin SATA male connector 15-pin SATA power connector Form factor JEDEC MO-297 Dimensions (54.0 x 39.8 x 4.0, unit: mm) RoHS compliant Device Sleep mode (optional) NAND Flash Type: MLC Endurance 16GB : 27 TBW 32GB : 54 TBW 64GB : 108 TBW 128GB : 217 TBW 256GB : 434 TBW *The values presented for Performances and Power Consumption are typical and may vary depending on different configurations and platforms. 1 © 2014 Apacer Technology Inc. Rev. 1.4 Serial ATA Flash Drive APS18SH1xxxx-XTMX Table of Contents 1. Product Description ................................................................................................. 3 1.1 Introduction ................................................................................................................................................. 3 1.2 Capacity Specification.................................................................................................................................3 1.3 Performance................................................................................................................................................. 3 1.4 Pin Assignments ..........................................................................................................................................4 2. Software Interface .................................................................................................... 6 2.1 Command Set ..............................................................................................................................................6 2.2 S.M.A.R.T. ................................................................................................................................................... 7 3. Flash Management ................................................................................................... 8 3.1 Error Correction/Detection ........................................................................................................................8 3.2 Bad Block Management ..............................................................................................................................8 3.3 Wear Leveling ..............................................................................................................................................8 3.4 Power Failure Management ........................................................................................................................8 3.5 TRIM ............................................................................................................................................................8 3.6 Secure Erase ................................................................................................................................................. 9 4. Reliability Specifications ....................................................................................... 10 4.1 Environments............................................................................................................................................. 10 4.2 Mean Time Between Failures (MTBF) ....................................................................................................10 4.3 Certification and Compliance .................................................................................................................. 10 4.4 Endurance .................................................................................................................................................. 11 5. Electrical Characteristics ...................................................................................... 12 5.1 Operating Voltage .....................................................................................................................................12 5.2 Power Consumption .................................................................................................................................. 12 6. Mechanical Specifications ..................................................................................... 13 7. Product Ordering Information ............................................................................... 14 7.1 Product Code Designations ........................................................................................................................ 14 7.2 Valid Combinations................................................................................................................................... 