APS18SH1128G-HTMW
APS18SH1128G-HTMW
    APACERMEMORYAMERICA(宇瞻科技)
    Solid State Drive (SSD) 128GB SATA III FLASH - NAND (MLC) Slim-SATA 5V
APS18SH1128G-HTMW 数据手册
RoHS Compliant SATA Flash Drive SFD18SH-M Product Specifications November 13, 2015 Version 2.0 Apacer Technology Inc. 1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C Tel: +886-2-2267-8000 www.apacer.com Fax: +886-2-2267-2261 Serial ATA Flash Drive APS18SH1xxxG-XTMX Features:  Serial ATA Revision 3.1 Compliance – SATA 6.0 Gbps interface – Backward compatible with SATA 3.0/1.5 Gbps interface – ATA Command set  Temperature Ranges – Operating: Standard: 0°C to 70°C Extended: -40°C to 85°C – Storage: -40°C to 85°C  Capacities – 8, 16, 32, 64, 128, 256 GB  Supply Voltage – 5 V ± 5%  Performance* – Interface burst read/write: 600 MB/sec – Sustained read: up to 510 MB/sec – Sustained write: up to 190 MB/sec  Power Consumption (typical)* – Active mode: 392 mA – Idle mode: 57 mA   Flash Management – Built-in hardware ECC – Wear-leveling – Flash bad block management – S.M.A.R.T. – Power Failure Management – TRIM Form Factor – JEDEC MO-297  NAND Flash Type: MLC  Endurance – 8 GB: 7 TBW – 16 GB: 14 TBW – 32 GB: 28 TBW – 64 GB: 57 TBW – 128 GB: 114 TBW – 256 GB: 228 TBW – Dimensions (54.0 x 39.8 x 4.0, unit: ㎜)  Connector – 7-pin SATA male connector – 15-pin SATA power connector  RoHS Compliant  Device Sleep Mode (optional) *The values presented for Performances and Power Consumption are typical and may vary depending on different configurations and platforms. 1 © 2015 Apacer Technology Inc. Rev. 2.0 Serial ATA Flash Drive APS18SH1xxxG-XTMX Table of Contents 1. Product Description ............................................................................. 3 1.1 Introduction ...................................................................................................................................... 3 1.2 Capacity Specifications .................................................................................................................... 3 1.3 Performance .................................................................................................................................... 3 1.4 Pin Assignments .............................................................................................................................. 4 2. Software Interface ................................................................................ 6 2.1 Command Set .................................................................................................................................. 6 2.2 S.M.A.R.T. ....................................................................................................................................... 7 3. Flash Management ................................................................................ 8 3.1 Error Correction/Detection ............................................................................................................... 8 3.2 Bad Block Management ................................................................................................................... 8 3.3 Wear Leveling .................................................................................................................................. 8 3.4 Power Failure Management ............................................................................................................. 8 3.5 TRIM ................................................................................................................................................ 8 3.6 Secure Erase ................................................................................................................................... 9 4. Reliability Specifications .................................................................... 10 4.1 Environments ................................................................................................................................. 10 4.2 Mean Time Between Failures (MTBF) ........................................................................................... 