APM2T60P200128GAN-8TMW 数据手册
RoHS Recast Compliant
M.2 2260 Flash Drive
P200-M Product Specifications
July 8, 2015
Version 1.2
Apacer Technology Inc.
1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C
Tel: +886-2-2267-8000
www.apacer.com
Fax: +886-2-2267-2261
APM2T60P200xxxxAN-XTMX
Features:
Standard SATA Interface Compliance
– Serial ATA Revision 3.1 compliance
– SATA 6.0 Gbps interface
– ATA-8 command set
Capacities
– 16, 32, 64, 128, 256 GB
Performance*
– Interface burst read/write: 600 MB/sec
– Sustained read: up to 520 MB/sec
– Sustained write: up to 180 MB/sec
Flash Management
– Built-in hardware ECC
– Static/dynamic wear-leveling
– Flash bad-block management
– S.M.A.R.T.
– Power Failure Management
– ATA Secure Erase
– TRIM
NAND Flash Type: MLC
Endurance
– 16GB: 14 TBW
– 32GB: 28 TBW
– 64GB: 57 TBW
– 128GB: 114 TBW
– 256GB: 228 TBW
Temperature ranges
– Operating:
Standard: 0°C to 70°C
Extended: -40°C to 85°C
– Storage: -40°C to 85°C
Supply voltage
– 3.3 V ± 5%
Power consumption (typical)*
– Active mode: 540 mA
– Idle mode: 105 mA
Connector type
– 75-pin SATA-based M.2 module pinout
Form factor
– M.2 2260 form factor
– Dimensions: 60.00mm x 22.00mm x3.65mm
Shock & Vibration***
– Shock:1500 G
– Vibration: 15 G
MTBF: >2,000,000 hours
RoHS Recast compliant (complies with
2011/65/EU standard)
Device Sleep mode (optional)
*Varies from capacities. The values for performances and power consumptions presented are typical and may vary depending on flash configurations
or platform settings. The term idle refers to the standby state of the device.
**Non-operating
1
© 2015 Apacer Technology Inc.
Rev. 1.2
Table of Contents
1. GENERAL DESCRIPTION .................................................................................................... 3
2. PIN ASSIGNMENTS ............................................................................................................... 3
3. PRODUCT SPECIFICATIONS .............................................................................................. 6
3.1 CAPACITY ............................................................................................................................................................. 6
3.2 PERFORMANCE .....................................................................................................................................................6
3.3 ENVIRONMENTAL SPECIFICATIONS .......................................................................................................................7
3.4 MEAN TIME BETWEEN FAILURES (MTBF) ...........................................................................................................7
3.5 CERTIFICATION AND COMPLIANCE .......................................................................................................................7
4. FLASH MANAGEMENT ....................................................................................................... 8
4.1 ERROR CORRECTION/DETECTION .........................................................................................................................8
4.2 BAD BLOCK MANAGEMENT .................................................................................................................................8
4.3 WEAR LEVELING ..................................................................................................................................................8
4.4 POWER FAILURE MANAGEMENT........................................................................................................................... 8
4.5 ATA SECURE ERASE ............................................................................................................................................9
4.6 TRIM ...................................................................................................................................................................9
4.7 SATA POWER MANAGEMENT .............................................................................................................................. 9
4.8 ENDURANCE ....................................................................................................................................................... 10
5. SOFTWARE INTERFACE .................................................................................................. 11
5.1 COMMAND SET ................................................................................................................................................... 11
5.2 S.M.A.R.T.......................................................................................................................................................... 12
6. ELECTRICAL SPECIFICATION ...................................................................................... 13
7. MECHANICAL SPECIFICATIONS .................................................................................. 14
2
Rev. 1.2
1. General Description
Apacer’s P200-M is the next generation modularized Solid State Drive (SSD) with the shape of all new
M.2 form factor, aimed to be the more suitable for mobile and compact computers with standard width at
only 22.00 mm. P200-M appears in M.2 2260 mechanical dimensions and is believed to be the leading
add-in storage solution for future host computing systems.
The M.2 SSD is designed with SATA-based connector pinouts, providing full compliance with the latest
SATA Revision 3.1 interface specifications. Aside from SATA compliance, P200-M delivers exceptional
performance and power efficiency. On the other hand, the extreme thin and light form factor makes P200M the ideal choice for mobile computing systems, which appears to be the trend in near future.