15 2 © 2014 Apacer Technology Inc. Rev. 1.4 Serial ATA Flash Drive APS18SH1xxxx-XTMX 1. Product Description 1.1 Introduction Apacer SFD18SH-M half-slim MO-297 SSD (Solid State Drive) delivers multiple technological advantages of flash memory storage. With SATA 6.0 Gbps interface, SFD18SH-M offers exceptional data transfer performance. Form factor wise, this model is fully compliant with JEDEC MO-297 standard, which is designed with standard interface consisting of SATA 7-pin signal segment and 15-pin power segment, while in compact size. This module provides low power consumption compared to traditional hard drive and hotswapping when removing/ replacing/ upgrading flash disks. Its capacity could provide a wide range up to 256GB. Moreover, it can reach up to 510MB/s read as well as 190MB/s write high performance. 1.2 Capacity Specification Table 1-1 Capacity specification Capacity Total Bytes* Cylinders Heads Sectors 16 GB Max LBA** 16,013,942,784 16,383 16 63 31,277,232 32 GB 32,017,047,552 16,383 16 63 62,533,296 64 GB 64,023,257,088 16,383 16 63 125,045,424 128 GB 128,035,676,160 16,383 16 63 250,069,680 256 GB 256,060,514,304 16,383 16 63 500,118,192 *Display of total bytes varies from file systems. **Cylinders, heads or sectors are not applicable for these capacities. Only LBA addressing applies. ***Notes: 1 GB = 1,000,000,000 bytes; 1 sector = 512 bytes. LBA count addressed in the table above indicates total user storage capacity and will remain the same throughout the lifespan of the device. However, the total usable capacity of the SSD is most likely to be less than the total physical capacity because a small portion of the capacity is reserved for device maintenance usages. 1.3 Performance Table 1-2 Performance specifications Capacity Performance Sustained Read (MB/s) Sustained Write (MB/s) 16 GB 32 GB 64 GB 128 GB 256 GB 315 480 480 480 510 150 150 180 180 190 Note: 1. Results may vary depending on host system configurations. 2. Sustained Read/Write: The read/write performances are measured by CrystalDiskMark under Windows 7 operating system. 3 © 2014 Apacer Technology Inc. Rev. 1.4 Serial ATA Flash Drive APS18SH1xxxx-XTMX 1.4 Pin Assignments Table 1-4: Signal segment Pin Type S1 GND S2 RxP S3 RxN S4 GND S5 TxN S6 TxP S7 GND Table 1-5: Power segment Description Serial Data Receiver Signal Pair Serial Data Transmitter Signal Pair Pin Signal/Description P1 Not used (3.3V) P2 Not used (3.3V) P3 Not used or Device Sleep P4 Ground P5 Ground P6 Ground P7 5V P8 5V P9 5V P10 Ground P11 Reserved P12 Ground P13 Not used (12V) P14 Not used (12V) P15 Not used (12V) P3 can be configured as trigger pin for Device Sleep 4 © 2014 Apacer Technology Inc. Rev. 1.4 Serial ATA Flash Drive APS18SH1xxxx-XTMX Figure 1-3 SATA Cable / Connector Connection Diagram The connector on the left represents the Host with TX/RX differential pairs connected to a cable while the connector on the right shows the Device with TX/RX differential pairs also connected to the cable. Notice also the ground path connecting the shielding of the cable to the Cable Receptacle. 5 © 2014 Apacer Technology Inc. Rev. 1.4 Serial ATA Flash Drive APS18SH1xxxx-XTMX 2. Software Interface 2.1 Command Set Command Code Command Code NOP 00h Idle 97h Data Set Management 06h Check Power Mode 98h 10f-1Fh Sleep 99h Recalibrate Read Sectors 20h SMART B0h Read Sectors without Retry 21h Device Configuration B1h Read Sectors EXT 24h Read Multiple C4h Read DMA EXT 25h Write Multiple C5h Read Native Max Address EXT 27h Set Multiple Mode C6h Read Multiple EXT 29h Read DMA C8h Read Log EXT 2Fh Read DMA without Retry C9h Write Sectors 30h Write DMA CAh Write Sectors Without Retry Write Sectors EXT 31h Write DMA without Retry CBh 34h Write Multiple FUA EXT Ceh Write DMA EXT 35h Standby Immediate E0h Set Native Max Address EXT 37h Idle Immediate E1h CFA Write Sectors without erase 38h Standby E2h Write Multiple EXT 39h Idle E3h Write DMA FUA EXT 3Dh Read Buffer E4h Write Long EXT 3Fh Check Power Mode E5h Read Verify Sectors 40h Sleep E6h Read Verify Sectors without Retry 41h Flush Cache E7h Read Verify Sectors EXT 42h Write Buffer E8h Write Uncorrectable EXT 45h Flush Cache EXT Eah Read FPDMA Queued 60h Identify Device Ech Write FPDMA Queued 61h Set Features Efh Seek 70h-7Fh Security Set Password F1h Execute Device Diagnostic 90h Security Unlock F2h Initialize Device Parameters 91h Security Erase Prepare F3h