10 4.3 Certification and Compliance ......................................................................................................... 10 4.4 Endurance ...................................................................................................................................... 11 5. Electrical Characteristics ................................................................... 12 5.1 Operating Voltage .......................................................................................................................... 12 5.2 Power Consumption....................................................................................................................... 12 6. Mechanical Specifications ................................................................. 13 7. Product Ordering Information ............................................................. 14 7.1 Product Code Designation ............................................................................................................. 14 7.2 Valid Combination .......................................................................................................................... 15 Revision History ...................................................................................... 16 2 © 2015 Apacer Technology Inc. Rev. 2.0 Serial ATA Flash Drive APS18SH1xxxG-XTMX 1. Product Description 1.1 Introduction Apacer SFD18SH-M half-slim MO-297 SSD (Solid State Drive) delivers multiple technological advantages of flash memory storage. With SATA 6.0 Gbps interface, SFD18SH-M offers exceptional data transfer performance. Form factor wise, this model is fully compliant with JEDEC MO-297 standard, which is designed with standard interface consisting of SATA 7-pin signal segment and 15-pin power segment, while in compact size. This module provides low power consumption compared to traditional hard drive and hotswapping when removing/ replacing/ upgrading flash disks. Its capacity could provide a wide range up to 256 GB. Moreover, it can reach up to 510 MB/s read as well as 190 MB/s write high performance. 1.2 Capacity Specifications Table 1-1 Capacity Specifications Capacity Total Bytes* Cylinders Heads Sectors Max LBA** 8 GB 8,012,390,400 15,525 16 63 15,649,200 16 GB 16,013,942,784 16,383 16 63 31,277,232 32 GB 32,017,047,552 16,383 16 63 62,533,296 64 GB 64,023,257,088 16,383 16 63 125,045,424 128 GB 128,035,676,160 16,383 16 63 250,069,680 256 GB 256,060,514,304 16,383 16 63 500,118,192 *Display of total bytes varies from file systems. **Cylinders, heads or sectors are not applicable for these capacities. Only LBA addressing applies. ***Notes: 1 GB = 1,000,000,000 bytes; 1 sector = 512 bytes. LBA count addressed in the table above indicates total user storage capacity and will remain the same throughout the lifespan of the device. However, the total usable capacity of the SSD is most likely to be less than the total physical capacity because a small portion of the capacity is reserved for device maintenance usages. 1.3 Performance Table 1-2 Performance Specifications Capacity 8 GB 16 GB 32 GB 64 GB 128 GB 256 GB Sustained Read (MB/s) 155 480 480 480 480 510 Sustained Write (MB/s) 85 150 150 180 180 190 Performance Note: 1. Results may vary depending on host system configurations. 2. Sustained Read/Write: The read/write performances are measured by CrystalDiskMark under Windows 7 operating system. 3 © 2015 Apacer Technology Inc. Rev. 2.0 Serial ATA Flash Drive APS18SH1xxxG-XTMX 1.4 Pin Assignments Table 1-3 Signal Segment Pin Type S1 GND S2 RxP S3 RxN S4 GND S5 TxN S6 TxP S7 GND Table 1-4 Power Segment Description Serial Data Receiver Signal Pair Serial Data Transmitter Signal Pair Pin Signal/Description P1 Not used (3.3V) P2 Not used (3.3V) P3 Not used or Device Sleep P4 Ground P5 Ground P6 Ground P7 5V P8 5V P9 5V P10 Ground P11 Reserved P12 Ground P13 Not used (12V) P14 Not used (12V) P15 Not used (12V) Note: P3 can be configured as trigger pin for Device Sleep. 