Regarding reliability, P200-M is built with a powerful SATA controller that supports on-the-module ECC as
well as efficient wear leveling scheme. In terms of power efficiency, P200-M is compliant with SATA 6.0
Gbps interface standard so that it can operate on SATA power management modes, which greatly save
on power consumption.
2. Pin Assignments
This connector does not support hot plug capability. There are a total of 75 pins. 12 pin locations are used
for mechanical key locations; this allows such a module to plug into both Key B and Key M connectors.
Notch M
Notch B
Pin1
Pin
Type
Description
1
CONFIG_3
Ground (according to M.2 configurations for SSD-SATA definition)
2
3.3V
Supply Pin, 3.3V
3
GND
Ground
4
3.3V
Supply pin, 3.3V
5
No connect
No connect
6
Not available
No connect (used for other purposes)
7
Not available
8
Not available
9
No connect
No connect
10
DAS/DSS
Device Activity Signal/Disable Staggered Spin-up
3
Rev. 1.2
11
No connect
12
Module key
Mechanical notch B
13
Module key
Mechanical notch B
14
Module key
Mechanical notch B
15
Module key
Mechanical notch B
16
Module key
Mechanical notch B
17
Module key
Mechanical notch B
18
Module key
Mechanical notch B
19
Module key
Mechanical notch B
Not available
21
CONFIG_0
22
Not available
23
Not available
24
Not available
25
Not available
26
Not available
27
GND
Ground
28
Not available
29
Not available
No connect
30
Not available
31
Not available
No connect
32
Not available
33
GND
Ground
34
Not available
35
Not available
No connect
36
Not available
37
Not available
No connect
38
Not available
No connect
39
GND
Ground
40
Not available
41
SATA-Rx+
Host receiver differential signal pair
42
Not available
43
SATA-Rx-
44
Not available
45
GND
Ground
46
Not available
47
SATA-Tx-
Host transmitter differential pair
4
Rev. 1.2
48
Not available
49
SATA-Tx+
50
Not available
No connect
51
GND
Ground
52
Not available
Not used
53
Not available
Not used
54
Not available
Not used
55
Not available
Not used
56
Reserved for MFG
Data
Manufacturing Data line. Used for SSD manufacturing only. Not used
in normal operation. Pins should be left N/C in platform Socket.
57
GND
Ground
58
Reserved for MFG
clock
Manufacturing Clock line. Used for SSD manufacturing only. Not used
59
Module key
Mechanical notch M
60
Module key
Mechanical notch M
61
Module key
Mechanical notch M
62
Module key
Mechanical notch M
63
Module key
Mechanical notch M
64
Module key
Mechanical notch M
65
Module key
Mechanical notch M
66
Module key
Mechanical notch M
67
Not available
68
SUSCLK
32 kHz clock supply input that is provided by PCH to reduce power
and cost for the module
69
CONFIG_1
Defines module type
70
3.3V
Supply pin, 3.3V
71
GND
Ground
72
3.3V
Supply pin, 3.3V
73
GND
Ground
74
3.3V
Supply pin, 3.3V
75
CONFIG_2
Ground
5
Rev. 1.2
3. Product Specifications
3.1 Capacity
Capacity specification of P200-M is available as shown in Table 3-1. It lists the specific capacity and the
default numbers of heads, sectors and cylinders for each product line.
Table 3-1: Capacity specifications
Capacity
Total Bytes
Cylinders
Heads
Sectors
Max LBA
16 GB
16,013,942,784
16,383
16
63
31,277,232
32 GB
32,017,047,552
16,383
16
63
62,533,296
64 GB
64,023,257,088
16,383
16
63
125,045,424
128 GB
128,035,676,160
16,383
16
63
250,069,680
256 GB
256,060,514,304
16,383
16
63
500,118,192
*Display of total bytes varies from file systems, which means not all of the bytes can be used for storage.
**Notes: 1 GB = 1,000,000,000 bytes; 1 sector = 512 bytes.
LBA count addressed in the table above indicates total user storage capacity and will remain the same throughout the lifespan of the
device. However, the total usable capacity of the SSD is most likely to be less than the total physical capacity because a small portion
of the capacity is reserved for device maintenance usages.
3.2 Performance
Performances of P200-M are listed below in table 3-2.