Download Microcode 92h Security Erase Unit F4h Download Microcode DMA 93h Security Freeze Lock F5h Standby Immediate 94h Security Disable Password F6h Idle Immediate 95h Read Native Max Address F8h Standby 96h Set Max Address F9h 6 © 2014 Apacer Technology Inc. Rev. 1.4 Serial ATA Flash Drive APS18SH1xxxx-XTMX 2.2 S.M.A.R.T. SMART, an acronym for Self-Monitoring, Analysis and Reporting Technology, is an open standard that allows a hard disk drive to automatically detect its health and report potential failures. When a failure is recorded by SMART, users can choose to replace the drive to prevent unexpected outage or data loss. Moreover, SMART can inform users of impending failures while there is still time to perform proactive actions, such as copy data to another device. 7 © 2014 Apacer Technology Inc. Rev. 1.4 Serial ATA Flash Drive APS18SH1xxxx-XTMX 3. Flash Management 3.1 Error Correction/Detection Flash memory cells will deteriorate with use, which might generate random bit errors in the stored data. Thus, this SSD applies the BCH ECC Algorithm, which can detect and correct errors occur during Read process, ensure data been read correctly, as well as protect data from corruption. This ECC supports up to 72bit/1K data. 3.2 Bad Block Management Bad blocks are blocks that include one or more invalid bits, and their reliability is not guaranteed. Blocks that are identified and marked as bad by the manufacturer are referred to as Initial Bad Blocks . Bad blocks that are developed during the lifespan of the flash are named Later Bad Blocks . Apacer implements an efficient bad block management algorithm to detect the factory-produced bad blocks and manages any bad blocks that appear with use. This practice further prevents data being stored into bad blocks and improves the data reliability. 3.3 Wear Leveling NAND Flash devices can only undergo a limited number of program/erase cycles, and in most cases, the flash media are not used evenly. If some areas get updated more frequently than others, the lifetime of the device would be reduced significantly. Thus, Wear Leveling technique is applied to extend the lifespan of NAND Flash by evenly distributing write and erase cycles across the media. Apacer provides advanced Wear Leveling algorithm, which can efficiently spread out the flash usage through the whole flash media area. Moreover, by implementing both dynamic and static Wear Leveling algorithms, the life expectancy of the NAND Flash is greatly improved. 3.4 Power Failure Management Power Failure Management plays a crucial role when experiencing unstable power supply. Power disruption may occur when users are storing data into the SSD. In this urgent situation, the controller would run multiple flush cycles to store the metadata for later block rebuilding. This urgent operation requires about several milliseconds to get it done. At the next power up, the firmware will perform a status tracking to retrieve the mapping table and resume previously programmed NAND blocks to check if there is any incompleteness of transmission. 3.5 TRIM TRIM is a feature which helps improve the read/write performance and speed of solid-state drives (SSD). Unlike hard disk drives (HDD), SSDs are not able to overwrite existing data, so the available space gradually becomes smaller with each use. With the TRIM command, the operating system can inform the SSD which blocks of data are no longer in use and can be removed permanently. Thus, the SSD will perform the erase action, which prevents unused data from occupying blocks all the time. 8 © 2014 Apacer Technology Inc. Rev. 1.4 Serial ATA Flash Drive APS18SH1xxxx-XTMX 3.6 Secure Erase Secure Erase is a standard ATA command and will write all 0xFF SSDs. When this command is issued, the SSD controller will empty its storage blocks and return to its factory default settings. Note. Secure erase command belongs to ATA security command. 9 © 2014 Apacer Technology Inc. Rev. 1.4 Serial ATA Flash Drive APS18SH1xxxx-XTMX 4. Reliability Specifications 4.1 Environments Table 4-1 SFD18SH-M environmental specifications Environment Specification 0°C to 70°C (Operating) / -40 C to 85 C (Extended) Temperature -40 C to 85 C (in storage) RH 93% under 40 C Humidity 1500G, 0.5ms Shock 20Hz~80Hz/1.52mm (frequency/displacement) 80Hz~2000Hz/20G (frequency/displacement) Vibration X, Y, Z axis/60mins each 80cm free fall, 6 face of each Drop 20N, hold 1min/5times Bending 0.5N-m or 2.5deg , hold 1min/5times Torque Pass ESD Note: Shock and Vibration specifications are subject to change without notice. 