APS18HPA512G-3TM
APS18HPA512G-3TM
    APACERMEMORYAMERICA(宇瞻科技)
    SSD512GB1.8"MLCSATAIII3.3V
APS18HPA512G-3TM 数据手册
RoHS Compliant SATA Flash Drive SFD18H-M Product Specifications January 28, 2015 Version 1.2 Apacer Technology Inc. 1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C Tel: +886-2-2267-8000 www.apacer.com Fax: +886-2-2267-2261 Serial ATA Flash Drive APS18HPAxxxG-3TMX Features:  Serial ATA Revision 3.0 Compliance – SATA 6.0 Gbps interface – Backward compatible with SATA 3.0/1.5 Gbps interface – ATA Command set  Temperature ranges – Operating: Standard: 0°C to 70°C Extended: -40°C to 85°C – Storage: -40°C to 85°C  Capacities – 32, 64, 128, 256, 512 GB  Supply voltage – 3.3V ± 5%  Performance* – Interface burst read/write: 600 MB/sec – Sustained read: up to 525 MB/sec – Sustained write: up to 485 MB/sec  Power consumption (typical)* – Active mode: 1,690 mA – Idle mode: 120 mA   Flash endurance design – Built-in hardware ECC, enabling up to 72 bit correction per 1K Bytes – Wear-leveling – Flash bad block management – S.M.A.R.T. – Power Failure Management – TRIM Form factor – 1.8”  NAND Flash Type: MLC  MTBF (hours): >1,000,000 – Dimensions (78.5 x 54.0 x 5.0, unit: ㎜)  Connector – 7-pin SATA male connector – 9-pin SATA power connector  RoHS compliant *The values presented for Performances and Power Consumption are typical and may vary depending on different configurations and platforms. 1 © 2015 Apacer Technology Inc. Rev. 1.2 Serial ATA Flash Drive APS18HPAxxxG-3TMX Table of Contents 1. Product Description .............................................................................. 3 1.1 Introduction ...................................................................................................................................... 3 1.2 Capacity Specification ..................................................................................................................... 3 1.3 Performance .................................................................................................................................... 3 1.4 Pin Assignments .............................................................................................................................. 4 2. Software Interface ............................................................................... 5 2.1 Command Set .................................................................................................................................. 5 2.2 S.M.A.R.T. ....................................................................................................................................... 6 3. Flash Management ............................................................................... 7 3.1 Error Correction/Detection ............................................................................................................... 7 3.2 Bad Block Management ................................................................................................................... 7 3.3 Wear Leveling .................................................................................................................................. 7 3.4 Power Failure Management ............................................................................................................. 7 3.5 TRIM ................................................................................................................................................ 7 3.6 Secure Erase ................................................................................................................................... 8 4. Reliability Specifications ...................................................................... 9 4.1 Environments ................................................................................................................................... 9 4.2 Mean Time Between Failures (MTBF) ............................................................................................. 9 4.3 Certification and Compliance ........................................................................................................... 9 5. Electrical Characteristics ................................................................... 