Table 3-2: Performance
Capacity
16 GB
32 GB
64 GB
128 GB
256 GB
Sustained read (MB/s)
300
510
515
520
520
Sustained write (MB/s)
170
180
180
180
180
Performance
Note: Results were measured by CrystalDiskMark and may differ from various flash configurations or host system setting
6
Rev. 1.2
3.3 Environmental Specifications
Environmental specification of P200-M series follows MIL-STD-810 standards as shown in Table 3-3.
Table 3-3 P200-M environmental specifications
Item
Specification
Operating temperature
0°C ~70°C(standard); -40°C ~85°C (extended)
Non-operating temperature
-40°C ~85°C
Operating humidity
40°C, 90%RH
Non-operating humidity
40°C, 93%RH
Frequency/Displacement: 20Hz~80Hz/1.52mm
Frequency/Acceleration: 80Hz~2000Hz/20G
X, Y, Z axis/60mins
1500G, 0.5ms
Vibration (Non-operating)
shock (Non-operating)
Drop (Non-operating)
Bending (non-operating)
80cm free fall, 6 face of each unit
≧20N, hold 1min/5times
Torque (non-operating)
0.5N-m or ±2.5 deg, hold 1min/5times
ESD (Electrostatic)
Passed (at relative temp/humidity: 24°C, 49%RH)
3.4 Mean Time Between Failures (MTBF)
Mean Time Between Failures (MTBF) is predicted based on reliability data for the individual components
in P200-M. The prediction result for P200-M is more than 2,000,000 hours.
Notes about the MTBF:
The MTBF is predicated and calculated based on “Telcordia Technologies Special Report, SR-332, Issue
2” method.
3.5 Certification and Compliance
P200-M complies with the following standards:
CE: EN55022
FCC :CISPR22
BSMI 13438
RoHS Recast
7
Rev. 1.2
4. Flash Management
4.1 Error Correction/Detection
P200-M implements a hardware ECC scheme, based on the BCH algorithm. It can detect and correct up
to 72 bits error in 1K bytes.
4.2 Bad Block Management
Bad blocks are blocks that include one or more invalid bits, and their reliability is not guaranteed. Blocks
that are identified and marked as bad by the manufacturer are referred to as “Initial Bad Blocks”. Bad
blocks that are developed during the lifespan of the flash are named “Later Bad Blocks”. Apacer
implements an efficient bad block management algorithm to detect the factory-produced bad blocks and
manages any bad blocks that appear with use. This practice further prevents data being stored into bad
blocks and improves the data reliability.
4.3 Wear Leveling
NAND flash devices can only undergo a limited number of program/erase cycles, and in most cases, the
flash media are not used evenly. If some areas get updated more frequently than others, the lifetime of
the device would be reduced significantly. Thus, Wear Leveling is applied to extend the lifespan of NAND
flash by evenly distributing write and erase cycles across the media.
Apacer provides advanced Wear Leveling algorithm, which can efficiently spread out the flash usage
through the whole flash media area. Moreover, by implementing both dynamic and static Wear Leveling
algorithms, the life expectancy of the NAND flash is greatly improved.
4.4 Power Failure Management
Power Failure Management is a mechanism to prevent data loss during unexpected power failure. DRAM
is a volatile memory and frequently used as temporary cache or buffer between the controller and the
NAND flash to improve the SSD performance. However, one major concern of the DRAM is that it is not
able to keep data during power failure. Accordingly, P200-M applies the flush mechanism, which requests
the controller to transfer data to the cache. For P200-M, DDR performs as a cache. Only when the data is
fully committed to the NAND flash will the controller send acknowledgement (ACK) to the host. Such
implementation can prevent false-positive performance and the risk of power cycling issues.
Additionally, it is critical for a controller to shorten the time the in-flight data stays in the cache. Thus,
P200-M applies an algorithm to reduce the amount of data resides in the cache to provide a better
performance. This algorithm allows incoming data to only have a “pit stop” in the cache and then move to
the NAND flash at once. If the flash is jammed due to particular file sizes (such as random 4KB data), the
cache will be treated as an “organizer”, consolidating incoming data into groups before written into the
flash to improve write amplification.
In sum, Power Failure Management proves to provide the reliability required by consumer, industrial, and
enterprise-level applications.