4 © 2015 Apacer Technology Inc. Rev. 2.0 Serial ATA Flash Drive APS18SH1xxxG-XTMX Figure 1-3 SATA Cable / Connector Connection Diagram The connector on the left represents the Host with TX/RX differential pairs connected to a cable while the connector on the right shows the Device with TX/RX differential pairs also connected to the cable. Notice also the ground path connecting the shielding of the cable to the Cable Receptacle. 5 © 2015 Apacer Technology Inc. Rev. 2.0 Serial ATA Flash Drive APS18SH1xxxG-XTMX 2. Software Interface 2.1 Command Set Table 2-1 Command Set Command Code Command Code NOP 00h Idle 97h Data Set Management 06h Check Power Mode 98h Recalibrate 10f-1Fh Sleep 99h Read Sectors 20h SMART B0h Read Sectors without Retry 21h Device Configuration B1h Read Sectors EXT 24h Read Multiple C4h Read DMA EXT 25h Write Multiple C5h Read Native Max Address EXT 27h Set Multiple Mode C6h Read Multiple EXT 29h Read DMA C8h Read Log EXT 2Fh Read DMA without Retry C9h Write Sectors 30h Write DMA CAh Write Sectors Without Retry 31h Write DMA without Retry CBh Write Sectors EXT 34h Write Multiple FUA EXT CEh Write DMA EXT 35h Standby Immediate E0h Set Native Max Address EXT 37h Idle Immediate E1h CFA Write Sectors without erase 38h Standby E2h Write Multiple EXT 39h Idle E3h Write DMA FUA EXT 3Dh Read Buffer E4h Write Long EXT 3Fh Check Power Mode E5h Read Verify Sectors 40h Sleep E6h Read Verify Sectors without Retry 41h Flush Cache E7h Read Verify Sectors EXT 42h Write Buffer E8h Write Uncorrectable EXT 45h Flush Cache EXT EAh Read FPDMA Queued 60h Identify Device ECh Write FPDMA Queued 61h Set Features EFh 70h-7Fh Security Set Password F1h Seek Execute Device Diagnostic 90h Security Unlock F2h Initialize Device Parameters 91h Security Erase Prepare F3h Download Microcode 92h Security Erase Unit F4h Download Microcode DMA 93h Security Freeze Lock F5h Standby Immediate 94h Security Disable Password F6h Idle Immediate 95h Read Native Max Address F8h Standby 96h Set Max Address F9h 6 © 2015 Apacer Technology Inc. Rev. 2.0 Serial ATA Flash Drive APS18SH1xxxG-XTMX 2.2 S.M.A.R.T. SMART, an acronym for Self-Monitoring, Analysis and Reporting Technology, is an open standard that allows a hard disk drive to automatically detect its health and report potential failures. When a failure is recorded by SMART, users can choose to replace the drive to prevent unexpected outage or data loss. Moreover, SMART can inform users of impending failures while there is still time to perform proactive actions, such as copy data to another device. 7 © 2015 Apacer Technology Inc. Rev. 2.0 Serial ATA Flash Drive APS18SH1xxxG-XTMX 3. Flash Management 3.1 Error Correction/Detection Flash memory cells will deteriorate with use, which might generate random bit errors in the stored data. Thus, this SSD applies the BCH ECC Algorithm, which can detect and correct errors occur during Read process, ensure data been read correctly, as well as protect data from corruption. This ECC supports up to 72bit/1K data. 3.2 Bad Block Management Bad blocks are blocks that include one or more invalid bits, and their reliability is not guaranteed. Blocks that are identified and marked as bad by the manufacturer are referred to as “Initial Bad Blocks”. Bad blocks that are developed during the lifespan of the flash are named “Later Bad Blocks”. Apacer implements an efficient bad block management algorithm to detect the factory-produced bad blocks and manages any bad blocks that appear with use. This practice further prevents data being stored into bad blocks and improves the data reliability. 3.3 Wear Leveling NAND Flash devices can only undergo a limited number of program/erase cycles, and in most cases, the flash media are not used evenly. If some areas get updated more frequently than others, the lifetime of the device would be reduced significantly. Thus, Wear Leveling technique is applied to extend the lifespan of NAND Flash by evenly distributing write and erase cycles across the media. Apacer provides advanced Wear Leveling algorithm, which can efficiently spread out the flash usage through the whole flash media area. Moreover, by implementing both dynamic and static Wear Leveling algorithms, the life expectancy of the NAND Flash is greatly improved. 