10 5.1 Operating Voltage .......................................................................................................................... 10 5.2 Power Consumption....................................................................................................................... 10 6. Mechanical Specifications ................................................................ 11 7. Product Ordering Information ............................................................ 12 7.1 Product Code Designations ........................................................................................................... 12 7.2 Valid Combinations ........................................................................................................................ 13 2 © 2015 Apacer Technology Inc. Rev. 1.2 Serial ATA Flash Drive APS18HPAxxxG-3TMX 1. Product Description 1.1 Introduction Apacer SFD18H-M 1.8” SSD (Solid State Drive) delivers multiple technological advantages of flash memory storage. With SATA 6.0 Gbps interface, SFD18H-M offers exceptional data transfer performance. Form factor wise, this model is fully compliant with SATA 1.8” standard, which is designed with standard interface consisting of SATA 7-pin signal segment and 15-pin power segment. This drive provides low power consumption compared to traditional hard drive and hot-swapping when removing/ replacing/ upgrading flash disks. With performance up to 525 MB/s, SFD18H-M is an economical storage solution. 1.2 Capacity Specification Table 1-1 Capacity specification Capacity Total Bytes* Cylinders Heads Sectors Max LBA** 32 GB 32,071,047,552 16,383 16 63 62,533,296 64 GB 64,023,257,088 16,383 16 63 125,045,424 128 GB 128,035,676,160 16,383 16 63 250,069,680 256 GB 256,060,514,304 16,383 16 63 500,118,192 512 GB 512,110,190,592 16,383 16 63 1,000,215,216 *Display of total bytes varies from file systems. **Cylinders, heads or sectors are not applicable for these capacities. Only LBA addressing applies. ***Notes: 1 GB = 1,000,000,000 bytes; 1 sector = 512 bytes. LBA count addressed in the table above indicates total user storage capacity and will remain the same throughout the lifespan of the device. However, the total usable capacity of the SSD is most likely to be less than the total physical capacity because a small portion of the capacity is reserved for device maintenance usages. 1.3 Performance Table 1-2 Performance specifications Capacity Performance Sustained Read (MB/s) Sustained Write (MB/s) 32 GB 64 GB 128 GB 256 GB 512 GB 510 525 525 525 525 95 185 350 340 485 Note: 1. Results may vary depending on host system configurations. 2. Sustained Read/Write: The read/write performances are measured by CrystalDiskMark under Windows 7 operating system. 3 © 2015 Apacer Technology Inc. Rev. 1.2 Serial ATA Flash Drive APS18HPAxxxG-3TMX 1.4 Pin Assignments Power Segment Pin P1 Signal Segment Pin S1 Table 1-3 Signal segment Pin Type S1 GND S2 RxP S3 RxN S4 GND S5 TxN S6 TxP S7 GND Table 1-4 Power segment Description Serial Data Receiver Signal Pair Serial Data Transmitter Signal Pair Pin Signal/Description P1 3.3V) P2 3.3V P3 Ground P4 Ground P5 5V (optional) P6 5V (optional) P7 LED (optional) Key N/C P8 Erase (optional) P9 N/C The connector on the left represents the Host with TX/RX differential pairs connected to a cable while the connector on the right shows the Device with TX/RX differential pairs also connected to the cable. Notice also the ground path connecting the shielding of the cable to the Cable Receptacle. 4 © 2015 Apacer Technology Inc. Rev. 1.2 Serial ATA Flash Drive APS18HPAxxxG-3TMX 2. Software Interface 2.1 Command Set Table 2-1 Command Set Command Code Command Code NOP 00h Idle 97h Data Set Management 06h Check Power Mode 98h Recalibrate Sleep 99h Read Sectors 20h SMART B0h Read Sectors without Retry 21h Device Configuration B1h Read Sectors EXT 24h Read Multiple C4h Read DMA EXT 25h Write Multiple C5h Read Native Max Address EXT 27h Set Multiple Mode C6h Read Multiple EXT 29h Read DMA C8h Read Log EXT 2Fh Read DMA without Retry C9h Write Sectors 30h Write DMA CAh Write Sectors Without Retry 31h Write DMA without Retry CBh Write Sectors EXT 34h Write Multiple FUA EXT CEh Write DMA EXT 35h Standby Immediate E0h Set Native Max Address EXT 37h Idle Immediate E1h CFA Write