8
Rev. 1.2
4.5 ATA Secure Erase
ATA Secure Erase is a standard ATA command and will write all “0xFF” to fully wipe all the data on hard
drives and SSDs. When this command is issued, the SSD controller will empty its storage blocks and
return to its factory default settings.
4.6 TRIM
TRIM is a feature which helps improve the read/write performance and speed of solid-state drives (SSD).
Unlike hard disk drives (HDD), SSDs are not able to overwrite existing data, so the available space
gradually becomes smaller with each use. With the TRIM command, the operating system can inform the
SSD which blocks of data are no longer in use and can be removed permanently. Thus, the SSD will
perform the erase action, which prevents unused data from occupying blocks all the time.
4.7 SATA Power Management
By complying with SATA 6.0 Gb/s specifications, the SSD supports the following SATA power saving
modes:
ACTIVE: PHY ready, full power, Tx & Rx operational
PARTIAL: Reduces power, resumes in under 10 µs (microseconds)
SLUMBER: Reduces power, resumes in under 10 ms (milliseconds)
HIPM: Host-Initiated Power Management
DIPM: Device-Initiated Power Management
Device Sleep (DevSleep or DEVSLP): PHY powered down; power consumption ≦ 5 mW; host
assertion time ≦ 10 ms; exit timeout from this state ≦ 20 ms (unless specified otherwise in SATA
Identify Device Log).
Note:
1. The behaviors of power management features would depend on host/device settings.
9
Rev. 1.2
4.8 Endurance
The endurance of a storage device is predicted by TeraBytes Written based on several factors related to
usage, such as the amount of data written into the drive, block management conditions, and daily
workload for the drive. Thus, key factors, such as Write Amplifications and the number of P/E cycles, can
influence the lifespan of the drive.
Capacity
TeraBytes Written
16 GB
14
32 GB
28
64 GB
57
128 GB
114
256 GB
228
Notes:
The measurement assumes the data written to the SSD for test is under a typical and constant rate.
The measurement follows the standard metric: 1 TB (Terabyte) = 1000 GB.
This estimation complies with JEDEC JESD-219, enterprise endurance workload of random data
with payload size distribution.
10
Rev. 1.2
5. Software Interface
5.1 Command Set
Table 5-1: Command set
Command
Code
Command
Code
CHECK POWER MODE
98h
10h-1Fh
SLEEP
99h
Read Sectors
20h
SMART
B0h
Read Sectors without Retry
21h
DEVICE CONFIGURATION
B1h
Read Sectors EXT
24h
Read Multiple
C4h
Read DMA EXT
25h
Write Multiple
C5h
27h
Set Multiple Mode
C6h
Read Multiple EXT
29h
Read DMA
C8h
Read Log EXT
2Fh
Read DMA without Retry
C9h
Write Sectors
30h
Write DMA
CAh
31h
Write DMA without Retry
CBh
34h
Write Multiple FUA EXT
CEh
Write DMA EXT
35h
Standby Immediate
E0h
Set Native Max Address EXT
37h
Idle Immediate
E1h
CFA WRITE SECTORS WITHOUT ERASE
38h
Standby
E2h
E3h
Data Set Management
Recalibrate
Read Native Max Address EXT
Write Sectors without Retry
Write Sectors EXT
Write Multiple EXT
06h
39h
IDLE
Write DMA FUA EXT
3Dh
Read Buffer
E4h
Write Long EXT
3Fh
Check Power Mode
E5h
Read Verify Sectors
40h
Sleep
E6h
Read Verify Sectors without Retry
41h
Flush Cache
E7h
E8h
Read Verify Sectors EXT
42h
Write Buffer
WRITE UNCORRECTABLE EXT
45h
Flush Cache EXT
EAh
Read FPDMA Queued
60h
Identify Device
ECh
Write FPDMA Queued
61h
Set Features
EFh
Security Set Password
F1h
F2h
Seek
Execute Device Diagnostic
70h-71h
90h
Security Unlock
Initialize Device Parameters
91h
Security Erase Prepare
F3h
Download Microcode
92h
Security Erase Unit
F4h
DOWNLOAD MICROCODE DMA
93h
Security Freeze Lock
F5h
94h
Security Disable Password
F6h
STANDBY IMMEDIATE
11
Rev. 1.2
IDLE IMMEDIATE
95h
F8
STANDBY
96h
Set Max Address
F9
IDLE
97h
5.2 S.M.A.R.T.
SMART, an acronym for Self-Monitoring, Analysis and Reporting Technology, is an open standard that
allows a hard disk drive to automatically detect its health and report potential failures. When a failure is
recorded by SMART, users can choose to replace the drive to prevent unexpected outage or data loss.