3.4 Power Failure Management Power Failure Management plays a crucial role when experiencing unstable power supply. Power disruption may occur when users are storing data into the SSD. In this urgent situation, the controller would run multiple flush cycles to store the metadata for later block rebuilding. This urgent operation requires about several milliseconds to get it done. At the next power up, the firmware will perform a status tracking to retrieve the mapping table and resume previously programmed NAND blocks to check if there is any incompleteness of transmission. 3.5 TRIM TRIM is a feature which helps improve the read/write performance and speed of solid-state drives (SSD). Unlike hard disk drives (HDD), SSDs are not able to overwrite existing data, so the available space gradually becomes smaller with each use. With the TRIM command, the operating system can inform the SSD which blocks of data are no longer in use and can be removed permanently. Thus, the SSD will perform the erase action, which prevents unused data from occupying blocks all the time. 8 © 2015 Apacer Technology Inc. Rev. 2.0 Serial ATA Flash Drive APS18SH1xxxG-XTMX 3.6 Secure Erase Secure Erase is a standard ATA command and will write all “0xFF” to fully wipe all the data on hard drives and SSDs. When this command is issued, the SSD controller will empty its storage blocks and return to its factory default settings. Note: Secure erase command belongs to ATA security command. 9 © 2015 Apacer Technology Inc. Rev. 2.0 Serial ATA Flash Drive APS18SH1xxxG-XTMX 4. Reliability Specifications 4.1 Environments Table 4-1 Environmental specifications Environment Operating Temperature Storage Shock Vibration Drop Bending Torque ESD Specification 0°C to 70°C (Standard); -40°C to 85°C (Extended) -40°C to 85°C 1,500G, 0.5ms 20Hz~80Hz/1.52mm (frequency/displacement) 80Hz~2000Hz/20G (frequency/displacement) X, Y, Z axis/60mins each 80cm free fall, 6 face of each ≧20N, hold 1min/5times 0.5N-m or 2.5deg , hold 1min/5times Pass Note: Shock and Vibration specifications are subject to change without notice. 4.2 Mean Time Between Failures (MTBF) Mean Time Between Failures (MTBF) is predicted based on reliability data for the individual components in SFD drive. The prediction result for SFD18SH-M is more than 1,000,000 hours. Notes about the MTBF: The MTBF is predicated and calculated based on “Telcordia Technologies Special Report, SR-332, Issue 2” method. 4.3 Certification and Compliance        RoHS SATA Revision 3.1 ATA/ATAPI FCC CE BSMI MIL-STD-810G 10 © 2015 Apacer Technology Inc. Rev. 2.0 Serial ATA Flash Drive APS18SH1xxxG-XTMX 4.4 Endurance The endurance of a storage device is predicted by Tera Bytes Written based on several factors related to usage, such as the amount of data written into the drive, block management conditions, and daily workload for the drive. Thus, key factors, such as Write Amplifications and the number of P/E cycles, can influence the lifespan of the drive. Capacity 8 GB 16 GB 32 GB 64 GB 128 GB 256 GB Tera Bytes Written 7 14 28 57 114 228 Notes:    The measurement assumes the data written to the SSD for test is under a typical and constant rate. The measurement follows the standard metric: 1 TB (Terabyte) = 1,000 GB. This estimation complies with JEDEC JESD-219, enterprise endurance workload of random data with payload size distribution. 11 © 2015 Apacer Technology Inc. Rev. 2.0 Serial ATA Flash Drive APS18SH1xxxG-XTMX 5. Electrical Characteristics 5.1 Operating Voltage Table 5-1 lists the supply voltage for SFD18SH-M. Table 5-1 Operating Voltage Parameter Conditions Supply voltage 5V ± 5% 5.2 Power Consumption Table 5-2 lists SFD18SH-M power consumption. Table 5-2 Power Consumption (typical) Capacity 8 GB 16 GB 32 GB 64 GB 128 GB 256 GB Active (mA) 38 199 218 293 352 392 Idle (mA) 17 56 53 55 57 57 Performance Note: power consumption may vary depending on flash configurations or platforms.. 