Sectors without erase 38h Standby E2h Write Multiple EXT 39h Idle E3h Write DMA FUA EXT 3Dh Read Buffer E4h Write Long EXT 3Fh Check Power Mode E5h Read Verify Sectors 40h Sleep E6h Read Verify Sectors without Retry 41h Flush Cache E7h Read Verify Sectors EXT 42h Write Buffer E8h Write Uncorrectable EXT 45h Flush Cache EXT EAh Read FPDMA Queued 60h Identify Device ECh Write FPDMA Queued 61h Set Features EFh Security Set Password F1h Seek 10f-1Fh 70h-7Fh Execute Device Diagnostic 90h Security Unlock F2h Initialize Device Parameters 91h Security Erase Prepare F3h Download Microcode 92h Security Erase Unit F4h Download Microcode DMA 93h Security Freeze Lock F5h Standby Immediate 94h Security Disable Password F6h Idle Immediate 95h Read Native Max Address F8h Standby 96h Set Max Address F9h 5 © 2015 Apacer Technology Inc. Rev. 1.2 Serial ATA Flash Drive APS18HPAxxxG-3TMX 2.2 S.M.A.R.T. SMART, an acronym for Self-Monitoring, Analysis and Reporting Technology, is an open standard that allows a hard disk drive to automatically detect its health and report potential failures. When a failure is recorded by SMART, users can choose to replace the drive to prevent unexpected outage or data loss. Moreover, SMART can inform users of impending failures while there is still time to perform proactive actions, such as copy data to another device. 6 © 2015 Apacer Technology Inc. Rev. 1.2 Serial ATA Flash Drive APS18HPAxxxG-3TMX 3. Flash Management 3.1 Error Correction/Detection Flash memory cells will deteriorate with use, which might generate random bit errors in the stored data. Thus, this SSD applies the BCH ECC Algorithm, which can detect and correct errors occur during Read process, ensure data been read correctly, as well as protect data from corruption. This ECC supports up to 72bit/1K data. 3.2 Bad Block Management Bad blocks are blocks that include one or more invalid bits, and their reliability is not guaranteed. Blocks that are identified and marked as bad by the manufacturer are referred to as “Initial Bad Blocks”. Bad blocks that are developed during the lifespan of the flash are named “Later Bad Blocks”. Apacer implements an efficient bad block management algorithm to detect the factory-produced bad blocks and manages any bad blocks that appear with use. This practice further prevents data being stored into bad blocks and improves the data reliability. 3.3 Wear Leveling NAND Flash devices can only undergo a limited number of program/erase cycles, and in most cases, the flash media are not used evenly. If some areas get updated more frequently than others, the lifetime of the device would be reduced significantly. Thus, Wear Leveling technique is applied to extend the lifespan of NAND Flash by evenly distributing write and erase cycles across the media. Apacer provides advanced Wear Leveling algorithm, which can efficiently spread out the flash usage through the whole flash media area. Moreover, by implementing both dynamic and static Wear Leveling algorithms, the life expectancy of the NAND Flash is greatly improved. 3.4 Power Failure Management Power Failure Management plays a crucial role when experiencing unstable power supply. Power disruption may occur when users are storing data into the SSD. In this urgent situation, the controller would run multiple flush cycles to store the metadata for later block rebuilding. This urgent operation requires about several milliseconds to get it done. At the next power up, the firmware will perform a status tracking to retrieve the mapping table and resume previously programmed NAND blocks to check if there is any incompleteness of transmission. 3.5 TRIM TRIM is a feature which helps improve the read/write performance and speed of solid-state drives (SSD). Unlike hard disk drives (HDD), SSDs are not able to overwrite existing data, so the available space gradually becomes smaller with each use. With the TRIM command, the operating system can inform the SSD which blocks of data are no longer in use and can be removed permanently. Thus, the SSD will perform the erase action, which prevents unused data from occupying blocks all the time. 7 © 2015 Apacer Technology Inc. Rev. 1.2 Serial ATA Flash Drive APS18HPAxxxG-3TMX 3.6 Secure Erase Secure Erase is a standard ATA command and will write all “0xFF” to fully wipe all the data on hard drives and SSDs. When this command is issued, the SSD controller will empty its storage blocks and return to its factory default settings. Note: Secure erase command belongs to ATA security command. 