Moreover, SMART can inform users of impending failures while there is still time to perform proactive
actions, such as copy data to another device.
12
Rev. 1.2
6. Electrical Specification
Table 6-1: Operating range
Ambient Temperature
0°C ~ +70°C(standard)
-40°C ~ 85°C (extended)
Supply Voltage
3.3V±5% (3.135-3.465V)
Table 6-2: Typical power consumption
Capacity
16 GB
32 GB
64 GB
128 GB
256 GB
Active (mA)
370
480
540
535
535
Idle (mA)
100
100
100
100
105
Modes
Note: Results may differ from various flash configurations or host system setting
13
Rev. 1.2
7. Mechanical Specifications
14
Rev. 1.2
15
Rev. 1.2
8. Product Ordering Information
8.1
AP
Product Code Designations
M2
T60
P200
xxxx
AN
X
TM
X
Temperature Range
Blank: Standard
W: Extended Temperature
Flash Type
Version Control
Apacer Brand
Capacities:
016G =
032G =
064G =
128G =
256G =
16GB
32GB
64GB
128GB
256GB
Solution version
Form Factor
M.2
Apacer Product Code
16
Rev. 1.2
8.2
Valid Combinations
8.2.1 Standard Temperature
Capacity
No DEVSLP
DEVSLP
16GB
32GB
64GB
APM2T60P200016GAN-7TM
APM2T60P200032GAN-7TM
APM2T60P200064GAN-7TM
APM2T60P200016GAN-8TM
APM2T60P200032GAN-8TM
APM2T60P200064GAN-8TM
128GB
256GB
APM2T60P200128GAN-7TM
APM2T60P200256GAN-7TM
APM2T60P200256GAN-8TM
8.2.2 Extended Temperature
Capacity
No DEVSLP
DEVSLP
16GB
32GB
64GB
128GB
APM2T60P200016GAN-7TMW
APM2T60P200032GAN-7TMW
APM2T60P200064GAN-7TMW
APM2T60P200128GAN-7TMW
APM2T60P200016GAN-8TMW
APM2T60P200032GAN-8TMW
APM2T60P200064GAN-8TMW
256GB
APM2T60P200256GAN-7TMW APM2T60P200256GAN-8TMW
Note: Valid combinations are those products in mass production or will be in mass production. Consult
your Apacer sales representative to confirm availability of valid combinations and to determine availability
of new combinations.
17
Rev. 1.2
Revision History
Revision
Date
Description
Remark
1.0
10/28/2014
Official release
1.1
07/07/2015
Add endurance information
-Added extended temp product support
1.2
07/08/2015
-Revised product ordering information due to FW
change(22A)
18
Rev. 1.2
Global Presence
Taiwan (Headquarters)
1F., No.32, Zhongcheng Rd., Tucheng Dist.,
New Taipei City 236, Taiwan R.O.C.
Tel: 886-2-2267-8000
Fax: 886-2-2267-2261
amtsales@apacer.com
U.S.A.
Apacer Memory America, Inc.
386 Fairview Way, Suite102,
Milpitas, CA 95035
Tel: 1-408-518-8699
Fax: 1-408-935-9611
sa@apacerus.com
Japan
Apacer Technology Corp.
5F, Matsura Bldg., Shiba, Minato-Ku
Tokyo, 105-0014, Japan
Tel: 81-3-5419-2668
Fax: 81-3-5419-0018
jpservices@apacer.com
Europe
Apacer Technology B.V.
Science Park Eindhoven 5051 5692 EB Son,
The Netherlands
Tel: 31-40-267-0000
Fax: 31-40-267-0000#6199
sales@apacer.nl
China
Apacer Electronic (Shanghai) Co., Ltd
1301, No.251,Xiaomuqiao Road, Shanghai,
200032, China
Tel: 86-21-5529-0222
Fax: 86-21-5206-6939
sales@apacer.com.cn
India
Apacer Technologies Pvt Ltd,
# 535, 1st Floor, 8th cross, JP Nagar 3rd Phase,
Bangalore – 560078, India
Tel: 91-80-4152-9061
sales_india@apacer.com
19
Rev. 1.2