12 © 2015 Apacer Technology Inc. Rev. 2.0 Serial ATA Flash Drive APS18SH1xxxG-XTMX 6. Mechanical Specifications Unit: ㎜ Tolerance: ±0.2 ㎜ 13 © 2015 Apacer Technology Inc. Rev. 2.0 Serial ATA Flash Drive APS18SH1xxxG-XTMX 7. Product Ordering Information 7.1 Product Code Designation A P S 18SH 1 xxxx - X TM X Operating Temperature Range Blank: 0°C ~ 70°C W: -40°C ~ 85°C Flash Type Version Control Capacity 008G = 8GB 016G = 16GB 032G = 32GB 064G = 64GB 128G = 128GB 256G = 256GB Solution version MO-297 Form Factor Serial ATA Flash Drive Apacer Product Code 14 © 2015 Apacer Technology Inc. Rev. 2.0 Serial ATA Flash Drive APS18SH1xxxG-XTMX 7.2 Valid Combination 7.2.1 Operating Temperature (0°C ~ 70°C) Capacity 8GB 16GB 32GB 64GB 128GB 256GB no DEVSLP APS18SH1008G-GTM APS18SH1016G-GTM APS18SH1032G-GTM APS18SH1064G-GTM APS18SH1128G-GTM APS18SH1256G-GTM DEVSLP APS18SH1008G-HTM APS18SH1016G-HTM APS18SH1032G-HTM APS18SH1064G-HTM APS18SH1128G-HTM APS18SH1256G-HTM 7.2.2 Extended Temperature (-40°C ~ 85°C) Capacity 8GB 16GB 32GB 64GB 128GB 256GB no DEVSLP APS18SH1008G-GTMW APS18SH1016G-GTMW APS18SH1032G-GTMW APS18SH1064G-GTMW APS18SH1128G-GTMW APS18SH1256G-GTMW DEVSLP APS18SH1008G-HTMW APS18SH1016G-HTMW APS18SH1032G-HTMW APS18SH1064G-HTMW APS18SH1128G-HTMW APS18SH1256G-HTMW Note: Valid combinations are those products in mass production or will be in mass production. Consult your Apacer sales representative to confirm availability of valid combinations and to determine availability of new combinations. 15 © 2015 Apacer Technology Inc. Rev. 2.0 Serial ATA Flash Drive APS18SH1xxxG-XTMX Revision History Revision 1.0 1.1 Description Date Official release 07/04/2014 Added 16GB model 10/14/2014 Added Extended temperature specifications 1.2 Revised Serial ATA spec support : 3.0 -> 3.1 11/07/2014 1.3 Added endurance information 11/20/2014 1.4 Revised 16GB performance 11/25/2014 1.5 Added 8 GB model MIL-STD-810G approved, added in section 4.3 “Certification and Compliance” list - Revised product ordering information due to FW change - Revised endurance value due to estimation change Revised performance value and product ordering information for 15nm MLC models. Revised performance value and product ordering information due to FW change 02/06/2014 Added extended temperature and valid combinations for extended temperature 11/13/2015 1.6 1.7 1.8 1.9 2.0 03/18/2015 06/29/2015 10/2/2015 10/16/2015 16 © 2015 Apacer Technology Inc. Rev. 2.0 Serial ATA Flash Drive APS18SH1xxxG-XTMX Global Presence Taiwan (Headquarters) Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: 886-2-2267-8000 Fax: 886-2-2267-2261 amtsales@apacer.com U.S.A. Apacer Memory America, Inc. 46732 Lakeview Blvd., Fremont, CA 94538 Tel: 1-408-518-8699 Fax: 1-510-249-9568 sa@apacerus.com Japan Apacer Technology Corp. 5F, Matsura Bldg., Shiba, Minato-Ku Tokyo, 105-0014, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Europe Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-267-0000#6199 sales@apacer.nl China Apacer Electronic (Shanghai) Co., Ltd Room D, 22/FL, No.2, Lane 600, JieyunPlaza, Tianshan RD, Shanghai, 200051, China Tel: 86-21-6228-9939 Fax: 86-21-6228-9936 sales@apacer.com.cn India Apacer Technologies Pvt Ltd, th Unit No.201, “Brigade Corner”, 7 Block Jayanagar, Yediyur Circle, Bangalore – 560082, India Tel: 91-80-4152-9061 Fax: 91-80-4170-0215 sales_india@apacer.com 17 © 2015 Apacer Technology Inc. Rev. 2.0
APS18SH1128G-HTMW
物料型号:Apacer SFD18SH-M Serial ATA Flash Drive,型号为APS18SH1xxxG-XTMX。
器件简介:Apacer SFD18SH-M是一款半轻薄的固态硬盘(SSD),采用SATA 6.0 Gbps接口,提供出色的数据传输性能。它符合JEDEC MO-297标准,具有较低的功耗,并支持热插拔。
引脚分配: - 信号段:S1为地线(GND),S2至S7涉及数据接收和发送信号对。 - 电源段:P1至P15涉及3.3V、5V电源线和地线,其中P3可配置为设备休眠触发引脚。
参数特性: - 容量:8GB、16GB、32GB、64GB、128GB、256GB。 - 性能:最高510MB/s的持续读取速度和最高190MB/s的持续写入速度。 - 闪存管理:内置硬件ECC、磨损均衡、闪存坏块管理、S.M.A.R.T.、断电管理、TRIM。 - 耐写入度:不同容量的SSD具有不同的TBW(Terabytes Written)值。
功能详解: - 支持SATA 6.0 Gbps接口,兼容SATA 3.0/1.5 Gbps。 - 提供多种容量选项,支持热插拔。 - 内置硬件ECC算法,可检测和纠正读取过程中的错误。 - 采用先进的磨损均衡算法,延长NAND闪存的使用寿命。 - TRIM功能帮助提高SSD的读写性能和速度。
应用信息:适用于需要快速数据传输和高可靠性的应用场景,如服务器、个人电脑等。
封装信息:尺寸为54.0 x 39.8 x 4.0毫米,符合JEDEC MO-297标准。
APS18SH1128G-HTMW 价格&库存
很抱歉,暂时无法提供与“APS18SH1128G-HTMW”相匹配的价格&库存,您可以联系我们找货