4.2 Mean Time Between Failures (MTBF) Mean Time Between Failures (MTBF) is predicted based on reliability data for the individual components in SFD drive. The prediction result for SFD18SH-M is more than 1,000,000 hours. Notes about the MTBF: The MTBF is predicated and calculated based on Telcordia Technologies Special Report, SR-332, Issue 2 method. 4.3 Certification and Compliance RoHS SATA Revision 3.0 ATA/ATAPI FCC CE BSMI 10 © 2014 Apacer Technology Inc. Rev. 1.4 Serial ATA Flash Drive APS18SH1xxxx-XTMX 4.4 Endurance The endurance of a storage device is predicted by TeraBytes Written based on several factors related to usage, such as the amount of data written into the drive, block management conditions, and daily workload for the drive. Thus, key factors, such as Write Amplifications and the number of P/E cycles, can influence the lifespan of the drive. Capacity TeraBytes Written 16 GB 27 32 GB 54 64 GB 108 128 GB 217 256 GB 434 Notes: The measurement assumes the data written to the SSD for test is under a typical and constant rate. The measurement follows the standard metric: 1 TB (Terabyte) = 1000 GB. 11 © 2014 Apacer Technology Inc. Rev. 1.4 Serial ATA Flash Drive APS18SH1xxxx-XTMX 5. Electrical Characteristics 5.1 Operating Voltage Table 5-1 lists the supply voltage for SFD18SH-M. Table 5-1 SFD18SH-M operating voltage Parameter Conditions Supply voltage 5.2 5V ±5% Power Consumption Table 5-2 lists SFD18SH-M power consumption. Table 5-2 SFD18SH-M power consumption Capacity Performance Active (mW) Idle (mW) 16 GB 32 GB 64 GB 128 GB 256 GB 995 1090 1465 1760 1960 280 265 275 285 285 Note: power consumption may vary depending on flash configurations or platforms.. 12 © 2014 Apacer Technology Inc. Rev. 1.4 Serial ATA Flash Drive APS18SH1xxxx-XTMX 6. Mechanical Specifications Unit: Tolerance: 0.2 13 © 2014 Apacer Technology Inc. Rev. 1.4 Serial ATA Flash Drive APS18SH1xxxx-XTMX 7. Product Ordering Information 7.1 Product Code Designations AP S 18SH 1 xxxx X TM X Operating Temperature Range Blank: 0 ~ 70 W: -40 ~ 85 Flash Type Version Control Capacities: 016G = 16GB 032G = 32GB 064G = 64GB 128G = 128GB 256G = 256GB Solution version MO-297 Form Factor Serial ATA Flash Drive Apacer Product Code 14 © 2014 Apacer Technology Inc. Rev. 1.4 Serial ATA Flash Drive APS18SH1xxxx-XTMX 7.2 Valid Combinations 7.2.1 Operating Temperature (0 APS18SH1016G-1TM APS18SH1032G-1TM APS18SH1064G-1TM APS18SH1128G-1TM APS18SH1256G-1TM 7.2.2 Operating Temperature (-40 Capacity ) No DEVSLP Capacity 16 GB 32 GB 64 GB 128 GB 256 GB ~ 70 ~ 85 DEVSLP APS18SH1016G-2TM APS18SH1032G-2TM APS18SH1064G-2TM APS18SH1128G-2TM APS18SH1256G-2TM ) No DEVSLP DEVSLP 16 GB 32 GB 64 GB APS18SH1016G-1TMW APS18SH1032G-1TMW APS18SH1064G-1TMW APS18SH1016G-2TMW APS18SH1032G-2TMW APS18SH1064G-2TMW 128 GB 256 GB APS18SH1128G-1TMW APS18SH1256G-1TMW APS18SH1128G-2TMW APS18SH1256G-2TMW Note: Please consult with Apacer sales representatives for availabilities. 15 © 2014 Apacer Technology Inc. Rev. 1.4 Serial ATA Flash Drive APS18SH1xxxx-XTMX Revision History Revision Description Date 1.0 Official release 07/04/2014 1.1 Added 16GB model 10/14/2014 Added Extended temperature specifications 1.2 Revised Serial ATA spec support : 3.0 -> 3.1 11/07/2014 1.3 Added endurance information 11/20/2014 1.4 Revise 16GB performance 11/25/2014 16 © 2014 Apacer Technology Inc. Rev. 1.4 Serial ATA Flash Drive APS18SH1xxxx-XTMX Global Presence Taiwan (Headquarters) Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: 886-2-2267-8000 Fax: 886-2-2267-2261 amtsales@apacer.com U.S.A. Apacer Memory America, Inc. 386 Fairview Way, Suite102, Milpitas, CA 95035 Tel: 1-408-518-8699 Fax: 1-408-935-9611 sa@apacerus.com Japan Apacer Technology Corp. 5F, Matsura Bldg., Shiba, Minato-Ku Tokyo, 105-0014, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Europe Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-267-0000#6199 sales@apacer.nl China Apacer Electronic (Shanghai) Co., Ltd 1301, No.251,Xiaomuqiao Road, Shanghai, 200032, China Tel: 86-21-5529-0222 Fax: 86-21-5206-6939 sales@apacer.com.cn India Apacer Technologies Pvt Ltd, # 535, 1st Floor, 8th cross, JP Nagar 3rd Phase, Bangalore 560078, India Tel: 91-80-4152-9061 sales_india@apacer.com 17 © 2014 Apacer Technology Inc. Rev. 1.4
APS18SH1128G-2TM 价格&库存
很抱歉,暂时无法提供与“APS18SH1128G-2TM”相匹配的价格&库存,您可以联系我们找货