8 © 2015 Apacer Technology Inc. Rev. 1.2 Serial ATA Flash Drive APS18HPAxxxG-3TMX 4. Reliability Specifications 4.1 Environments Table 4-1 Environmental specifications Environment Temperature Humidity Shock Vibration Drop Bending Torque ESD Specification Standard 0°C to 70°C Operating Extended -40°C to 85°C Storage -40°C to 85°C RH 93% under 40°C 1500G, 0.5ms 20Hz~80Hz/1.52mm (frequency/displacement) 80Hz~2000Hz/20G (frequency/displacement) X, Y, Z axis/60mins each 80cm free fall, 6 face of each ≧50N, hold 1min/5times 0.5N-m or 10deg, hold 5min/5times Pass Note: Shock and Vibration specifications are subject to change without notice. 4.2 Mean Time Between Failures (MTBF) Mean Time Between Failures (MTBF) is predicted based on reliability data for the individual components in SFD drive. The prediction result for SFD18H-M is more than 1,000,000 hours. Notes about the MTBF: The MTBF is predicated and calculated based on “Telcordia Technologies Special Report, SR-332, Issue 2” method. 4.3 Certification and Compliance       RoHS SATA Revision 3.0 ATA/ATAPI FCC CE BSMI 9 © 2015 Apacer Technology Inc. Rev. 1.2 Serial ATA Flash Drive APS18HPAxxxG-3TMX 5. Electrical Characteristics 5.1 Operating Voltage Table 5-1 lists the supply voltage for SFD18H-M. Table 5-1 Operating voltage Parameter Supply voltage Conditions 3.3V ±5% 5.2 Power Consumption Table 5-2 lists SFD18H-M power consumption. Table 5-2 Power consumption Capacity Consumption Active (mA) Idle (mA) 32 GB 64 GB 128 GB 256 GB 512 GB 670 740 1140 1200 1690 110 110 110 110 120 Note: power consumption may vary depending on flash configurations or platforms. 10 © 2015 Apacer Technology Inc. Rev. 1.2 Serial ATA Flash Drive APS18HPAxxxG-3TMX 6. Mechanical Specifications Unit: ㎜ Tolerance: ±0.2 ㎜ 11 © 2015 Apacer Technology Inc. Rev. 1.2 Serial ATA Flash Drive APS18HPAxxxG-3TMX 7. Product Ordering Information 7.1 Product Code Designations AP S 18H P A x x x x – 3 TM X Temperature Range Blank: Standard W: Extended Temperature Flash type Version Control Capacities: 32G: 64G: 128G: 256G: 512G: 32GB 64GB 128GB 256GB 512GB 1.8”Housing Solution version 1.8 inch Form Factor Serial ATA Flash Drive Apacer Product Code 12 © 2015 Apacer Technology Inc. Rev. 1.2 Serial ATA Flash Drive APS18HPAxxxG-3TMX 7.2 Valid Combinations Capacity Standard Extended 32GB APS18HPA032G-3TM APS18HPA032G-3TMW 64GB APS18HPA064G-3TM APS18HPA064G-3TMW 128GB APS18HPA128G-3TM APS18HPA128G-3TMW 256GB APS18HPA256G-3TM APS18HPA256G-3TMW 512GB APS18HPA512G-3TM Note: Valid combinations are those products in mass production or will be in mass production. Consult your Apacer sales representative to confirm availability of valid combinations and to determine availability of new combinations. 13 © 2015 Apacer Technology Inc. Rev. 1.2 Serial ATA Flash Drive APS18HPAxxxG-3TMX Revision History Revision Description Date 1.0 Official release 08/13/2014 1.1 Revised supply voltage requirement 09/17/2014 1.2 Updated capacities and related specifications. 01/28/2015 14 © 2015 Apacer Technology Inc. Rev. 1.2 Serial ATA Flash Drive APS18HPAxxxG-3TMX Global Presence Taiwan (Headquarters) Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: 886-2-2267-8000 Fax: 886-2-2267-2261 amtsales@apacer.com U.S.A. Apacer Memory America, Inc. 386 Fairview Way, Suite102, Milpitas, CA 95035 Tel: 1-408-518-8699 Fax: 1-408-935-9611 sa@apacerus.com Japan Apacer Technology Corp. 5F, Matsura Bldg., Shiba, Minato-Ku Tokyo, 105-0014, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Europe Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-267-0000#6199 sales@apacer.nl China Apacer Electronic (Shanghai) Co., Ltd 1301, No.251,Xiaomuqiao Road, Shanghai, 200032, China Tel: 86-21-5529-0222 Fax: 86-21-5206-6939 sales@apacer.com.cn India Apacer Technologies Pvt Ltd, # 535, 1st Floor, 8th cross, JP Nagar 3rd Phase, Bangalore – 560078, India Tel: 91-80-4152-9061 sales_india@apacer.com 15 © 2015 Apacer Technology Inc. Rev. 1.2
APS18HPA512G-3TM 价格&库存
很抱歉,暂时无法提供与“APS18HPA512G-3TM”相匹配的价格&库存,您可以联系我们找货
